Question about Rockford Fosgate Punch P5002 Car Audio Amplifier
Not working I have recently bought a rockford p5002 amp and a new audio bahn subwoofer, i hooked them all up and i got power to the amp but i got no sound.. i did for a breif moment.. but now i got nothin all the fuses are in good shape, the wires all have a good connection as far as i can tell.. it seems that if i turn the volume up on my radio the amp is taking more power because my lights will dim a little bit, but the sub is not working.. and i recently had a rockford p325.2 amp hooked up to the same wires and i sold the amp im working condition.. and now i hooked the new one up to those same wires and i got nothing .. what should i do?
  • Anonymous Sep 30, 2008
    I have the same exact problem mentioned above and would love to solve it.
Maybe you should use 4 awg wire
Posted on Sep 08, 2008
I have a old 2001 rockford fosgate 2 channel p5002 model in great condition just need to know how many watts is it and which subwoofers are compatible to this amp? thanks
Your amp is rated at 500 watts. Here is the break down of your wattage.
125x2 at 4 ohms
250x2 at 2 ohms
500x1 at bridged 4 ohms
When hooking up the amp make sure to use 4 gauge power and ground wire.
Jan 07, 2011 | Rockford Fosgate Punch P5002 Car Audio...
Bass level is the same @ all volume levels
your problem is the wiring... but it is really hard for me to see where the problem is..
is there a way for you to send a picture of what you have done?
Dec 24, 2007 | Rockford Fosgate Punch P5002 Car Audio...
Rockford fosgate p5002 amp keeps blowing fuses as soon as i turn it on.
make sure your power hasnt found its way in the the ground and vice versa
Apr 02, 2010 | Rockford Fosgate Punch P5002 Car Audio...
I have a rockford fosgate p5002 amp. I have 2 alpine 12" type-r's. I just got them bridged together and my amp keeps going into clipping mode. i tried turning down my gain and adjusting my frequency but it...
Hi unbridge the subs and run them sterio your overloading the amp and its going into protection mode. if you have anymore questions about car audio feel free to ask me...
Feb 05, 2010 | Rockford Fosgate Punch P5002 Car Audio...
Wire diagram for audio bahn AWIS12P
they are so many ways to run a dvc sub, let me know what ohms the coils are, and i will give you the ultimate bass that will hurt your hearing.
Feb 04, 2010 | Jl Audio DWC254 Mb Quart 10 Auto Bahn Car...
Rockford P5002 amp problem with thermal light and low voltage
Hello rbenwalker,
The voltage drop may not be in the actual power wire itself. The same reading on both the B+ and remote terminal probably points to a bad or high resistance ground. Try a different ground point or make sure there isn't any corrosion, paint or anything else preventing metal to metal contact.
Hope this helps.
Sep 12, 2009 | Rockford Fosgate Punch P5002 Car Audio...
Rockford P5002 not getting enough power
7 volts will not be sufficient for the amp either for power or remote. Also check to make sure you speakers wires are not crossed. If its goin it to protect mode immediately the amp is detecting a fault and is not turning on.
Sep 12, 2009 | MA Audio HK4000D Car Audio Amplifier
Amp fuses blowing and amp overheat
Does the amp heat up if you power it up with no speaker wires connected to the amplifier's speaker terminals?
Jul 17, 2009 | Rockford Fosgate Punch P5002 Car Audio...
Where to take my amp for repair
Contact Rockford for factory service.
If you don't want to send it to Rockford, ask the local audio shops who they use for amp repairs. If several use the same repair shop, it's probably a good place to send your amp.
May 25, 2008 | Rockford Fosgate Punch 500a2 Car Audio...
MY AMPLIFIER
HI SOUFBOY , Theres a few things you need to check , First make sure that your amplifier is getting an audio signal form your head unit,Check all the wires for breaks in the amplifier input, secondly make sure that your 12 inch woofers are still connected to the amp check all the wires . Thirdly check your woofers are they blown ? . The best way of grounding your amp is by scrapping all the paint on a spot on the car body inside the trunk or wherever you have it and making sure the ground wire is securely screwed onto the car body on that spot ..
Mar 19, 2007 | Rockford Fosgate Punch P5002 Car Audio...
Rockford Fosgate Punch P5002 Car Audio Amplifier Logo
127 people viewed this question
Top Rockford Fosgate Car Audio & Video Experts
seankane89
Level 1 Expert
hoyzee1
Tygh Duval
Tygh Duval
Are you a Rockford Fosgate Car Audio and Video Expert? Answer questions, earn points and help others
