Question about Magellan Maestro 4000 Handheld GPS Receiver
Magellan maestro 3100
6 month old gps should be fully charged, but will not turn on anymore
    President:
  • 1,111 Answers
Hi ksayenga
this is a very common problem with your model gps
the following advice pertains to the following magellan gps systems.
Magellan 800, 860, 2000, 2200t, 2500, 3000, 3050, 3100, 3140, 4000, 4040, 4050, 5310 and 6000t
i fix these and many other magellan gps daily so when considering my advice , please understand i do not google my solutions.
assuming your car charger is working (the little green light is on) and your magellan still wont start up after holding the power button while its plugged in for up to ten seconds and still does not start..read below
this is actually a very common problem with these magellan power ports...they are poor quality from the factory and always and i mean always fail..the new ports that you find on ebay are 100% better then the factory port.
if your able to replace that power port yourself, you can get one HERE, if not, ask the fellow that sells them for help.
due to some dubious "experts" on fixya, im not permitted to help you directly, but please follow the link above to get further help.
let me know if you need more help or info
Bill
Standing Member of G.O.T.
Posted on Feb 10, 2011
My gps wont charge anymore where can i repair it
if you have the 3100 or similar and verified its not charging in the system tab, you can get it repaired HERE or just the part (you need the power port)
if you need further help, just post back to me here and ill help you further.
bill
May 15, 2010 | Magellan MAESTRO 3100 98083401 GPS Device
My Magellan Maestro 31100 won't power on
You could have a defective power connection in your Magellan Maestro 3100 which will not allow you to charge the internal battery or power on your unit.
You may try to contact Magellangps.com or Autonav2000.com to see if they can provide you with repair service.
Might be cheaper to purhcase another Magellan Maestro than spend the money on repairs.
Good Luck
Apr 03, 2010 | Magellan MAESTRO 3100 98083401 GPS Device
My Magellan Maestro 3100 GPS unit won't charge anymore. I've seen 2 possible explanations for this problem. #1: The DC power port is broken #2: The battery won't hold a charge any longer How do I determine...
if it starts, you can verifiy if its charging by going to the system settings then power options. the green indicator should be moving left to right. this indicates its charging.
if you disconnect the battery, your magellan should still work while plugged in if the power port is ok.
this is very common problem with this and many model magellans.
try the car charger.
make sure green light is on the car charger and let it plugged in for awhile, then hold the power button (up to ten seconds) until it starts..if that fails
the following magellan 2000, 2200t, 2500, 3000, 3100, 3140, 4000, 4040, 4050 and the 6000 are known to have faulty dc connectors...if your magellan gps is not charging or will not power up, its most likely the dc power port...
you can get it repaired, here
or buy the port here
if you need further help, just let me know.
Oct 15, 2009 | Magellan MAESTRO 3100 98083401 GPS Device
Hi My Magellan Maestro powers up with the Magellan screen and the bar scrolls but thats all it does? Carl Lucas Aberdeen MD
i just replied to a fellow with the same problem and since your problem is same, ill post what i wrote him/her but try a hard reset 1st..turn the gps on then locate the little pin hole on the side, using a paper clip, push reset....if that fails, try the 2.18 update if you havent already.
updates for any magellan can be found HERE
but read below first before getting the update
i cant stress enough that patients is a must here. this update is huge 1.75GB
follow the instructions below whether you have updated your gps already or not!
There are few ways to solve this problem. i assume you installed the 2.18 update for the 3100 and assuming you tried the reset already, try and run the update again and follow the directions to the letter..make sure the battery is fully charged (i also keep mine plugged in if the update doesnt say not to) and do not try and run the update across a network. this update is huge 1.75GB and can take an hour or so depending on the computer..do not interrupt the update process. if you do not have the 2.18 update read me file, i can try and post it here, but its in PDF and dont think i can post that
if all else fails, magellan will fix or replace for free any of there gps that were rendered inoperable due to one of there updates.
either solution will work but magellans going to tell you to run the update again anyway before sending it back.
i gave you the 2 easyest ways to fix it,but
there are other ways to get it running again, but if your not comfortable copying and moving files...youll make it even worst then it is.
hope this helps.
bill
Comments: Jul 19, 2009 - here are a few key points, but read the full update guide before trying the update again.
hope this helps
NOTE: This update is COMPATIBLE ONLY with Windows® XP.
Before Beginning:
Check to make sure you have everything required for updating your unit:
• Magellan Maestro 3100 GPS
• PC running Windows XP
• A Blank SD memory card (16 MB to 2GB)
• USB cable
• Paper clip or similar object (for resetting your unit)
EACH OF THE FOLLOWING POINTS IS CRITICAL TO THE UPDATE PROCESS
1) The battery of your Maestro 3100 must be fully charged before beginning the update.
NOTE: It takes between 3 and 4 hours to fully charge the battery with your vehicle power adapter. Check System Settings to ensure the battery is fully charged.
2) Your Address Book will be erased during the process. Please back up your data to an SD memory card.
a. Insert a blank SD memory card
b. Select User Options
c. Select Backup and Restore
d. Select Yes to confirm
3) Do not connect your Maestro 3100 to your PC until instructed to do so by the Update Wizard.
4) Close all other applications while performing the update.
5) Disconnect all Pocket PC devices from the USB ports on your PC.
6) Insert a blank SD card (16 MB to 2GB) into your Maestro 3100.
7) Perform a hard reset on your Maestro 3100 by pressing a paper clip or similar object into the hole marked reset.
Update Process:
1) Launch the Magellan_Maestro_3100_2_18.exe file.
2) Select Next on the Welcome screen.
3) Turn on your Magellan Maestro and connect the USB cable.
Aug 03, 2009 | Magellan MAESTRO 3100 98083401 GPS Device
Gps will not turn on
make sure green light is on the car charger and let it plugged in for awhile, then hold the power button (upto ten seconds) until it starts..if that fails
the following magellan 2000,2200t,2500,3000,3100,3140,4000 and the 4050 are known to have faulty dc connectors...if your magellan gps is not charging or will not power up, its most likely the dc power port...i sell these power ports and will repair them for anyone thats not able to do it them selves
you can email me through here or email to.... wmetz@comcast.net
Jul 18, 2009 | Magellan MAESTRO 3100 98083401 GPS Device
Magellan maestro 3100 frozen on blue screen tried power on and off and reset button still frozen black bar at bottom of scren stays on blue screen
hope this helps.
bill
hope this helps
Before Beginning:
• USB cable
Update Process:
Jul 14, 2009 | Magellan MAESTRO 3100 98083401 GPS Device
Magellan maestro screen not coming on
if you have a 3100 or 3140 as you have pictured..they cant be charged via USB..you need a home or car charger
May 10, 2009 | Magellan MAESTRO 3100 98083401 GPS Device
My magellan maestro 3100 won't stay powered on
If the battery is fully charged then press the RESET button.
Jan 20, 2009 | Magellan MAESTRO 3100 98083401 GPS Device
Magellan maestro 3100 turns itself off
Try using the RESET button . Make sure the battery is holding its charge
GPS
change the battery or at leasst make sure its fully charged
Jul 01, 2008 | Magellan MAESTRO 3100 98083401 GPS Device
Magellan Maestro 4000 Handheld GPS Receiver Logo
87 people viewed this question
Top Magellan GPS Experts
Jungle Ghost
Jungle Ghost
Mike Cairns
Mike Cairns
Are you a Magellan GPS Expert? Answer questions, earn points and help others
