Minolta Bizhub B211
Hi, guys. Can someone pls assist me. I have problems with the scanning function on this machine. It keeps on giving the following message: NO NETWORK SETTINGS What to do now?
    Problem Solver:
  • 15 Answers
You might not install the net work card if you did you should inter the setting
Posted on Apr 15, 2009
Konica Minolta Bizhub C252 FTP Scanning Problem
I'm not sure what you want to do, but I have installed various BizHub machines.
User ID, is exactly what it is... Used to monitor and manage individual users.
Which OS is the machine you want to scan to?
Depending on machine, I will hint Konica Minolta FTP Utility...
Mar 04, 2014 | Office Equipment & Supplies
Scanner settings Bizhub Pro C500
The communication can only be complete when the IP Address is fully established. This is in the manual and information on doing a set up is detailed by Minolta. Only you or a technical person with privileges who you invite into your computer can resolve that issue.
Feb 20, 2014 | Konica Minolta Bizhub Pro C500
Scanning to e-mail - Bizhub 215
This setting is only for bizhub 200 - 350
How to set up the machine for SMTP authentication. There is no selection to enter the information in network setup on the machine.
Solution
CAUSE: Incorrect soft switch setting.
SOLUTION: Perform the following:
1. Touch utility button
2. Admin. Management
3. Admin. 2
4. Software SW
5. Enter the soft switch mode 380. Set bits 6 and 2 to 1.
6. Re-start the machine. The SMTP settings will now appear in the network setup of the Admin 2 mode to allow entry of the user name and password.
Aug 01, 2012 | Konica Minolta Office Equipment & Supplies
Plz guide this machine gives me an error mal function what is mal function
What is the malfuction code showing on the display? This code will be a letter followed by 4 numbers. Such as C3542. Reply back with the code so we can assist you further.
Feb 08, 2011 | Konica Minolta bizhub 350 All-In-One Laser...
Minolta bizhub erorr codeco202
CO202 relates to tray 1 (top tray). It hasn't managed to lift the paper successfully.
Open the tray, remove the paper, reset the machine (open/shut front door) then reload the paper and try again
Hope that helps
Regards
Taminol
Jul 27, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
Konica Minolta Bizhub C352 error C-B116
try with trouble reset
turn off the machine, press and keep pressed utility counter, turn on the machine
on the display you'll see the Trouble reset button on the display, touch it and turn off and on the machine
check if error disappear
Oct 19, 2008 | Konica Minolta bizhub C250 All-In-One...
Bizhub C650 (Minolta printer, copier)
setup for adf if is new machine u have the setup **** for adf
the setup **** (A4 page) with black border
Oct 13, 2008 | Konica Minolta bizhub 350 All-In-One Laser...
Problem in configuring IP address in Konica Minolta bizhub 210 Copier, Printer, Fax
Is there network card is installed in it, if yes then you can configure it with your network go to machine Manu in machine control panel and the in network settings here you can give the IP address and subnet mask after then reboot the machine.
If network card is no installed behind the machine then you can use its built-in USB or and parallel printer without NIC card.
Feb 01, 2008 | Konica Minolta bizhub 250 All-In-One Laser...
177 people viewed this question
jasbo
jasbo
