HITACHI 65SWX20B turns off in 3 seconds
The TV will turn off in about 3 sec - seems like a power supply issue; I have replaced I-901 (STA-X6456) with no luck. Something is making the overload protection turn off the power supply, correct? What is the best way to isolate the problem? Any help is highly appreciated :-)
  • TablaPlayer Jun 25, 2008
    I appreciate your prompt response.
    When I turn the unit on, one of the green LED (D940) starts to blink along with protection red LED. Then after three seconds the unit shuts off - at this point the blinking green LED (D940) AND another green LED (D964) becomes dark & turn off. I read somewhere that the ones that turn off (or go dark) are the trouble areas of the Power Supply. So, my question to you is - what is the meaning of the green blinking LED (D940)? Now, since two green LEDs went off (or became dark) does that mean I have two sections that are not working (with bad components)?
    Once again, I really appreciate all your help.
  • TablaPlayer Jun 26, 2008
    I got it working now! Previously I had changed a couple of ICs on the main Power Supply PCB - that did not help. I followed your suggestions - checked to make sure the components in the horizontal are good Itransistors, diodes, resistors & caps) then I re-soldered horizontal components (xfmr and transistors) it started to work! I really appreciate all your help.
    Many Thanks :)
    Novelist:
    Champion:
  • 203 Answers
On most Hitachi circuit boards there are small green lights in the circuitry that show if a section of the set is working. Also,there are small protection fuses that look like resistors on the board around the power supply transformer. Check to see if any of those are open and it will lead you to the trouble spot. More than likely on that set it is convergence, vertical, Cold solder in horizontal (FBT or H.Drive xfmr.), cold solder at vert. output, regulator i.c., or audio out. Make sure you check the fuses that go to the convergence amps and look for discoloration on resistors surrounding conv. STKs. These are prone to change in value or burn up. Hope you have some luck solving this, Russmann.
Posted on Jun 24, 2008
  • Rusty Larmann
    Rusty Larmann Jun 25, 2008
    The green blinking LED was meant to tell us which circuit has failed but aren't perfect. My suggestion after taking a second look at databases for you are the same. First, check the convergence i.c.s and vertical output for cold solder joints. Second, look for discoloration around resistors in conv. circuit and replace conv. i.c.s and vert. output. Additionally, Hitachi has had a few problems with IH01, TA1360, C480 and C481 failure. Short of calling a repairman to repair it for you. These are my best suggestions. Good luck, Russmann.
I have a hitachi 65SWX20B projection TV. When I power it on, I get no picture, no sound, and on one of the circuit boards, an LED (D967) blinks dimly (1/2 second on, 1/2 second off). A soft click is...
If the board with the blinking LED has larger than average parts on it, it is likely the main power supply and the clicking may be from a relay that is connecting and then, disconnecting the AC. With no video or audio, the main power supply has likely failed. Contact Hitachi service to ask how much the repair or replacement cost of the supply is. Make sure you have all involved model numbers handy; the one from your set with the mfr. date if present and if you can find an assembly number on the power supply itself. it may save you time and errors. These boards are often simply plugged into other assemblies with dissimilar plugs but if you decide to DIY, take some snapshots of the cabling to be on the safe side.
Mar 11, 2011 | Hitachi 65SWX20B 65" Rear Projection...
Hitachi 43UWX10B - LED Light on constantly on will not go off
Power relay is defective. All contacts are not opening when power is removed. Located on small power supply board, upper rt side.
s 901 part# FJ00142 should be under $10, do a google search with part number and 50 sources will appear.
easyab
s901, FJ00142
Jul 14, 2010 | Hitachi 43UWX10B 43" Rear Projection...
I have no power to my Hitachi TV. It is plugged
try turning off main switch and unplug set then replug in wait 30 sec turn on main power and repeat then try if it works great if not power supply bad. i also suggest a ups universal power supply newer tvs sensitive to surges and brownouts also never turn tv off n on in short period of time will cause surge that trips protection circuit
Dec 29, 2009 | Hitachi 42HDS69 42 in. Plasma Television
REPOST: Hitachi 60SX12B Rear Projection TV typical(?) problem
If you can solder you can Fix It STK ICs they are big black ICs will have part number on them example STK392-110 replace Both and these resistors RK42 3.3ohms RK46 1.8 RK5 2.7 RK54 1.5 RK58 3.9 RK60 2.2ohms upgrade to STK392-150s better ICs
Dec 03, 2009 | Hitachi 60SX12B/13K 60" Rear Projection...
My TV shuts off seconds after turning it on. I hear clicks and shuts off. Please help. Hitachi 43fdx15B rear projection tv.
I have a very similar issue. Problem seems to go away after the TV has been on a bit and warms up. Did you find a solution for this? Thanks.
Oct 30, 2009 | Hitachi 65SWX20B 65" Rear Projection...
Hitachi projection tv will only turn on periodically. I power the tv up and sometimes it turns right on and other times it seems to power up but then front 3 lights on the front start blinking and the tv...
I don't know what model you have but ... the 50v715 I have did the same thing. Would come up for about 3 to 30 sec's (picture and sound) then shut down and do again. It was the BULB going out. You probably just need to replace your bulb. Check your manual on how to change it out. Make sure you buy an original Hitachi replacement I think there made by phillips. Hope this is helpful.
Oct 26, 2009 | Hitachi Televison & Video
Hitachi 65F59A turns itself off
The power supply may be failing.
Sep 02, 2017 | Hitachi 65F59A Television
Hitachi 32LD8700 - TV won't turn on although has power
The general problem with LCD type TV's is that the power supply fails. They are very sophisticated designs that are difficult to troubleshoot and generally best to just replace the module, but sometimes there is visible damage in some of the electrolytic capacitors (visibly bulged) and high voltage rated parts can be substituted.
Hope Ya Fix It
Feb 10, 2008 | Hitachi 32LD8700 32 in. LCD Television
Televison & Video Logo
196 people viewed this question
Top Televison & Video Experts
