Question about GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker Over the Range Microwave Oven
We have had a GE SpacemakerXL Microwave Oven (Model JVM1650 or 1651) since 2000. The other day, while heating some food, it made a noise and went completely dead.
If you have any ideas about what could be wrong and whether it could be fixed for a reasonable cost, I would appreciate it.
Sandy
  • 958 Answers
Sandy, i think your magnetron just went bad. can you see if there is a black spot or dirt accumulating on the microwave guide cover. it is the gray rectangular thing at the side of the wall . these black spots are from oil or food that have accumulated and has been heated over and over again untill it becomes carbon and becomes conductive. these carbon then conducts electricity to the metal casing holding the wave guide cover. if this happens, the tip of the megnetron would spark against the wall and burn the tip of the magnetron and short it out. if it has a fuse, it could pop out and might still save the magnetron. if there is none, then you could have end up with a bad magnetron. decide how much a magnetron first before you buy a new oven. i hope i was able to help.
Posted on Jun 24, 2008
I have a GE SpacemakerXL Microwave Oven Model JVM 1350 The fan and the light works, but the microwave is not working and the screen says
There are two possibilities, one of the door switches has malfunctioned, usually caused by food partical buildup, more than likely. or there is an issue with the microprocessor control board, less likely.
Mar 11, 2012 | GE JVM1350BW/WW/AW/SY Microwave Oven
I have a GE SpacemakerXL microwave oven - Model JVM1640WB004, S/NTZ979368S. It is no longer heating. The lights, fan and rotating tray are still working. Will this repair be so expensive that it would be...
When there is no heat, but everything else seems to work, it means the magnetron circuit has failed. The magetron is the part the generates the microwaves that heat the food. When it fails, it makes a loud buzzing sound. The replacement part can cost as much as a new oven, so it not worth fixing. Get yourself a new oven.
Feb 22, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
GE spacesaver II making loud noise and is not heating up food
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Jun 04, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
GE SpacemakerXL JVM1443 stays on when door is closed
That's almost certainly a failed primary interlock (upper door switch) or its mount is bad.
See our file on info on door switch diagnosis and replacement.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
May 30, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
heatman101
Apr 06, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
GE SpacemakerXL Microwave oven clicking noise
Spacemaker t/t motors are very easy to change. Removed the screws from bottom of microwave. the bottom panel will found towards wall. Mtr is in very center of unit. Should have 2 wires going to it
Nov 21, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Our microwave (GE) not longer heats food items.
heatman101
r
Sep 27, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave run with a different noise and stopped heating up food
heatman101
fkj
Mar 18, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
No more heating, GE Profile Microwave JVM 1870CF02
I think its the mag tube, mine went out the same way. GE will provide the mag tube for free just call them...have a local ge certified tech out to put it in.
Aug 31, 2008 | GE JVM1850 1000 Watts Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
230 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
