Question about HP OfficeJet 7410 All-In-One InkJet Printer
Help Would you please be more specific on how to take the card off? I did open the back panel, but then I lost and gave up. Is it possible to provide a step by step instruction? Thank you so much, I am this much frustrated.
  • dasse Jun 25, 2008
    Thank you so much for your help.
    It took me almost 10 sec. to solve the problem.
    Now it is connected through the USB port.
    I haven't tried the wireless again.
    Do you think the wireless card is broken? Anyway to fix this?
    I want more and more, right? ;-)
    Anyway, thank you so much.
  • 3 Answers
I'll do my best to be more precise, however the problem happened today at the office so I won't be able to link images, since I'm home now.
If you remove the back part of the printer (in our case it also had a module for 10x15cm prints) by pushing on the sides, you'll discover a couple of hexagonal screws. You don't necessarily need an hexagonal screwdriver to remove them: a slotted one , if it's a small one, is enough. Once you remove the two screws on the sides of the back panel (they are at the sides of the part where the paper usually moves during the print operation), you'll be able to pull the back panel, and uncover a small logic board with at least 6 connections on it. It's on the left side of the printer , if you look at it from the back.
First of all, there is no "card" to be removed, since it is placed somewhere in the printer but it's not connected directly to the board: the cables, however, are the ones that connect the different components of the printer (display, scanner, etc...) to the logic board. There are 2 main kinds of connections: "flat" wires ("buses") and ribbon cables, usually made of wires of different colors tied together: these usually end with a white connector.
By trying them, I found out that the "flat" cables are the ones that are needed to operate the display and the front panel buttons, while the white-ending cables are responsible for connecting the scanner and , presumably, the wireless card, among others.  I had to remove almost every cable I found, because the (supposed) wireless connector is hidden by some of these cables: it's in the upper part of the logic board, it's one of the smallest connector and, if I recall correctly, it's the only one that is wrapped into black rubber covering. I removed all the cables by pulling using my fingers (be sure not to cut them, especially the flat ones are quite fragile!!). Once you unplug that cable, be sure to reconnect all the others in the correct place. Reconnect the power supply to the printer: it worked for me, and I didn't even lose my settings!
If by accident it happens that the display won't turn on, or the front panel buttons don't work, this means you didn't reconnect the cables properly, or that you unplug the wrong cable.
Hope it helps!
Posted on Jun 24, 2008
  • Maggix Jun 25, 2008
    Well in our office we didn't need any kind of wireless connection, so until someone complains, we are going to keep it as it is ;)
    If anything is going to change, I'll write on this thread :)
    BTW in my case ethernet still works, so we connected it through etherned cable.
I am trying to register my new TV with you
You won't be registering your new TV with this site. You have to actually go to the website for the manufacturer of your TV. You gave no indication of brand so can't help you specifically. Your warranty or registration card should give you specific details.
Nov 10, 2014 | Televison & Video
Door dont open..
go see a nissan dealer . possible the BCM has failed
Mar 12, 2017 | Nissan Altima Cars & Trucks
My 2006 manufactured Viore flat screen plasma tv suddenly went blank. Still have sound. Please help!
Read the following:
http://blog.coppelltvrepair.com/2011/02/hp-pl4260n-suddenly-lost-picture-how-to.html
Different TV, but most likely same problem and, in fact, quite possibly literally the same boards, so maybe practically the same TV.
Can't be sure since you haven't posted the model of your Viore.
If you have specific questions, please always include the model number in the question...the model is on a sticker at the back of the TV, right after or below the words "MODEL:" :-)
Nov 09, 2011 | Toymax Viore 42 in. Plasma TV
I accidentily deleted some pictures I needed. Is there a button I can press to get them back??? Please help me!
I have had success with this picture recovery program called asoftech photo recovery... Download the program from
http://www.asoftech.com/apr/
You have to use a card reader either on your computer or an external USB card reader. Put the card in the card reader, open the recovery program, then select the drive where files are deleted, then press "Start" and wait for it to do it's magic.
Feb 24, 2011 | Polaroid A530 Digital Camera
My zebra id card printer p120i does not print very sharp
zebra p120i TROUBLESHOOTING LINK
Printing shows blurry printed image.
Possible Cause:
•Ribbon cartridge may not be correctly positioned.
Solution:
•Check that the ribbon is properly rolled onto the ribbon cores of the cartridge, with no wrinkles.
•Replace ribbon cartridge, making sure it locks in place, and print again.
Possible Cause:
•Ribbon may not be synchronized on the correct color panel position.
Solution:
•Open lid, then close lid to synchronize ribbon.
Possible Cause:
•Cards may not meet specifications.
Solution:
•Use a different supply of cards.
Possible Cause:
•Dust or embedded contamination inside the printer and/or dirty Cleaning Roller.
Solution:
•Clean the Print Head.
•Replace Cleaning Roller
Jan 30, 2011 | Zebra P120i Thermal Card Printer
Error Code C3451
Where exactly is the switch because if you open the front door there is only the door sensor actuater and I dont seen to see the switch. Is it under the covers
Feb 06, 2010 | Konica Minolta bizhub 350 All-In-One Laser...
How to delete my memory card password in Nokia 3110 .It is 256mb
format the memory card. passwords are dangerous when forgotten. You loose all that you wanted to protect. format it either in the phone or on a PC.
Aug 05, 2009 | Nokia 3110 Cellular Phone
Bumped front of my modem by accident and i lost connection....
I think that when u bumped, something went loose. Open up your computer and just make sure everything is seated properly. You RAM and your graphics card being the main things to check. Re-seat them if possible. That should take care of the problem.
May 14, 2009 | Dell Computers & Internet
Friend gave me his old Samsung SGH D500 but had lost instructions
button on back of phone near top, press in and remove battery, you should see a sim slot? slide your sim card in, re the camera, go to menu/camera/ok/ok/ok, you have just taken a photo!
Apr 29, 2009 | Samsung SGH-D500 Cellular Phone
Lost unzipping ability
Clickhere to download winrar. After downloading, install it and tick all the archives like zip,rar etc., that you want it to open. Post back if you need more help.
Regards,
Sai
Dec 06, 2008 | Microsoft Windows Vista Ultimate Edition
HP OfficeJet 7410 All-In-One InkJet Printer Logo
99 people viewed this question
Ben Johnson
