How to put the belt on,
Hotpoint washing machine aquarius-wf000 1000 spins
my belt fel off, i have tried to put it back on ,but it looks too small.
please, is there any other way ,thanks
  • 1,462 Answers
There is no way of tensioning the belt so it is a very tight fit
put belt round motor pulley first then start belt on large pulley and turn large pulley by hand and it should go on
Posted on Jun 24, 2008
  • j_hairstyles Apr 08, 2012
    use a 1/2" drive ext and 11/16 deepwell socket or one that will fit over your moter shaft put the belt on the drum pulley first then (took 2 people) put the socket over the other end of the belt angle the socket and the ext toward and over the motor shaft this takes strength continue streaching the belt with ext arm until it is at same angele the motor shaft hold in position spray socket with alchol this aids the belt ti slide into position turn drum til belt sets second person makes sure belt stays on drum while you carefully streach the belt we did it this way because the drum had sharp edges and could cut the bet
Ur a b!tch dat why it fel down herd
sincerly, yo mama
Posted on Dec 21, 2008
The belt has come off my hotpoint WMA5 washing machine
offer the belt around the motor pulley first , feed one side of the belt to drum pulley , whilst holding this side to drum pulley turn pulley using other hand , belt should follow natural path onto pulley .
Jan 23, 2013 | Hotpoint Aquarius WMA56 Front Load Washer
Hotpoint aquarius ctd00 tumble dryer...everything working but drum wont turn
it looks like you need to put the belt back on which is inside the machine. to do this open the lid with screws on back take lid off then you should see the belt inside the machine and where is was before on the drum of the machine. slip it back on and put lid back on and it should start turning again. hope this helps.
Sep 20, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
How to fit a belt to a hotpoint aquarius when the back cannot be removed
If there is a small inspection panel at the back where you can get to the motor remove that then remove the top lid of the machine. Loosen motor mounts and swing motor up and remove belt from motor. Now remove belt from pulley from the top of machine. Reverse the order starting from the top to replace belt.
Jan 24, 2010 | Hotpoint Aquarius WF000 Front Load Washer
My wfooo hotpoint washing machine doesnt spin, the belt came off i put it back on but then it snapped when i put the washer on spin, will the washer being empty when i did this affect the belt?
Think your belt was allready on the way out and you will need a new one. Just a coincedence that it broke when it did. It came off because it was worn and stretched.
Sep 01, 2009 | Hotpoint Aquarius WF000 Front Load Washer
The belts come off, its a hotpoint aquarius wm63.
Remove the complete rear panel of m/c if it is a washer dryer, you will see the drum pulley in the center, and the motor pulley is at the top of the m/c
Put belt round motor pulley first, and feed belt round drum pulley.
If it is a washer on its own, remove the small center cover at rear of washer, and remove top cover also.
Put belt round motor pulley first and carefully feed belt round drum pulley, you will find this easier to do if you unhook the rear retaining spring.
Please leave a fixya rating for my solution.
Feb 12, 2009 | Hotpoint Aquarius WD63 Front Load...
Need to replace drive belt on hotpoint wf430 but to tight to get
Put it on the motor spindle first then feed it onto pulley. It is tricky with such limited access.
Hope this helps &thanks for using Fixya.
Jan 22, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint WD640P - Fitting a new belt
Put belt on motor pully first then turn big pully around!Like fitting bike chain.
Oct 11, 2008 | Hotpoint Aquarius WD63 Front Load...
Belt has come off - how do i put in back?
Jun 06, 2008 | Hotpoint Aquarius WMA52 Front Load Washer
My washing machine has stopped spinning, for the last 4-5 washes it made quite a bit of noise when spinning the load and now it has stopped spinning completely. It makes the noise as if the motor is...
it sound like your belt has come off if not wait till its dark put it on spin turn the light off if you can see flashes coming from under the machine it your brushes that need replaced on the motor
Dec 31, 2007 | Hotpoint Aquarius WF215 Front Load Washer
Washing Machines Logo
360 people viewed this question
Top Washing Machines Experts
