Question about KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator
Freezer is only cool, everything melting
The freezer in our KitchenAid Superba side by side has just stopped freezing. Things are cool, but ice and all previously frozen meats, etc. are thawed.
Any suggestions??
  • 481 Answers
Sounds like a defrost problem. Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items.
Posted on Jul 06, 2008
No ice.... refrigerator getting warm..... freezer also getting warm
here are a couple of things to check. First look at the back inside wall of the freezer and see if it is getting coated with frost or snow. If yes, you probably have a problem with the defrost system usually the defrost heater burns out first. Once you replace the heaters, all the excess frost has to be melted off the cooling coils behind that wall. A hair dryer works well for this. Another thing t check is the fan motor that is back behind that same wall. If the fan stops for any reason--- you loose cooling on both sides.
May 08, 2015 | KitchenAid Superba KSRG25FK Side by Side...
I have kitchen aid superba the icemaker works fine, except at the door where ice is dispensed the unit freezes up the ice crusher area like there is an air leak in the door somewhere which allows warm air...
I have had this issue with my french door kitchen aid freezer drawer. I have a toddler who sometimes gets into the drawer. If it is left open just a hair, it will melt everything completely and water leaks out all over the floor.
The drain gets clogged when the door gets pushed back in for a tight seal and freezes again.
Try to focus on keeping a really tight seal every time you open and then close the freezer...its almost like you have to TRY to close it hard to ensure it is closed. Total pain, but it works. When the door is closed tight, it stays like it is supposed to .
Oct 16, 2013 | KitchenAid Superba Architect KSCS25INSS...
Our 14 year old KitchenAid Superba side by side refridgerator (Mondel KSRS22FGBT01) is not cooling the top half of the freezer section. Bottom half seems to be able to keep cold - but top half doesn't....
Do you see any ice build up on the back wall of the freezer compartment? You probably have one of the following problems: A failed defrost system, meaning the defrost timer and/or element has gone out and your evaporator coil is frozen over; you are low on freon and this too will cause your evap coil to freeze over until the freon drops so low all cooling stops; or there could be a clog in the capillary tube which is the very small diamiter copper tube that carries the condensed liquid freon to the evap coil. Unless you have gauges, a licence to buy freon and service valves (or a buddy with such) you are limited to what you can do. Here is my advice:1. unplug the frig and let it defrose over night, unplug the frig and empty the freezer to remove the back cover to look for ice, a frozen fan and if so get your hair dryer out and melt the ice so you can test the fan and the defrost element (you will need a volt/ohm meter to do the element check. You can do it.
Oct 13, 2013 | Refrigerators
Freezer not freezing ice cream and milk
Icecream is a tough call. Some brands have to many artaficial ingredients and that doesnt get solid. What temps are you getting in the freezer? Is everything else frozen solid?
Jul 17, 2009 | KitchenAid Superba Architect KSCS25INSS...
Frigidaire freezer not freezing ice cream
The freezer temp settings are not low enough or you are getting ready to have a poblem with the defrost circuit.
May 05, 2009 | KitchenAid Superba Architect KSCS25INSS...
Water inside bottom of freezer after defrost cycle
sounds like a drain clog in the freezer compartment above. remove the freezer rear panel and totally defrost the evaporator area, directly under the evap you see( under all taht ice) a small drain hole that has become frozen over, try defrosting with either a hair dryer( not a heat gun too much heat youl melt everything) or by pouring hot water donw the drain until you get a free flow of water down the tube. after its clear reassemble and you should be fine
Oct 31, 2008 | KitchenAid Superba Architect KSCS25INSS...
Kitchenaid superba icemaker leaking/freezing in freezer section
Your water hose that connects to the back of the freezer may be loose. Move the fridge out away and in the back make sure it is tightend.
Let me know if it helped :)
Oct 20, 2008 | KitchenAid Superba Architect KSCS25INSS...
Freezer freezing up
  • possible causes:
Jul 06, 2008 | KitchenAid Superba Architect KSCS25INSS...
Kitchenaid superba ice freezes in the bin
The temperature of your freezer is probably set to low allowing the ice to melt a bit, then refreeze. Try setting your freezer temp a bit lower. That should fix it.
May 01, 2008 | KitchenAid Superba Architect KSCS25INSS...
Kitchenaid superba side by side ice maker stopped producing ice
This is a picture of an ice maker module.  Which is behind the white plastic cover.  The cover just pops off.  Look at the two little tabs in the center of white wheel.  If yours is twisted, pressed together, or one is broken then the module is bad.  If not, take the icemaker out and let it set for a few hours to let it defrost.  Put it back in and see what you get.  The ice maker won't cycle and fill with water until it gets below freezing so you will have to wait awhile.  It can be started manually by inserting a jumper wire into terminal T and H.  Let it start to cycle for about 10 sec. then pull the wire out.  At the end of the cycle it will fill with water then wait for it to freeze.  Also, if door was left open check all vents in fridge for ice build up.  This cause cooling problems of they are plugged.  Let me know what you find.
Oct 21, 2007 | KitchenAid Superba Architect KSCS25INSS...
KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator Logo
289 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
rugby prop
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
