Question about Frigidaire ATF6000ES Front Load Washer
Kenmore Elite front loader
During the spin cycle, it won't go up to maximum speed, so the clothes are soaking wet when it is finished. This happened once before. The repair man came out, pressed a few buttons on the panel and charged me $100. I hope that I can fix it myself. Thanks, Carol
  • 639 Answers
Dear cs wegman,
ngfam at you service
Defective part!
Sounds like you need service!
Call A&E Factory Service /They service nation wide
And are available 24/7 for making appointments!
If the appliance is 10 years old or more,it may make sense not to invest any money to fix it!
Happy to assist you,
Neil
PS.Before you sign off!
PLEASE GIVE ME A GOOD RATING HERE ON FIXYA.COM
Posted on Aug 25, 2008
During the spin cycle it spins correctly until the last 2-3 minutes and then it just fluffs clothes
Some machines used a variable speed slow down process to avoid clothing damage, this removes the items from the outside of the drum where if the clothing was left for a length of time after the cycle has finished it could damage the fibres, this way the clothing is also easier to remove from the machine and promotes airflow over the items
Jun 14, 2016 | Sears Kenmore Elite 3.9 cu. ft. Front-Load...
Front loader spins at high speed, clothes still soaking wet? why?
I think the water is syphoning back from your waste outlet make sure the waste pipe is installed correctly
Jan 22, 2013 | Washing Machines
Clothes still wet after cycle is over
Be sure drain hose is not kinked and no higher than the top of washer to drain pipe. Remove clothes as soon as it stops spinning
Jun 23, 2010 | Kenmore 23822 Top Load Washer
I have a Kenmore frontloading washer, model no. 417.42042100. At the end of the wash cycle, the clothes are still very wet; that is, still SOAKED with water, even though all the water has been drained...
HI. your unit is equipped with a spin control board. this board, if damaged, will not initiate an adequate spin. This will not allow for proper drainage and drying of the clothes. The spin motor regulates the rotation speed during the spin cycle. It seems to be the culprit at this time. Have the spin board replaced asap.
This part will usually cost around $150.00 at the most.
Aug 27, 2009 | Kenmore Washing Machines
Washer will not turn on...
My washer makes a wierd clinky sound during wash and rinse cycle and it has began to stop spinning the water will drain but clothes will be soaked. Also sometimes during spin cycle it will agitate instead of spinning
Jun 22, 2009 | Kenmore Elite 45986 Front Load Washer
Loud banging when spinning
but a small load in . if happen then it sounds as if the bearings have gone at the back of the drum.
May 12, 2009 | Washing Machines
Clothes are still soaking wet when load is finished.
Have you tryed replaceing the motor speed control. That is also what makes the machine spin.
Sep 24, 2008 | Kenmore Elite 45986 Front Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
79 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
