Question about Vtech i5807 (735078006394) Cordless Expansion Handset
Vtech i5807 keypad erratic
When I press a number on the i5807 kepad, a signal may or may not be generated. Is the inside contact dirty and, if so, can I clean it?
  • sidinheaven Jan 02, 2009
    I have a base phone i5867 and an expansion unit i5807 they are now more than 2 years old. I am highly satisfied with their performance in all aspects except both the handset keypad have started troubling as it has become contantly hard to press certain keys like # 8, 4 & 1. sometimes i have to press them 4 to 5 times. I thought there might be some dust which might have been collected underneath the pad so i tried to open and clean it. I could find 4 screws at the battery compartment but still could not open it. I don't want to force and break it as i love these phones. I shall be really thankful if someone can help me figure out how to fix it.
    Thanks in advance.
2 Suggested Answers
  • 89 Answers
SOURCE: Hard to press keys on i5807 vtech phones
your best bet is to get new handsets
Posted on Jan 07, 2009
1) you must change the batteries
2) clean the contacts batteries with special cleaner contacs
3) retight the spring contacts batteries for better contact.
4) resolder the wires connector contacts batteries.
5) open the remote control, for clean keypads for dirty, corrosion, or oxide.
6) remember the r.control send infrared frequency, and it must be clean the matrix design inside , in other words, must be clean, other wise inside the microcontroller WILL not work GOOD, only erratic.
7) Otherwise you must go to the repair shop TV, or change the R. Control.
God bless you
Jul 10, 2012 | Acoustic Research ARRX18G LCD Touchscreen...
Space bar not working
It is kepad fault. The membrane switches inside the space bar has the fault. You have to replace the kepad. there is no repair to this porblem, except keypad replacement..
Feb 04, 2012 | Toshiba Satellite Computers & Internet
My nokia 5130c kepad is not properly working that the key is 6,9,# is not properly working
Thanks for writing Fixya. I am Marion and let me help you with this.
There are reasons why your phones keypad is not working, first, have you tried re aligning your keypad if it fits exactly on the button, also, you may try pressing the keys without the keypad tofind out if the problem is just on the keypad or on the phones hardware already. Also, the keypads functionality may affect if it had a water spill or had dropped previuosly.
Jun 24, 2011 | Nokia 5130 Cellular Phone
I would like to install an additional kepad to my existing system.
You will need to run a 4conductor wire (preferably 22 gauge stranded) from the main control panel to the keypad location you desire. Long bit are made to accomplish without exposing wires. Contact me for additional information
May 04, 2011 | Honeywell Ademco 6160 Alpha Keypad Vista...
Wireless Kepad Does not always work first time
It sounds like you have a bad keypad. It flashes when it is working not when there is a problem. Call and get warranty service.
Jun 08, 2009 | Sears Craftsman LiftMaster Chamberlain...
Can put in base id
Did you try this (from the i5801 manual) -
To register a handset to the base, follow these steps:
Step 1: If ENTER BASE ID is displayed on the handset, proceed to the next step; if not, press MENU on the handset, then press ▼ until REGISTER is highlighted; now press OK.
Step 2: Locate the 15-digit Base ID number by pressing, at the base: MENU, then press until DISPLAY BASE-ID is highlighted, then press OK.
Step 3: Carefully enter this number using the handset dialpad. If you make a mistake, press to backspace. When finished, press OK.
In a few moments, the handset will be assigned a number (1-6). This will be the lowest available number in the sequence not previously assigned to another system handset.
Step 4: Repeat the procedure for any other unregistered system handsets.
Reply back if you have success. The Base ID is not from the bottom of the base unit, but is something you get by following Step 2 above.
Feb 04, 2009 | Vtech i5807 (735078006394) Cordless...
Nokia 6800
there are connector for left side kepad. those connecter are on the head of phone, u locate them hold ur phone vertically from the button which power on ur phone above that button on head of ur phone on the both corners u will see four golden small strips, with pair of 2 on both sides. there can be some kind of rusting on strips , rub them with needle, then check ur kepad if problem still stays then may be ur left keypad is not making connection with those strips contact any technician
Dec 16, 2007 | Nokia 6800
Stow n go wireless keypad
had the same problem.
try holding the alt key while entering the numeric code and then hitting ENTER on the keypad.
Oct 30, 2007 | Targus Stow-N-Go AKP01US Keypad
Vtech i5807 (735078006394) Cordless Expansion Handset Logo
59 people viewed this question
Top Vtech Lands Phones Experts
Are you a Vtech Lands Phone Expert? Answer questions, earn points and help others
