Question about Jenn-Air Grilling
Jenn-Air Grill My Jenn-Air Grill lignts, but won't stay lit. Any ideas?
  • Anonymous Mar 18, 2014
    jenn air grill
We had a similar problem. It turns out that there is some sort of fuel distribution rod that fits into the gas jets in the front of the grill (remove the drip pan). It appears that the gaskets between the gas jets and the rod have burned/disintegrated. We ordered a new rod from Nextgrill but it came w/o gaskets. So now we're having to call again to see if the gaskets are a separate item or if (for some reason) they are part of the jets?? Anyway, good luck.
Posted on Jun 27, 2008
An older jenn air grill range model # S125- the left burner does not work front or back and the light stays on
Replace the switch that controls one of the two burners. One switch is bad. Look also for a blown fuse. if present.
Chances are one bad element had shorted out the switch (now stays lit) and also took out one fuse.
Oct 20, 2013 | Jenn-Air Kitchen Ranges
The blower won't turn off on the grill side of the stove. I changed the switch but the blower stays on.
Since I don't know your model number, I will have to give you deneric advise. Some fans have a thermostat that will activate the fan when certain temperatures are met. If yours is like that, then the thermostat could be the cause.
Jul 05, 2011 | Jenn-Air Cooktops
Where can I get Ignitors for my gas grill Jenn Air model 729-0163 ?
If you purchased your Jenn Air grill from Lowe's, it's not really a Jenn Air. Lowe's bought the rights to use the name and place it on the grill. This grill was made exclusively for Lowe's The grill is made by NEX Grill Corp. You can find them on line by doing a Google search. If it is in fact, a true Jenn Air Grill, any appliance dealer that sells Jenn Air kitchen appliances can help you obtain them through their parts dept..
Jan 30, 2011 | Grilling
Jenn-Air SVD48600B grill burners have gotten weaker over time (seems like low flow of gas) and not the back will stay lit and cook but the front flicker on and off but not stay lit on its own. What is the...
do you have any carbon built up in the holes of the burners if so these would need to be cleaned every single small hole on the burner needs to be able to have a clear opening for the gas to travel out of? Message me back if the burners are cleaned and there is no carbon build up on the under side in this case you may have to make an adjustment to your gas valve Thanks again Rick
Jan 09, 2011 | Jenn-Air Kitchen Ranges
I have Jenn-air gas grill, model no. 720-0336, the back burner that we use for the Rotisserie does not stay lit. Once started it will run for three minutes or so the you'll hear a pop...flame goes...
The tube to the third burner or the burner itself is clogged. Spiders are the usual suspects. Unhook them and clean out with circular brush or compressed air.
Please rate my answer 4 stars if it helps.
Good luck,
Oct 24, 2017 | Garden
Jenn Air Built in Four Burner Grill
Replace the regulator that should do it
Aug 01, 2010 | Jenn-Air JLG7130A
How do I adjust the flame to burn hotter or more.
There are adjustment screw at the end of the burner tubes that allow more or less air to enter the burners. try opening or closing these screws
Jun 01, 2009 | Jenn-Air JLG7130A
Jenn-Air S136 Grill-Range--auto clean not working
Selector to Clean
Temperature to Clean
Move lock lever to the right
Press the enter button Twice
Mar 19, 2009 | Jenn-Air JES9860 Electric Kitchen Range
Users Manual & Warranty Information 720-0163
Hi phvieth,
I am in the same boat. My Jenn-Air 720-0163 lit itself on fire and I need to find replacement valve seals and a manual.
Jan 04, 2009 | Amana 5939 Grill
Jenn-Air element won't shut off
most likely its a faulty switch, not completly shutting down trickling power out.
Mar 15, 2008 | Cooktops
Grilling Logo
330 people viewed this question
Top Jenn-Air Grilling Experts
Gary Kenady
Gary Kenady
Paul Carew
Dan Webster
Dan Webster
Are you a Jenn-Air Grilling Expert? Answer questions, earn points and help others
