Question about Xerox Office Equipment & Supplies
XEROX PHASER 3500. 8220 FUSER FAILED #8221. OVER HEATING AND BURNING SMELL.
LE HE CAMBIADOS DOS VECES EL FUSOR A LA IMPRESORA XEROX 3500, SE HA DAñADO SUPUESTAMENTE POR CAUSA DE LA ELECTRICIDAD, USTEDES ME RECOMENDARIAN USAR OTRA O SABER SI EL FUSOR REALMENTE HA SIDO REPARADO Y POR ESA RAZON VUELVE A DAñARSE.-
Posted on Dec 07, 2008
Fuser upper failure is the message i am getting on my xerox phaser 7300. can anyone help please
Hello, The fuser or fuser roller is what actually bonds or melt the toner on to your paper. There is probably some type of temperature sensor, that senses the temperature of the fuser. If its not hot enough or just plain dead, it will give out an alarm similar to what your getting. You probably need to replace the fuser unit. You have a lower fuser and an upper fuser. You might be able to get away with just replacing the upper roller. The roller has a heating element inside and that's what probably defective.
Hope this Helps
Thank You for your feedback
Jan 31, 2011 | Xerox Phaser 7300DN Laser Printer
Phaser 6250 DP keeps on jamming at Fuser.
Paper type set correctly? Does the paper enter the fuser? If not, the fuser drive has failed, replacing the fuser may correct it.
Nov 19, 2010 | Xerox Phaser 6250DP Laser Printer
Printer error fuser temp
You will need to replace the fuser. The heating element or one of the thermistors have failed.
You can call 1-800-835-6100 to order that, I do not think it is very expensive. If it is in warranty they will just replace it.
Feb 23, 2010 | Xerox Phaser 3100MFP/S Laser Printer
Engine fuser low heat error on my xerox phaser 3500
You may want to look and see if you just have a piece of paper wrapped around the roll, but most likely the heating element has gone bad or one of the thermistors have failed.
Call 1-800-835-6100 and tell them the model number, and if it is a 120 volt or 220 volt fuser.
Feb 10, 2010 | Xerox Phaser 3500/DN Laser Printer
How can I reset the Xerox Phaser 3100MFP fuser?
A hardware module is used to reset Xerox Phaser 3100 which work as permanent solution. After that you can refill unlimited number of times without any problem. www.nakshatraworld.com, 09713862555
Dec 15, 2009 | Xerox Phaser 3100MFP/S Laser Printer
Fuser temperature error for xerox 3100mfp
kindly check externally the fuser is heating or not. i SUSPECT THE FUSER MIGHT BE FAILED.
Nov 16, 2009 | Xerox Phaser 8400 Laser Printer
I own a Xerox Phaser 3100MFP and it keeps giving me an error message saying "Printer error Fuser temp"...Help
please your xerox phaser is in fuser light is checked is not courently okthis parts is damaze? then changing the fuser temp and new added.
Sep 22, 2009 | Xerox Phaser 3100MFP/S Laser Printer
Xerox 8560 is very hot even in sleep mode
the fusers get about 300 degrees to melt the toner to the page. If you do not have the phaser clean regularly, the paper dust that is next to the fuser could smell like it is burning.
Jul 16, 2009 | Xerox Phaser 8560MFP Laser Printer
Burning smell during warm up
This is a normal start up smell.
Dec 12, 2008 | Xerox Phaser 8500/DN Printer
Open heat error
One of 2 things is happening, Either the Heating element is going bad, or more likely the thermistor that monitors the temperature of the fuser is intermittent. You will most likely need to replace the fuser to resolve the issue. That machine has a one year on site warranty. If its less than a year old Xerox will fix it for you free of charge.
Oct 03, 2008 | Xerox Phaser 4500 Printer
559 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
