Vauxhall astra radio keeps switching on and off on its own
  • 1 more comment
  • tony567 Nov 15, 2008
    Even with the ignition off and the vehicle unoccupied,the CD player for no apparent reason is convinced a cd has been loaded and tries to read it. When it can't, it shows "error cd" and after a few seconds defaults to the radio. I'm returning the car in the morning to find that the radio has been playing away to itself all night ! Tried cleaning the cd and tried other options in the set-up menu but unable to cure it.
  • AstraSteve Dec 14, 2008
    Same here. Radio will give a CD read error and switch itself on randomly. Hey presto! Flat battery in the morning. Did anyone find a fix for this?
  • montagu Feb 28, 2009
    Me too. I've removed the radio. But I've heard that the cheapest solution is to keep a CD in the radio at all times. I'm gonna refit the radio tomorrow to give it a go. I have yet to find out whether this technical problem can actually be fixed. Certainly my local Vauxhall dealer - who acknowledged it was a common fault - only offered to replace it for a re-condition unit for £200!
I had this problem for the last 2 weeks, didn't think much of it, but recently the car radio just turned on and off by itself, it decided to do so whilst the car was switched off and it drained my battery. After doing some tests with the Amp meter and removing the fuses for the radio and infotainment system the amps going through the batter went from about 0.7 to 0.001 (far more accpetable) - so the radio was draining the battery and randomly turning itself on/changing stations and the internal display system had stopped working.
after putting the fuses back in and re-testing the radio worked fine (almost like it had a full reset - no random turning on and off OR changing of radio stations)
the fuse box for my astra was next to the battery under the bonnet (see your car manual - I had lost mine so googled for it)
http://pdfcast.org/pdf/2006-vauxhall-astra-owners-manual-operation-safety-and-maintenance
PAGE (267 or 265)
but it seems yanking the fuses for the radio (FUSE number 35 and 36) seemed to fix it (been a few days and no flat battery) -
It maybe an intermitent fault, in which case i'll have it looked into, but as garages charge an arm and a leg i'd give this solution a go and if your battery is good all you need to do is remove the fuses and put them back after say a minute or so)
Posted on Jan 15, 2011
I too have an astray mk5 fitted with a cd30 which kept switching on... sometimes it would change from radio to cd by itself I removed it from the car and removed the casing I then found the rotary disc switch at the top of the CD mech was carefully dismantled and cleaned .... a little silicon grease on the contacts reassembled refitted and fault now cleared...
Posted on Oct 11, 2013
I have a Vauxhall 1.6 Astra, and the radio keep switching stations, have tried retunning all stations, but it still does it, funny thing is I took my car to Vauxhall yesterday because one of the gearbox mount bolts fell out and, asked them to check the radio, they told me they did a test drive and the radio was fine, yet I drove out of the garage turned left into the next road less than 100 yards and the radio changed station for no reason.
Posted on Mar 24, 2010
Vauxhall astra radio problems
If it won't switch to AUX then you'd better get back to that nice car man who sold you this lovely car.
Jan 08, 2014 | Audio Players & Recorders
My Sony radio XDR-S55DAB has completely stopped working. Initially all that showed on the display unit was the symbol for a dead battery but this also appeared when it was mains connected. I have pressed...
I have noticed exactly the same issue with my Sony XDR-S55DAB
Even if it has batteries installed but only working off mains electricity, after several months it will not start when the power button is pressed and I have to replace the batteries.
The radio will work again if you just replace the batteries with fresh ones
Try this next time the batteries go flat; disconnect the radio from the mains, replace the batteries with fresh ones, and leave for a couple of minutes (you do not have to switch on!).
You can remove the batteries if you like then reconnect the mains cable and press ON
If your radio behaves exactly the same as mine, it will spring into life so how come?
In the "olden days" ie pre-2000, small portable radios often had a physical switch which connected and disconnected the power supply be it battery or mains.
Nowadays, many radios don't have a "proper" switch, but a "function" button - press it on, and the radio operates, press it again and the radio stops - to enable this, a very small amount of charge is required to keep the central "brain" alive in order to notice this, and in the case of the Sony XDR-S55DAB, this only seems to be supplied by the battery, not the mains adapter.
My advice is simply keep a spare set of batteries handy and replace them whenever your radio wont turn on. Using the mains adapter allows the batteries to lastfar longer than using the batteries on their own.
It is completely counter-intuitive that a "battery/mains" radio needs batteries to work off the mains, but this is the only design fault can find in an otherwise excellent radio.
Aug 15, 2013 | Audio Players & Recorders
Radio time clock will not set even when switched off for days.
Please sepccify in detail if you meant that the clock does not set after few days or does not set at all. If so check if the standy +B is wired to be ON to keep the memory on hold.
Also specify the make/model.
Jul 23, 2011 | Audio Players & Recorders
Sheerwood rv4080 r receiver /online manual
I think you might have a failure of a memory retention capacitor. These are small odd looking capacitors that store voltage for memory chips.
Look for something like this:
Feb 26, 2010 | Sherwood RV-4080R
How do I enter the code for my Blaupunkt 6 Disc cd changer in my 98 Vectra?
Switch off radio, press and hold cd selection button, switch on radio, wait for CODE ---- to appear, enter code [same maner as radio], press cd selection button and wait for beep. Job done.
Jul 20, 2008 | Audio Players & Recorders
Siemans NCDC 2015 Car Radio/Sat Nav/Telephone/ CD player
Heres a question....does the main power switch "feel" like the others.
The main power switch is one of those that gets a workout. After looking at some images, I am going to guess that it is what is called a "Tac" ( short for tactile ) switch.
How do you tell if it feels right?.....go to the least used switch on the unit ( is should theoretically be like new if it is the least used ) ,and very slowly push it in. What do you feel?....some resistance and then it gives?.....do you hear a slight snap ( make sure the unit is off or the volume is all the way down ). Now go to the power switch....does it feel the same ? A sign that ths switch is finished is that there is no travel to it, that is, when you push is it stops immediately....the least used switch should have a little "room" in it before it hits bottom and makes the connection.....I'll bet the switch is shot.......give it a go......Thanks..Rob
If you can feel a big difference in the switches, then I would take it to a local electronics shop and see it they can replace the switch ( those type of tac switches are EVERYWHERE ), or maybe find a seimens shop and have them look at it.....better than 1500 !!!!
Mar 13, 2008 | Audio Players & Recorders
Car audio
Can't really help without seeing the item - but I know it is very difficult to fit a 'different' radio to cars nowadays as they are all 'cutom-built' just to fit their vehicle.
What do you mean ' the wiring is too large at rear of unit ' ?#
Is this the radio itself you mean - what wiring is at the rear of the JVC KD G431?
Mar 11, 2008 | Audio Players & Recorders
Hi I have a blaupunkt car 300 radio cassette in my vauxhall and I have lost the code,I tried to get the code from a local repair shop he gave me 2 codes none of them worked and now the tries left are down...
look up eBay member acecar18 for any radio codes and other stuff it cost me £1.50 and was done from the serial number in less than 10 minutes, this guy knows his stuff and hes cheap!!!!
Mar 04, 2008 | Audio Players & Recorders
2,623 people viewed this question
 Grubhead
Grubhead
