Question about Nakamichi Audio Players & Recorders
Nakamichi 680zx, no Naka Auto Azmuth control ?, should happer on its own.
Dear all Hi! I am a electronics engineer and I have Nakamichi 680ZX cassette deck, its FL indicators are not functioning. I had checked for both channels output signals on switch PCB. I had received audio signal on pin # 5 of IC 904 (RC4560D) on Indicator PCB C ***'y, further no signal on pin # 7 but (-)10 Volts DC with respect to ground, of the same IC. I would appreciate if you could guide me to rectify the problem. Please also note that I have complete full service manual for Nakamichi 680ZX. Best Regards Muhammad Ali Shah
Senior Manager Service & Technical Support
AVS, Lahore Pakistan
Cell # 0300-8859964
Posted on Aug 11, 2008
Subwoofers Power Cable and Speaker Connecting Cables
Nothing special about the original Nakamichi cables. Brochure here:
Nakamichi Soundspace 12
Jul 14, 2016 | Nakamichi SoundSpace 12 System
Why wont my Nakamichi 680ZX tape deck record
It is strange that people go to belts when that has nothing to do with the problem at hand. The probably cause can be a defective record enable switch or there have been some Nak decks that have a defective capacitor in the Bias oscillator circuit. The only way to find out is to do the troubleshooting that is necessary. It may need belts but that does not stop a unit from recording. The deck is playing so the problem is with the Bias oscillator turning on. I bet it does not erase either.
Jul 05, 2014 | Audio Players & Recorders
Nakamichi manuals
WHERE DO I HOOK UP MY SYSTEM NAKAMICHI NK5.
Jan 10, 2014 | Nakamichi New Original SOUNDSPACE11 Remote...
Naka 700ZXL- Intermittent Problem: After turning on the deck and at the same time the reel motor turns to eliminate tape slack one or more of the 15 lamps on the RAMM indicator panel turn on. If you...
from what is described of the lamps and the RAMM indicator the the negative 4.5 volt supply and the sometimes double spiked signal sound as though you have a weak regulator component or a voltage control circuit with a bad or weak component that needs replacement.
1. check electrolytic caps
2. all diodes/ resistance > all dropped/ no voltage in the voltage controlled circuit
3. trace voltage and current back to source to see if the supply is correct.\
If this is intermittent it means that a component or several components are growing weak and need replacement
4. a schematic for the unit is very helpful in isolating circuit component failure.
Jul 03, 2011 | Nakamichi Audio Players & Recorders
Nakamichi MB-70 CD player - cannot get cd to eject
Having just removed three discs from an identical unit which also jammed, I will say how easy that was. I do not know if the unit will now function when reinstalled in the vehicle.
Remove the unit from its mounts, remove the outer "frame" (if fitted), remove the two #2 phillips pan head screws from the sides holding the face to the chassis, remove the four #0 phillips screws (black, flat head) from the top and bottom of the face plate.
Slide the face plate off and carefully handle it while tethered by its ribbon wire.
Turing the unit upside down, peer into the opening and observe the disc, gently press the carriage away from the top of the unit (now the bottom, as it is inverted) and allow the disc to be freed, simply pull the disc out.
If there are multiple discs stuck inside, oberve the large metal gear just inside, carefully rotate the gear to actuate the loading mechanism as needed to release addtional discs.
Feb 23, 2009 | Nakamichi MB-70 6-disc In-dash Musicbank...
Nakamichi CD-400 users manual
Color change http://www.youtube.com/watch?v=91LB-KM4avg
Dec 15, 2008 | Nakamichi CD-400 CD Player
Need a Nak CD-45Z wiring harness, or diagram
Rob, I had the exact same problem, I kept searching on line and came upon Alex in Australia, he deals in Nakamichi products, and has the part (plug/wiring harness). He charges $55 for the part and $30 for express shipping.
Here's his email: aminassian@optusnet.com.au
I have also found a site with the Manual: http://www.nakremotes.com/default.htm
Click on "Model List" and look for your model, in the manual there's the wire color code for the pinout. I also have the pinout by wire color, no room to include, will send in another response.
TOP
[ 1 2 3 4 5 6 7 ] Looking @ pins in socket
[ 8 9 10 11 12 13 14 ] Naka CD45-Z deck
Note: The above diagram is done from the perspective of looking directly on to the connector pins. If you are having trouble figuring out which way is which, just use the ground wire, which is always black, as a reference for making sure you are doing the pins correctly.
Jun 11, 2008 | Nakamichi CD-45Z CD Player
Nakamichi Sound Space 8 System
NEW CABLE FROM NAKAMICHI IS £150 . INSTEAD JUST CUT THE METAL SHIELD OFF ANY CD MINI DIN CONTROL CABLE WITH A JUNIOR HACKSAW AND IT WILL FIT PERFECTLY (IT ONLY GOES IN ONE WAY BECAUSE OF THE WAY THE PINS ARE LAID OUT!). I USED AN OLD MAC DIN PLUG BECAUSE IT WAS 3M LONG! WORKS PERFECTLY!
DS
Jun 01, 2008 | Nakamichi SoundSpace 8 System
352 people viewed this question
Top Nakamichi Audio Players & Recorders Experts
Jerry Greenberg
Jerry Greenberg
ELECTRICLAW
Level 1 Expert
da surgen
Are you a Nakamichi Audio Player and Recorder Expert? Answer questions, earn points and help others
