Question about Creative Labs (70CF004000010) Keyboard
Creative Prodikeys Musical Keyboard PS/2 Plug broken
My Prodikeys PS/2 plug (Computer end) has totally come off and completely broken while pulling it out of PS/2 socket. Can I replace the cable with ususal PS/2 cables as the one in case of this keyboard has five cables instead of four in common keyboards?
  • Anonymous Mar 20, 2009
    Need PS 2 wiring color code for Prodikeys dm
    Problem Solver:
  • 8 Answers
You can replace, just get a usb cable that is equivalent. alot of times you can find a usb extension at a dollar store, eg deals, big lots etc. just use it
Posted on Apr 17, 2010
I acidently pulled the cord out and need to know what wires go where. plz help me out with pictures
is the keyboard a ps2 connection. The end of the plug will be purple for keyboard or green for mouse and the computer sockets have similar colors.
(Note ! there is a square plastic piece inside the plug it must match /align with the socket !!!! it is real easy to bend the pins if not aligned correctly be gentle iwhen inserting the plug )
https://en.wikipedia.org/wiki/PS/2_port
if it is usb cables then plug them into usb ports
https://en.wikipedia.org/wiki/USB
look for the usb symbol and have the usb symbol up on the plug when you plug it in.
Mar 26, 2016 | Computers & Internet
How do I connect the mouse?
212
i am assuming you have a usb mouse and a PS2 connection on the computer. If this is the case then you need a female usb to ps2 mouse adapter
So that the mouse cable plugs into the USB female connection and the male ps/2 plug end goes int othe female ps2 port on the computer.
If this is the case you have the wrong converter the chester will convert a ps/2 on the mouse or keyboard to a usb on the back of the computer.. Can you tell us what sort of mouse you are trying to connect does the end of the cable have a usb plug on it a bit like the blue usb plug in your picture.
Google it and see the difference.
Mar 12, 2015 | Chester Creek PS/2-USB Converter PS/2 to...
Inow how to install a power supla for a compac cuputer
>Unplug computer from wall outlet.
>Open side panel on case.
>Unplug all cables from your hard drive(s), DVD drive(s), and cooling fans. Also, the main motherboard power cable plugged into the motherboard; it's a wide plug with numerous cables coming out of it and will be a bit hard to unplug. Do not pull on the cables themselves, grasp the plastic plug and work it off the motherboard socket. There may also be a snap catch that you have to press while pulling.
>There are 4 screws on the rear of the computer that hold the power supply in place. back those out. Make sure the power supply doesn't just fall. Usually there is a small ledge that it rests on but no guarantee on that.
>Remove the PS. Usually they just slide out, but sometimes it is a bit tricky to free it from the case if the PS hits the rear of the DVD drive; you just have to work with it.
>Slide in the new PS, mount it with the screws and replug all the cables. If you arent't sure, label the cable plugs and where they go with bits of masking tape, it will help you remember which cable goes to which socket. Check on the rear of the new PS, there may be an on/off switch. If there is, turn it on. Do not get confused with the 120/240 USA/European converter switch! Leave it on 120v for American power.
More information:
http://www.suggest-a-fix.com/index.php?/topic/206-home-building-and-testing-techniques/
May 18, 2014 | Compaq Computers & Internet
Rj45 conector pug installation
RJ45 cables have a lock lever, which you need to press before pulling the plug out of the socket. locate the lever, press it towards the socket (sometimes you need a screwdriver or similar), then you can pull the plug out.
Apr 24, 2014 | Acer Aspire M3400 PC Desktop
How to fix a broken earthernet port hole snap that click and snap the earther net cable in the socket
you can do several things.
  1. have the whole cable replaced
  2. remove the end of both connection and re-crimp the broken end, a computer shop can do it for you.
  3. if you are not in such a hurry, re plug the end again and tape it with the vga cable to hold it in place.
Sep 08, 2012 | Dell Latitude 110L Notebook
Need to kb\now how to change spark plugs on my 2001 sonata
Follow these steps on how to replace thespark plugs. 1. First, you turn off the Sonataengine and allow it to cool. This normally takes about 30 minutes. 2. Raise the hood and locate thespark plug cables along the side of the engine. Spark plug cables are normally1/4 to 1/2 inch thick and plug directly into the engine. 3. Grasp the cable by its boot.This is the thicker piece that covers the spark plug or spark plug well. Turnthe cable back and forth until the lock releases. Pull back on the cable toremove it. Complete the replacement process for each plug before moving on tothe next. Slide the socket, extension and wrench over the spark plug. Turn thewrench to the left to unscrew and remove the plug from the engine. Spark plugsockets have a cushion inside that grab the end of the plug to hold it inplace. 4. Clean the well and boot withthe wire brush. Do not rub hard on the well or boot or it will cause damage.Spray silicon in the boot and on the spark plug threads, so you can easilyremove the spark plug the next time. 5. Insert the socket into the welland gently thread it into the engine. Test the tension with the tester. Thetension a spark plug needs varies by plug manufacturer. Check the package tofind the correct tension. If you need more tension, tighten the spark plug. Forless, loosen or unscrew the plug. 6. Place the cable back onto thespark plug. Repeat Steps 2 through 7 for the other plugs. Work your way downone side of the engine and then down the other as you replace or clean thespark plugs. This are the things you need for the job, 16mm spark plug socket,Socket wrench with extension, Wire brush, Silicon spray, New spark plug,Tension tester
Jan 10, 2011 | 2001 Hyundai Sonata
Driver for PS/2 compatible mouse for tower PC HP compaq dx7300 were not found and not installed in my PC.
PS/2 compatible mouse drivers are generic drivers already install when the Operating System to your PC. You don't need any extra PS/2 drivers!! "
Check your mousePS/2 pins & PS/2 socket -> Pins..Dented..Broken?
Mouse could be faulty. Try replacing another PS/2 mouse to your PC.
If the PS/2 socket is faulty, you can use a USB mouse too.
Hope it helps.
"Courtesy is free but it will carry you forward a long way in a lifetime!"
Nov 07, 2010 | Computers & Internet
Right turn signal socket needs replaced. 1998 Intrigue
Hi Mdelah
That is a very quick and easy fix. I believe you may suffer the constant blowing of your signal light right? (I had it so bad that at some point they would break the same day)
Here the good news you do not need to buy them from GM directly at the cost of 80 dollars plus. You will need to find an ACDelco LS115 Socket at any Lordco or other Car Part shop. That should cost around 30 dollars.
The replacing of this is very straight forward. There are two slats on the back of your headlight (white) which clamp the light to the frame. All you do is pull these up and remove them from the pins they are on and pull the whole headlight assembly out. (total of 15 second deal)
Then take the plastic cover of the signal light bay rotate the signal light socket to the left and pull carefully. Pull out the Bulb (if you need it and it works) then remove the little plug on the other end of the socket (the plug with the cables for power to the socket) and attach it to the new socket. Insert bulb place headlight assembly in place the white slats back on the pins and clamp the headlight assembly back to the frame...
Total time for that procedure should be 50 seconds ;) and you won't have to pay a mechanic for that.
Oct 24, 2010 | 1998 Oldsmobile Intrigue
The dc power plug is broken
Yes.
Is the connector on the power adapter that plugs into the laptop?
If so, this is an easy repair, purchase a new connector from electronics parts shop, cut off the old connector and solder the new one on the end of the cable. MAKE SURE YOU SOLDER THE CONNECTIONS TO GIVE THE CORRECT POLARITY ON THE CONNECTOR, OR YOU WILL DAMAGE THE LAPTOP.
If the power socket on the laptop is faulty, this repair is more difficult. The socket may only need resoldering on the motherboard or in the worst case a new socket replacement. Either way the laptop need to be dismantled to get at the power socket.
If you don't feel you can handle this, get it done by a computer repair shop or a techo friend.
May 28, 2009 | Computers & Internet
SD400 broken screen
found this guide on the net once, try it out and let us know what you think: " WARNING: this repair voids your warranty and may damage your camera. Perform at your own risk. The publisher of this site is not responsible for any damage you cause. This replacement is of medium difficulty. If you have ever ?built? a computer from parts, you are probably capable of it. If you are patient, orderly, and meticulous, you can probably do it. But you do risk breaking your camera even further, so don?t do it if you won?t accept that risk! Be carefully that you are grounded and thus do not harm the camera via static discharge. Google the terms ?grounding? and ?static discharge? if you need more info. I only performed this operation on a Canon SD300 / Ixus 40, but readers have reported that it is the same on the SD200 / Ixus 30 and on the SD400 / Ixus 50. Read all of the instructions before proceeding. Within each step, I don?t necessarily use exact chronological order. Tools: a small Phillips head screwdriver and a smaller flathead screwdriver (used for prying). Step 1. Ascertain what is broken. Symptom: your screen still glows with light, but shows crazy colors or a visible crack surrounded by crazy colors. Problem: your LCD screen is broken but your backlight still works. You need only purchase a new LCD screen. Symptom: your LCD does not glow. Problem: your backlight is probably broken. This didn?t happen to me, so I don?t give any further advice about this problem on this page. However, the information on this page will take you about 60% of the way to replacing the backlight as well, so it may be useful. Step 2. Order a replacement screen. UK: H. Lehmann's Ltd: +44 (0)1782 413 611 at a cost of 33 GBP (including shipping) US: Canon? +1 732 521 7230 / +1 800-828-4040 at a cost of around 66$ (including shipping) The part number for the SD-300 / Ixus 40 LCD screen (without backlight) is: ck9-1103 The part number is the same in the US & UK. I do not know whether the SD-200 / Ixus 30 LCD / SD-400 / Ixus 50 LCD part number is the same.. Step 3. Open the camera - Remove 6 screws in total: 2 from the left side, 2 from the right side, and 2 from the bottom. - Gently pry open the case - The plate covering the ?grommet? to which you attach the strap will fall off. So will the round grommet. Don?t worry about it. Step 4. Remove the screen & backlight assembly from the back of the camera - Remove the screw from the upper right corner of the backlight/LCD package. Note: this screw is of different size to those you have already removed. Keep it separate. - Be careful of the tongue extending from the bottom right corner of the backlight/LCD package. It?s very tiny and easy to miss. You want to be sure to slide it out, because it?s easy to just break the plastic into which the tongue slides. (I did. Not a huge crisis, but I wish I hadn?t!) - There is a tab on the left side of the backlight/LCD package. Pull it back slightly so you can lift the backlight/LCD package. (I used the flathead screwdriver to pry it off.) - You should now be able to lift up the backlight/LCD package. It will still be connected to the camera body via two ribbon cables. Step 5. Separate the LCD from the backlight - There are a number of fiddly plastic/metal tabs holding the two together. Just gently pry and poke until you have separated them. It?s a bit time consuming, but I can?t really give better instructions than these. - You should be left with the LCD totally separate from the backlight, but still connected to the camera via a ribbon cable. - The backlight should also remain connected to the camera via a ribbon cable. Step 6. Undo the LCD ribbon cable - The LCD ribbon cable extends under the bottom of the camera (actually passing under the tripod screw hole, which cannot be removed). It re-appears in the front of the camera and is connected to a socket. The socket is rather like a DIMM socket on a computer. It has a flat, black, clasp which is folded down to hold the ribbon cable in the socket. - Examine carefully the way the ribbon cable is attached to the socket. Note that it is pushed in entirely, so that the wider part of the cable (with two holes at either side of it) is flush against the socket. - GENTLY lift the clasp (I used the flathead screwdriver). It should swivel up and the ribbon cable should fall out. DO NOT YET PULL THE RIBBON OUT OF THE CAMERA. Step 7. Totally remove the LCD - Tape a long, narrow strip of paper to the end of the ribbon cable. This paper is to help you thread the ribbon cable of the new LCD back through the inside of the camera. - Note how the ribbon cable is threaded under the tripod mount to the front of the camera. Wiggle it around a bit, get a feel for it. Sliding the new one back through is a bit tough, so experiment with how this one fits and where it goes. - Gently pull the ribbon cable out from under the tripod mount, leaving the broken LCD screen now completely detached from the camera. Make sure to leave the paper threaded through the camera so that you can tape it to the new LCD?s ribbon cable and pull that one back through. - If you messed up with the paper, don?t worry. You can still push the new ribbon cable through: it just takes some wriggling and some time! Finishing. - You have now got to go through the process in reverse, installing the new LCD screen. - Threading the LCD ribbon cable back under the tripod mounting screw is tough. Just keep sliding it back and forth and exert pressure to push it through. It will go through, eventually. - As you connect the LCD ribbon cable, read the ?white screen? problem below, so that you do not suffer from it! FAQ 1. My screen just shows white or gray. (E.g. white screen, white display). What did I do wrong? A. The ribbon cable that connects the LCD to the circuit board was not inserted deeply enough. The end of the ribbon cable has a narrow portion, then a very small much wider portion with two holes at either end, then it narrows again. The very tip should be inserted into the "socket" deeply enough that the wider portion is pressed right up against the "socket." Physically, it cannot be inserted more deeply. It may help you to use two wooden or plastic toothpicks, one in each of the small holes at the end of the cable, to push the cable into the socket." If you feel like supporting the author of this thread, go to his website through this link: http://www.cl.cam.ac.uk/~jo262/broken_lcd_cracked_screen_canon_sd-300_sd-200_ixus-40_ixus-30.html Good luck
May 18, 2006 | Canon PowerShot SD400 / IXUS 50 Digital...
Creative Labs (70CF004000010) Keyboard Logo
334 people viewed this question
Top Creative Labs Computers & Internet Experts
micky dee
kevinmacleod
Level 1 Expert
Are you a Creative Labs Computer and Internet Expert? Answer questions, earn points and help others
