Question about Uniden DECT 6.0 Cordless Telephone Expansion Handset
Phone says "Searching" and will not work.
I have a 2 phone set of Uniden DECT 6.0 phones, the one on the main base usually says "Searching" and when I press the call button, it makes three quick beeps and says "Out Of Range". The phone on the secondary base charger thing works just fine, though.
  • 8 more comments
  • nickb47 Jun 24, 2008
    English?
  • dpbrew Aug 03, 2008
    We have calls drop off and then the phone says out of range when we are standing 4 feet from the base.
  • rmess40 Aug 08, 2008
    I have the same problem the hand set will say out of range right next to the base
  • kehillma Aug 26, 2008
    I have the base plus three other phones, one which is the submersible one, DWX207. I used the ball point pen and if finally took. The problem is it reads searching all the time. Please help or I will return them to Costco.
    Ken
  • Anonymous Sep 07, 2008
    my phone says searching and when i try to call someone it make 3 quick beeps and says OUT OF RANGE
  • nettcav Oct 10, 2008
    I have the dect 3080-3 it they all say searching. Even the one on the base. I tried resetting the phones by unplugging everything, phone line, power, and removing the batteries. It worked ok for half a day, now it's back to searching.
  • Anonymous Oct 15, 2008
    Same for me second phone is alwayts searching and wont register to the base. Help!!
  • Anonymous Dec 17, 2008
    Neither one of my two phones work. Both the main and the secondary phones say Searching and will not give a dial tone. Please help!
  • Anonymous Mar 17, 2014
    handset #2 shows handset out of range/searching. calls cannot be made from this phone. does not connect.
  • Anonymous Mar 27, 2014
    Reset. Base
    unit
Como activar mute la pertada 2 sin vos
Posted on Jun 24, 2008
The display screen is showing the word "SEARCHING" on the screen, can't get the phone to work, cannot pick up an incoming call, the display also displays "HANDSET OUT OF RANGE" WHEN ANY BUTTON IS...
From the Uniden support site.
You can first try a Basic Reset.
A reset is done by following the below steps:
1. Disconnect the battery from handset(s)
2. Disconnect Phone Cord from wall jack
3. Disconnect Phone cord from base unit
4. Disconnect AC adapter from wall outlet
5. Allow to sit for 30 min
6. Reconnect Phone Cord to base
7. Reconnect Phone cord to wall jack
8. Reconnect AC Adapter to wall outlet
9. Reconnect battery into handset until you click or feel the plug snap into place
10. Re-Register Handset by placing on main base
reference
Mar 13, 2015 | Uniden DECT 6.0 Cordless Phone ID
Uniden phone stuck at searching, not getting a dial tone
One thing to try is deregestering your phone and registering it with the base again.
Hole the # and 'End' key on the handset until the next menu appears (about 5 seconds). Select deregister phone (use the 'Menu' button). Do it again, but select "base unavailable". After that, set them in the base (not the handset charger) and they should register with the base.
This works on most Uniden model phones.
Jan 29, 2013 | Uniden DECT 6.0 Cordless Telephone...
Uniden D1680-2: After a 24-hr power outage, it now says "searching"
Move your phone closer to base ... that is what I did with my Uniden and it resolved itself
Sep 07, 2012 | Uniden DECT 6.0 Cordless Phone ID
We just bought a new uniden phone system and the Answering Machine keeps answering the phone after 2 rings. I set the base machine setting to answer after 6 rings but it didn't change.
If you have changed the setting on the base station and that did not work, power your base station off completely and try again if that does not work you have an out of box defect and need to exchange it.
May 06, 2011 | Uniden DECT 6.0 Cordless Phone ID
Handset won't connect to base unit
Try placing the handset in the base unit to register it. Then see if it is found by the base.
Mar 21, 2010 | Uniden DECT 6.0 Cordless Phone ID
Phone not working
Searching means the phone can't find the base.
Make sure you registered each phone on the base.
If you have done this already, and are sure that the baseunit cradle has power, I'd return them as they are probably defective.
Nov 02, 2009 | Uniden Cordless Phone
After charging a Uniden 2180-2 DECT 6.0, the base stope showing anything on its display. As for the other handset, their display report " searching" since they can' t connect to the base. What is goin
Reset Procedure for Cordless Phones
Question:
What is the general reset procedure for cordless phones?
Answer:
1. Disconnect Battery from handset(s)
9. Reconnect Battery to hanset until you click or feel the plug snap into place
10. Re-Register Handset by placing on main base in most instances
May 05, 2009 | Lands Phones
Can use the phone it is only reading searching on the display.
Question:
Answer:
Apr 07, 2009 | Uniden DECT 6.0 Cordless Phone ID
Uniden DECT 6.0 Cordless Telephone Expansion Handset Logo
1,210 people viewed this question
Top Uniden Lands Phones Experts
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
