My samsung rear projector has lost its convergance,it is slightly in 3d and the auto focus will not fix it
  • 4 more comments
  • Anonymous Sep 13, 2008
    seems to be that the lens focus is out of sync (red,green and yellow colours are separate .how can this be adjusted
  • tkdaa2485 Oct 10, 2008
    I have the same problem. The Blue lens on my Samsung 42" projection TV has a blue lining that sinks in from the top left portion of the screen to the top right protion and sinks half way down. The picture is not visible within this section of the TV. Its a Samsung model: CM42W5. The only way I can watch the TV is if I cover the blue lens entirely. The picture is visible just slightly distorted and of course....no blue is present.
    Anything can help at this point.....Thanks!
  • Anonymous Oct 18, 2008
    Mine id the blue color
  • mateens Nov 17, 2008
    cm42w5 Samsung
    Red lens is "dropping" on the left side,so all images have red "copy" which is very distorted.
  • Delicatez Dec 12, 2008
    I have the same problem. The Blue lens on my Samsung 43" projection TV has a blue lining that sinks in from the top left portion of the screen to the top right protion and sinks half way down. The picture is not visible within this section of the TV. Its a Samsung model: SP43W6HPX. The only way I can watch the TV is if I cover the blue lens entirely.
  • bxfin3ztlu Jan 12, 2009
    i also have the same problems my screen is all distorted and in the top and bottom sink in..i think its all my colors..my model is a Samsung CM42W5, Model no.HCM4216W if you have any answers please e-mail me @ bxfin3ztlu@tmail.com
  • 8,617 Answers
Need your model number to help you. Please respond to this post so I will have access to your symptons when post your model number.
Posted on Jun 24, 2008
I have the akia projector tv and the numbers and letters are doubled. Also the color isn't right . Is it the auto focus ? . Please help I don't know how to fix this ...
The tv problem is call convergence problems,it dead.Tv have convergence colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.These parts must replaced on the tv convergence board to solved the tv picture convergence problems.Try website like Tvrepairworld.com might still can buy a whole refurbish convergence board for the replacement.The Akai and Samsung DLP tvs used the same convergence board.Or the shop,will cost u like $300-350 for parts and labors.
Jan 06, 2011 | Akai PT5598HD 55" Rear Projection...
Samsung Projection TV - Yellow White Level and Auto Focus Failure
perfect focus is based on service mode convergence. FActory setting as it were. the set needs to converged in service mode then these values stored then it should work
Jan 03, 2008 | Samsung PCL541R 54" Rear Projection...
Samsung rear projector tv Model SP42Q2HL HDTV ready 1080i Looks like i should b wearing 3D glasses when watching tv, Is it game over?
No,is it not.It a repairable tv.The tv have a problems known as a convergence problems,it dead.The tv colors lines R,G,B mis alignment,have colors shadows pictures or 3D pictures look alike.The tv convergence board have dead 2 STK convergence ICS and some or all it resistors too.These parts on the tv convergence board,must be replaced to solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Nov 12, 2010 | Samsung HCP4252W 42" Rear Projection...
Wavy color separation, auto focus doesn't fix problem. Doesn't have a manual focus.
Ur tv have a problems known as a convergence problems,it dead.The tv colors lines R,G,B mis alignment,have colors shadows or 3D pictures.The tv convergence board it have dead 2 STK convergence ICS and some or all it resistors.These parts,must be replaced on the tv convergence board to solved tv picture convergence.
Oct 11, 2010 | Sony KP-57WS500 57" Rear Projection...
It is like looking at 3d in all three colors. i
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
May 30, 2010 | RCA D52W19 52" Rear Projection Television
Got a samsung hcm5525w tv that i cant adjust the blue convegance, the red i can adjust, and using the auto focus only gets trough the green.
This is a common problem. Its called a convergence failure.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Video may look distorted
You can see some examples and find a fix here...
Dec 24, 2009 | Samsung HCM5525W 55" Rear Projection...
Samsung SP47W3HFX tv blue flickering curved line..
If the lines are slightly curved and stationary on about 2/3 of the screen its either the Blue CRT or the Blue CRT drive board which is having the problem.
Dec 19, 2009 | Televison & Video
Convergence issue
You would have to go into the service menu to do fine convergence adjustments - The best way to approach this is to get a service manual - available online $ at servicemanuals.net - Also double check all the 3.9 ohm resistors near the convergence IC's
Nov 06, 2009 | Samsung HC-P4752W 47" Rear Projection...
I pressed the auto convergence button now it looks like its in 3d
  • Screen looks 3D
Oct 16, 2009 | Zenith R57W46 57" Rear Projection...
53UDX10B 53 in. Rear Projection "3D vision"
the convergence IC`s and associated resistors have to be replaced, do not repeatedly push magic focus or the alignment after the parts change out will take longer which of course means higher repair bill, good luck
Nov 10, 2007 | Hitachi 53SDX01B 53" Rear Projection...
Televison & Video Logo
215 people viewed this question
Top Televison & Video Experts
