Question about Panasonic KX-TA308 Phone
Incoming call to one extension only at night
I have a KX-TA308. When it is set to "night" (782#) I want one of the extensions (where the fax is located) to receive all calls (faxes) coming from one of the three outside lines. My dealer in Argentina sold me the KX-TA308 (brand new) with no owner's manual, CD-Rom or anything and he doesn't have a clue. I know it should be simple but... how? Thanks a LOT!
Etienne van Dam - evd@fibertel.com.ar
  • Panasonic Master
  • 2,460 Answers
Answered elsewhere, but night ring is programmed in system option 409.
Carl
Posted on Sep 13, 2008
  • Mikrobi Apr 28, 2011
    We have a similar problem. The incoming calls are transferred to the extension where the voicemail is located, too fast. How can I set the nr. of the ringing before transferring the call to at least 5?
KX TA308 how to disable 2 locals Ring sametime
There are two possibilities, you have to check to confirm. Either the two were physically wired in parallel or through programming they were configured to ring simultaneously. Start by checking if the two were physically wired in parallel. One way would be to establish how many extensions you have altogether and is it equal or less than the total number of extension ports available on the KX-TA308?
Apr 03, 2014 | Panasonic KX-TA308 Phone
I CAN'T SEND FAX WITH EXTENSION NUMBER
Generally if you wanted to send a fax to a facsimile which is connected to an extension.you must dial only the direct line number and ask operator to transfer this call to fax (wanted extension).After you heard the fax tone you can push start button.
If the fax machine full-time connected to same extension & dedicated direct-line there only for faxing,we can program the pbx for automatically transfer the incoming fax or call to that extension.so outsider have to dial only direct fax number without ext no.
Only Panasonic PBXes having a unique feature if i'm wright if it detect fax tone from any direct line it will automatically transfers towards fax extension.
Mar 24, 2014 | Panasonic KX-FL611 Plain Paper Laser Fax
Hi, Can you help me my problem. I Need programming manual for KX-ta308. Specially for the restriction of outgoing calls on local extensions. Already downloaded a manual but cannot find outgoing...
Under alphabetic FEATURES, look at TRS (Toll Restriction) and COS (Class Of Service). It explains the concept of call restriction and how to program it.
We have a different 308 in the US, one that was built on a 624 platform, so a 624 features set will work, it just has a smaller number of lines :-)
Carl
Jan 31, 2011 | Panasonic KX-TA308 Phone
Hi would like to know how to set an extension not to ring when any of the co lines is ringing since i have a fax machine connected to this extension and it is programmed to answer automatically
Ringing for each extension and line is done in Panasonic system programming commands 408-410 for Day/Night/Lunch. You turn off ringing for all lines to your fax extension and then just turn on one line for that phone.
Be sure to turn off or delay the fax line ringing to all the other extensions at the same time.
Carl
Nov 03, 2010 | Panasonic KX-TA308 Phone
How to program the extension rings when incoming
you have to go to adreess 408 day 409 night 410 lunch
in each one get enable and desable if you dont want ring
remember to do in each line too
Jul 08, 2010 | Panasonic KX-TA308 Phone
I can ring out on phone but the phone or base wont ring on incoming calls night mode is not on and all the volumes are turned up
It sounds like you don't have it programmed to ring. The volume controls the sound, but programming controls the ringing. Try night mode (782 from extension 101) to put it into night and test again, or check out the sytsem programming for ring modes.
Carl
May 06, 2010 | Panasonic KX-T7730 Corded Phone
KX-T7730 Picking up Problem
You are on the right track but the extension number is not " 0 ". There is an extension number associated with the operator phone just as your phone may be " Extension 101". If you have a display phone have the operator call you and look at your display for her/his extension number then when their phone is ringing, pick up your handset, dial 4 plus the extension number of the operator. Let me know how it works out. .....Mitelmike
Nov 18, 2008 | Panasonic KX-TA308 Phone
I want to pick up incoming calls from another extension
Yours may be different if your TA-308 is not a U.S. version, but the family is generally 40 picks up all calls in your group and 4+the ringing extension will pick it up. Just in case they have call pickup deny set (721) you'd have to cancel it with 720.
Carl
Panasonic KX-TA308 Phone Logo
248 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
