Question about Kenmore 22422 Top Load Washer
Replace a lid switch
Have ordered lid switch assembly, but need to know how to replace it
  • 1 more comment
  • emsmith Jun 25, 2008
    The plastic casing which holds the two mounting screws have split, causing the lid switch to drop down. Closing the lid does not close the switch and the washer stops during the rinse cycle and does not spin. I used a sticky-back metal duct tape to hold the switch in place and use the washer while I order the lid switch (Part #3949238) and the do it yourself repair manual (Part #LIT4314044) from Sears Parts at 866-873-7666.
  • Anonymous Jun 30, 2008
    i was lucky---i gently pulled the pieces out, tugged on the wire, super glued the plastic pieces together, slid it back in and reinserted the screws. I am assuming it got broke by someone slamming the lid but no ones fessing up!!!
  • richatc44 Dec 23, 2008
    in the middle of the cycle it will stop and i can unplug it for a short time and i hear a click sound and it will work again for a min or 2 i just replaced the lid switch
  • 413 Answers
To access the lid switch:
1.Remove the trim on either side by prying off from the top. Grasp the trim at the top and pull forward to expose to expose a screw.
2. You will find a lid switch connector (white in color). Unplug the switch from the connector.
3. There will be two brass colored clips. Place a flat blade screwdriver straight down into the opening on top of the washer and into the groove of the clip. Push the screwdriver down and away from you and the clip will release.
4. Open the lid of the washer and place your hand under the front rim of the opening (DO NOT grab the wash tub). Tilt and slide cabinet forward to remove.
If you need further assistance, let me know
Regards,
reg501
The FixYa Team
Posted on Jun 26, 2008
Haier HLP20E washing machine won't spin & drain.
Haier HLP20E washing machine won spin drain Google Search
Cause 1Lid Switch Assembly The lid switch assembly prevents the washer from spinning when the lid is open. If the lid switch assembly fails, the washer will not spin. To determine if the lid switch assembly is defective, use a multimeter to test the lid switch for continuity. If the lid switch does not have continuity, replace it.
Parts Cause 2Motor Coupling
The motor coupling connects the motor to the washing machine transmission. If the washer is overloaded, the motor coupling will fail in order to protect both the motor and transmission. The motor coupling can also fail due to normal wear. Inspect the motor coupling to determine if it is broken. If the motor coupling is broken, replace it.
Parts Cause 3Drive Belt
Inspect the drive belt to determine if it is broken or if it is loose on the pulleys. If the drive belt is broken or loose, replace it.
Parts
Jan 13, 2018 | Haier Washing Machines
My Whirlpool WTW57ESVW1 is not working. The auto load sensing stopped working long ago. When i shut the lid it won't start. Sometimes if I slam it shut it will work but now I have nothing help!
Here is a list of possible Parts that can be replaced for this symptom.
  1. Lid strike
  2. Lid switch assembly
  3. Motor Coupler
  4. Motor Capacitor
and you could also replace the Load Sensing Switch if you needed. The pictures are in the same order.
Check parts and replace as necessary. I am also including a link to the parts diagram.
Good Luck!
JP
WHIRLPOOL AUTOMATIC WASHER Parts Model WTW57ESVW1 Sears PartsDirect
Jul 09, 2015 | Whirlpool Washing Machines
Whirlpool la5558xtwo
Replace the lid switch and you will be good to go. Here is that part to order.
Whirlpool 285671 Lid Switch Assembly AppliancePartsPros com
Aug 18, 2014 | Whirlpool Washing Machines
I need to put weight on the lid for the machine to run may tag atlantis
You need to order and replace a lid switch assembly. Good Luck, Appliance Specialists
Dec 17, 2010 | Maytag Washing Machines
My maytag washer stoped during the cycle with 8
You may have blown the internal fuse located in the lid switch. Could be you over loaded the washer and blew the fuse.
Unplug the washer and remove the four screws holding the control panel front in place. Two screws on top and two screws under control panel.
Remove the control panel and tilt forward.
Locate the lid switch assemble and remove glass fuse and inspect.
Door switch assembly should be replaced. When you order the proper fuse it should come with the door switch assembly.
Replace assembly. Reinstall the front control panel and four screws.
Plug machine in and test.
Jan 03, 2010 | Maytag Neptune MAH5500B Front Load Washer
Replace lid switch assembly kaws850
The following link explains how to replace a lid switch:
http://www.fixya.com/support/r385199-replacing_lid_switch_whirlpool_top
On the particular model you have listed, the lid switch should be located under the console near the right rear lid hinge.
You will need to use the steps in the link provided to remove the exterior case to access the switch to see how the actuator and lid hinge interface. You washer is manufactured by Whirlpool and uses Whirlpool parts, so these instructions will apply.
This is a very simple repair, but if you have any questions along the way, please let me know. I hope this is helpful to you.
NOTE: If you have not pruchased a new lid switch yet, the part number is 8054980. It can be purchased at appliancepartspros.com for about $18.
Oct 30, 2009 | KitchenAid KAWS850L Top Load Washer
Replace lid switch assembly on
Most whirlpools open this way:
The control panel must be detatched- it is held on with small spring clips under the left and right side of the control panel, and you can release them by pressing in on them with a putty knife -OR- it is held on with screws at the back of the base, which when remove will allow you to move the base and release the hooks from their slots.
Then you need to unplug the lid switch, and then release the two brass colored "funny s shaped spring hooks" that hold the cabinet to the back panel. Then you tilt the cabinet back (or actually forward-- away from the back panel) and pull it off of the hooks on the base.
Sep 15, 2009 | Whirlpool Washing Machines
GE WSJR4160DOWN
You don't have to remove the washer top. Use a putty knife to push the tabs in on the left and right side, about two inches from the sides, at the top seam of the front panel. Front panel pulls forward and lifts off bottom pegs. Lid switch has a tab you need to push toward the center of the switch (its on the back side of the switch) which will allow the switch to push up. twist the switch and pass it back down through the washer top.
Oct 11, 2008 | GE WBSR3140DW Top Load Washer
Kenmore lid switch
The following link explains how to replace a lid switch on a Kenmore top loader:
http://www.fixya.com/support/r385198-replacing_lid_switch
Now, unless someone has modified the original lid switch, there is NO soldering required. The defective switch just has a couple of mounting screws holding it in place, along with a ground wire attached to the casing. The entire assembly unplugs from the timer and comes out.
As far as a replacement is concerned, you can order them on line at searspartsdirect.com. Just type in your complete model number (located around the wash tub opening) and the lid switch is usually listed under the "Top and Cabinet" heading. If your lid switch is activated by a lid strike, which is mounted on the washer lid, make sure it is also intact and not broken. The strike is also listed under the same heading. If you do not wish to wait on shipment, take the part numbers listed on the Sears website and go to your nearest appliance parts retailer. These are standard parts that can commonly be found there.
I hope you find this information helpful. Let me know if you require additional assistance.
Sep 28, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore Top Load washer
You can replace the switch, it appears, without lifting the lid. I've ordered the repair manual (LIT4314044) but I can feel the connector and wires. It appears that the lid switch can be replaced without taking anything apart. There does appear to be a screw on the back that holds the ground in place.
Jun 23, 2008 | Kenmore 22422 Top Load Washer
Kenmore 22422 Top Load Washer Logo
442 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
