I am using ultra mon and have a dual monitor set up with 2 dell 1707FP monitors, for some reason when these monitors go into standby only one of them will "wake up" and the other stays in standby. How do I stop this happening so that both screens "wake up" when the mouse or keyboard is activated?
It seems the problem was with the graphics card -NVIDIA FX550 - this was changed with a known good and the problem no longer appears.
Posted on Jun 25, 2008
How do I connect dell ultra sharp 24 dual monitors to dell 9020 mini tower
At the back of the unit you will see a graphics card output. If you only have one then you will need to buy a second one to utilise a second monitor. You will need 2 DVI outputs to run this kind of setup.
Mar 05, 2015 | Dell OptiPlex 9020 Desktop Computer -...
Dual monitor vs Large monitor?
Or go through this page and see.
Whether it's helpful to you or not?All the Best!
Thanks for using FixYa.
Apr 26, 2012 | Dell Optiplex GX520 (GX520 2.8) PC Desktop
It is a Dell monitor, Model 1707FP. The screen went black and the power button is blinking. It does not make a difference whether I disconnect the video cable or connect it to another computer. What are...
http://s807.photobucket.com/albums/yy352/budm/Dell%201707FP%20Rev%20A01/
Check for bad caps first.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you
http://www.badcaps.net
Replacement board:
http://www.lcdrepair.us
Aug 12, 2010 | Dell UltraSharp 1707FP 17" LCD Monitor
Power button damange ,
I used two thin putty knives this morning to open the monitor case. First, unscrew the four screws at the back. Then insert a putty knife into the small crack between the front bezel and the monitor shell. Carefully work you way around and wiggle the putty knives. Note that the front buttons are attached to the thin black edge at the front, and there's a thin cable at the bottom. Don't damage that. You can take off the back shell though.
Sep 09, 2009 | Dell UltraSharp 1707FP Monitor
Power on/off button not working on Dell 17 in. Ultrasharp 1707FP
hi. probably de botton is damage or broken. if you have experience opening electronic devices like monitor you can replace that button you can purchase online. depending on the type of button, you can see a full tipe of button here: https://www.sparkfun.com/categories/145?page=all
Sep 16, 2017 | Dell UltraSharp 1707FP Monitor
Dual monitors can't extend desktop
Connecting Two Monitors
Use the cable adapter to connect a VGA monitor and a DVI monitor to the DVI-I connector on the back panel.
When you connect two monitors, the video driver will detect this connection and activate the multimonitor functionality.
This is the only way to enable extended display. If you use a standard splitter and connect two DVI montors, the display will only be mirrored.
Detailed documentation is available at http://support.dell.com/support/edocs/systems/op755/en/UG/HTML/ultrasma.htm
Hope this helps! Please rate your feedback!
Mar 02, 2009 | Dell Optiplex 755 Ultra Small Form Factor...
Dell 151fp is slow to get going, fine otherwise
You dell e151fp lcd monitor may have a bad/weak capacitor on power section(primary and secondary). Just change the buldge capacitor and use the Dick Smith ESR Meter to check the capacitor esr value. If you not sure all the above, you may go to this site to get the list of bad component on dell e151fp lcd monitor. Please visit here http://www.fastrepairguide.com/monitor-and-lcd-monitor-problem-solutions/repair-dell-e151fp-lcd-monitor-with-symptom-no.html
Sep 08, 2007 | Dell E151FP 15" Flat Panel LCD Monitor
Computers & Internet Logo
105 people viewed this question
David Payne
David Payne
