Question about Gateway GM5072 Desktop PC
No boot I wanted to try what you said about removing the battery & memory but can you walk me through the process. Where is the memory and will it erase if removed? I see the battery and would it help to remove that wait a few minutes then replace?
  • 2,427 Answers
Preety Much ,,
Remove the battery,,
remove the memory (RAMS)
wait 30 seconds
press and hold the power button for 2 seconds
replace the memory followed by the battery
that will clear your cmos
Cheers DARK LORD TNT
Posted on Jul 09, 2008
  • Rishi Roshan Ali Jul 09, 2008
    yep what i just posted
  • Rishi Roshan Ali Jul 17, 2008
    hey were did it work or do u still require help
Thinkpad R51 will not boot
Try remove ALL media DVD.CD,USB,etc. Shut down, unplug, remove battery, plug in, reboot. Do you get anything on the monitor? Can you access the restore/recovery software? Open the Memory bay and reseat the Memory, open the HDD bay reseat the HDD, Reboot. If no change remove HDD, test, replace if necessary. Have you changed the CMOS battery?,
Jan 18, 2013 | IBM ThinkPad R51 Notebook
I hooked up another monitor to laptop and still gets black screen before and after I could get f2 Setup Utility but I can click on them nothing changes tried f9 gets nothing,f12 loads up but does nothing
Remove all media, DVD, CD, USB, etc. Remove all cables, monitor etc. shut down the laptop, unplug, remove battery, plug in try to reboot and tap the F keys. Is the computer booting, HDD Led blinking? DVD led blinking? Walk me through the process.
Dec 16, 2012 | Acer Aspire 5920-6727 Notebook
My KS-UMD070NA is not passing booting stage, can you help me?
Exactly what is happening when you try to boot?
Try the Check Disk Utility if it is trying to boot and gets hung in the boot process.
To run the check disk utility you will need a repair disc or a operating system disc. Put the disc in the cd drive and boot from it. You want to get to the Dos Command Prompt (Black screen with white letters) and type the following command: chkdsk /r
Check disk will run well over an hour or two and you will notice the percentages going from high to low, this is normal. Let it run to completion. Then reboot machine.
If check disk fails to solve your problem you might have to reinstall windows. Try doing a Repair Install that way you don't loose your data, documents, music, pictures, videos or programs.
In windows xp you get to the dos command prompt by selecting R for repair when the options appear.
In Vista and Windows 7 you want to get to the recovery console and look down at the bottom of the window for the Dos Command.
If it looks like it does not even start the boot process for some reason try the steps below:
When you plug in the power cord is there any lights whatsoever on the laptop, where the plug goes in or on the AC Adapter of the power cord?
When you press the power button do you hear fans running, hard drive spinning, lights on the computer, hear any beeps or lights constantly blinking, hear the DvD/CD drive click and the light on the drawer of the DvD/CD turn on for a second or two? If so the laptop is trying to boot or may have booted, but the screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with the laptop and why it is not booting. Most times it's a motherboard issue when you hear beeps or blinking lights continuous. Most times the problem is with the memory or Video Card. Count the Blinking Lights or Beeps and take note of their pattern (1 Long or 1 Long followed by 2 Short).
Maybe your power cord is bad if you don't get anything to happen whatsoever when you press the power button. And if that's true maybe you was operating off the battery the last time you had it on and since the power cord is bad, it was not charging the battery so the battery is drained and the power cord is bad.
Maybe you have a Static Charge Buildup. Remove the Power Cord, Remove the Battery, then Press and Hold the power button for 30 seconds. After 30 seconds plug the power cord back in (leave the battery out) and hit the power button to see if it boots. If it does, you can put the battery back in and let it charge.
Maybe your DC Power Jack which is where the power cord plugs into the computer is bad. Take an ink pen and push the tip inside the jack and see if the little pin wiggles, if so the jack is bad. You'll have to take the laptop apart to fix it. Most times it is soldered onto the motherboard, so you will have to desolder the old and solder a new one.
Maybe your memory is bad or the memory slot is bad.
Remove the Power Cord, Remove the Battery, Remove the cover that houses the memory on the bottom of the laptop then remove one of the memory chips. Set the chip aside then try rebooting the computer. If it boots, then you know the memory chip you set aside is bad so mark an x on it with an ink pen. If it fails to boot then move the chip to the next memory slot and try rebooting. If it fails take the chip out and set it aside, then put the other chip in and try booting it in both slots. If it boots, just to verify that the chip set aside is bad, mark an x on it and put it into the open memory chip slot and try booting.
Jun 02, 2012 | Computers & Internet
Power button does not work vostro 1700
LOL, sounds like a lemon. I would think either the memory, power cord or CMOS battery might be the cause. But since it boots each time after you go thru the process you described it has me baffled.
Maybe one of your memory chips is bad.
Remove the Power Cord, Open the Case and remove one of thememory chips. Set the chip aside then try rebooting the computer. If it boots, then you know the memory chip you set aside is bad so mark an x onit with an ink pen. If it fails to boot then move the chip to the nextmemory slot and try rebooting. If it fails take the chip out and set itaside, then put the other chip in and try booting it in both slots. If itboots, just to verify that the chip set aside is bad, mark an x on it and putit into the open memory chip slot and try booting.
Mar 31, 2012 | Dell Vostro 1700 Notebook
Laptop problem
If the fan runs and you see lights that's a good thing. It means the laptop is getting power and trying to boot. Now do you hear the hard drive turning? When you press the Power Button do you hear the CD drive click once and notice that the light on the cd drive door turns on for a second or two? These are all good signs of the laptop trying to boot. When you press the power button did you hear any beeps or notice that the lights blink continuously such as 1 long beep and 2 short beeps. The lights and blinks tells the technician what is wrong. When you press the power button do you see anything on the LCD Screen as it goes thru the boot process?
Try removing the battery and the power cord from the laptop. Then press and hold the power button for 30 seconds. After 30 seconds, plug only the power cord in and press the power button to reboot. If it boots that means you had a static buildup which is normal in computers. By hold the power button you released the static. If it boots you can put the battery back in. If it does not boot and if the lights are blinking or you hear beeps you might have a bad memory chip. Unplug the laptop and turn it over to remove the screws tht house the memory chips. Remove one of the memory chips and set it aside. Now try to boot your laptop. If it does not boot, move the memory chip to the other slot and try rebooting. If it boots place an x on the memory chip that you have set aside. If it does not boot remove that chip and put the memory chip you have set aside in the laptop and repeat the process of moving in into each memory slot and trying to boot. If you get it to boot with one memory chip, place the other chip in the available slot (make sure it has an x mark on it so that you will know which one might be bad), then try rebooting. If it fails, that chip is bad. If it does not boot for either chip then more than likely you have a motherboard issue.
Mar 20, 2012 | Compaq Computers & Internet
Unable to boot Acer laptop. The booting starts and then there is a blank screen and a cursor blinking. Not moving forward. I pressed F12 and made it boot from hard drive. Still the same.
Hello.
Either you have an operating system problem or memory issue.
First, boot your system to Safe Mode (press F8 repeatedly when powering on). Go to System Restore and choose a date when your system worked OK. Note: with System Restore, all your updates will roll back to that date. Follow the process.
If still a problem, disconnect all cables. Be certain to dispel static electricity by touching metal. Remove the battery and memory cover. Try reseating (removing and reinserting) your memory (try one module at a time to test).
Hope this helps.
Aug 28, 2011 | Acer Aspire 5100 Notebook
My VAIO VGN-FS920 laptop freezes after booting to the windows operating system. I see my desktop but cannot work because the cursor freezes.
Hello.
If still a problem, disconnect all cables. Remove the battery. Be certain to dispel static electricity by touching metal. Remove the memory cover. Try reseating (removing and reinserting) your memory (try one module at a time to test). Replace the cover and battery and boot.
Hope this helps.
May 18, 2011 | Sony VAIO VGN-FS920 Notebook
T30 still won't boot after fan replacement
One of your memory slots might be bad as I'm assuming you tried both memory chips in the known working slot.
I found setting the boot up sequence in BIOS is better than using F12.
Set your BIOS to boot the CDROM first. I suspect the hard drive has failed or has a problem. Do you have a floppy boot disk? Lenovo has PCDoctor bootable diagnostics on their website. You may have inadvertently bent a pin inserting the hard drive. Your CMOS battery could be dead but since that was untouched I would be surprised.
Sep 08, 2008 | IBM ThinkPad T30 2366 Notebook
Gateway GM5072 Desktop PC Logo
127 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
