Question about Ridgid 9 Gallon Wet/Dry Shop Vac 96882 Canister Vacuum
Motor while using my shop vac it started to smoke then it smeled like an electrical fire,inedd to find the motor/blower
Im here in philippines please post certain local dealer of vacuum cleaner rigid brand for as a reference in purchasing.i need a power motor for model:wd1665ex0.
Posted on Oct 09, 2008
    Problem Solver:
  • 15 Answers
Replace the motor... if you live in canada, go to canadian tire or part source they'll have what oyu need to fix it.
Posted on Jun 24, 2008
How to use Shop Vac 85L450 exhaust as blower
Unlike the old days few vacs today have a blower facility.
In the old days many vacs used a single exhaust port the hose could fit into for blowing and in particular using some of the supplied accessories - such as the famous spray gun loved and hated by everyone in equal measure.
Modern vacs tend to have a diffused exhaust usually through several ports, perhaps because of imagined safety concerns. I suggest you check the operator instructions.
Jun 24, 2014 | Shop Vac Vacuums
My new shop vac is smoking and smells like electrical fire. Any suggestions? Should I just take it back to the store?
Hi. ABSOLUTELY return it. It has an internal electrical issue which may cause a fire. Return it ASAP!! J.
Aug 09, 2010 | Ridgid 9 Gallon Wet/Dry Shop Vac 96882...
Hoover steam vac smoking
Your problem sounds electrical in nature. I would take it in for evaluation / estimate of service.
Apr 22, 2010 | Hoover SteamVac Carpet/Upholstery Deep...
Hoover u5781-900, motor shuts off (intermittent)when you shake vac or make jerky movements.If you move vac to up right position the vac starts right up.When you giggle vac, motor starts and stops no mater...
lucy
you have a bad connection somewhere in the unit
this is a fire hazard and you should not use this until its been fixed
could be a pinched wire or broken connections
Oct 03, 2009 | Vacuums
Solution for "the unit is making smoke rubber belt smell how do i change the belt...hoover steam vac f7225-900
there is no belt on this model. From your description, it is definitely electrical, possibly the motor. I would have it looked at a repair shop.
Mar 15, 2009 | Hoover F7225-900 SteamVac V2 Upright...
Vacuum plugged in but not on, smoke started coming from the motor
The motor winding burned out. Perhaps the motor was very hot when the vac was turned off after the last use and the insulation of the motor windings broke down when the air stopped moving thought the unit. Perhaps also the polarity of the receptacle it was plugged into is reversed or the plug on the vacuum is not polarized. Those things in combination could cause this but this is kind of a long shot guess. In any case the blower motor is likely burned out and will need to be replaced and checked out.
Jan 18, 2009 | Eureka Altima Upright Vacuum Model 2996AVS...
Shop vac 90L400 stopped working won't start
I had the same problem with the same model. Turned out to be the thermal fuse on the motor housing, between the switch and the windings. Took it apart and replaced the melted solder with 14 guage copper wire. Works fine! No thermal protection but I don't use it for long at a time anyway. Check the switch for continuity, if good then check the thermal fuse for continuity. If good, it's the motor.
Oct 19, 2008 | Shop Vac 925-13 Canister Wet/Dry Vacuum
Shop Vac just stopped
If you remove the motor, you will see that the wires that go from the switch to the brushes. On one side there is one wire connected directly to the brush. On the other side the wire goes to a plastic plug with a second wire going to the brush. This is probably where the problem is. This is a fusible link and it has most likely melted creating an open in the circuit. I put a piece of solder where the link was and the motor ran BUT the brushed arced like a sparkler. Upon further examination the brushes were crumbling apart. I have been unable to find replacement brushes.
This machine has a five year warranty. I called Shop Vac Customer Service 1-888-822-4644 and they sent me a new motor.
I had a Shop Vac QL50EIC which had exactly the same problem but the warranty was expired so that I had to buy another motor for about $50.
Mar 08, 2008 | Shop Vac 285-00-10 Back Pack Vac Wearable...
Ridgid 9 Gallon Wet/Dry Shop Vac 96882 Canister Vacuum Logo
554 people viewed this question
Top Ridgid Vacuums Experts
Dan
Level 1 Expert
ken skalski
Are you a Ridgid Vacuum Expert? Answer questions, earn points and help others
