Question about Kenmore 44103 Side by Side Refrigerator
Kenmore refrigerator door
Door will open, but will not shut unless it is lifted up
There is a part on the lower door hinge & on the bottom of the door called a door cam riser & that needs to be replaced
Posted on Jun 24, 2008
Having a problem with garage door not opening from car--it used to work every time and now it only works part of the time.
Check the battery, even if you have replaced it lately. The contacts in the remote might be worn, unless you have an a solid state remote. Check the code in the garage and in the remote, make sure they are the same
Nov 24, 2014 | Master Equipment Z-Lift 42 by 24-Inch...
Power liftgate will not open with remote, instrument panel control or button in rear cargo on lincoln mkx
It can be faulty switch or its issue with lift gate latch.Its got stuck up hard or cracked inside.It has to be inspected.-----------
There are few help links with proper solutions for these problem.I suggest you to refer the links.
Click the link below:----
2007 Mercury Mountaineer: Liftgate will not Unlock or Open?
Adjust Hydraulic Lifters?
How to open rear lift gate?
--------- Power Liftgate Shuts Down
------------ Power Lift Gate Will Not Remain Open
----------- Power Lift-gate will not Operate
------------- Liftgate will Not Stay Up Open?
---------------- Rear Door will not open
------------ 2000 Toyota Corolla: Rear Door wont open from outside or inside?
These details will help.
Nov 25, 2012 | 2007 Lincoln MKX AWD
Samsung model smh7178std, shut the door and the fan and lights come on automatically, if i lift up on the door the fan shuts off but light stays on.
some switches are normally closed "short position" press switch "open" it will be labeled NC on the one side, "stands for normally closed" and others will be NO "stands for normally open" press switch "short" if there is no change in readings when you press switch it is defective.
Mar 28, 2012 | Samsung SMH7178STD Microwave Oven
When i close the door on my 95 chevy corsica it doesnt close. it just bounces back. please help im a girl and my parents dont know so use small simple words please.
I think what has happened is that the door latch (the one in the door) has somehow closed and won't let the door shut normally.
Here's how it works. The door latch consists of two major parts. One is the short, round metal tube thing that is attached to the car body about halfway up where the door shuts. Inside the door there is a latch in a slot that lines up with round metal tube thing when you shut the door. I think what has happened is the latch has closed, not allowing the door latch to slide over the metal tube thing and close completely. If you look at the latch in the door slot you'll (hopefully) see what I mean. Now how to fix it.
You'll need a medium to large screwdriver and maybe some help from a friend. First, lift the outside door handle like you are going to open the door. Hold it up. Then, with the screwdriver, push the latch in the door slot UPWARD until it clicks and latches.
It is difficult to put this in words but it usually is an easy fix. No damage done to your car (unless you REALLY slammed the door hard numerous times..).
Please re-post with any questions.
Mar 01, 2010 | 1995 Chevrolet Corsica
Won't shut off unless the door is opened
Usually the only thing that will stop the dryer is to open the door or turn the timer to the off position.
Nov 24, 2009 | Dryers
My garage door will open about a foot then stop. I can't find anything obstructing the path of the rollers, and the chain goes all the way through the cycle. Does anyone know what could possibly be the...
2 possible problems.
1 might be your door springs need to be adjusted causing a more than normal load on the opener. Test this by disengaging the opener and open the door by hand. A properly balanced door should only require minimal effort. If you struggle to open it manually then the torsen springs need adjusted. Caution- they are under high torque and unless you have the knowledge and tools required don't attempt this yourself.
2 the open force needs to be adjusted on the opener. there are 4 adjustment screws located on the opener. Two are for travel distance-one for each direction. The other two are for force adjustment, one for each direction.
Aug 26, 2009 | Liftmaster, Chamberlain, Sears Door...
Passenger door dropped on my Daewoo how do i fix
Hi David,
It's either loose hinge(s) or a loose lock.
The lock is easier. Make sure the mechanism within the door is secure. The screws tight. That there is no movement of the latch assembly.
Next the hinges:
With the door fully open, position yourself so you can observe the hinges while lifting the door. It will be easier with a helper.
You are looking for movement at the mounting points of either hinge. Check mounting bolts and tighten where necessary.
Comment me back with the results.
Best regards,
Aug 22, 2009 | 1999 Daewoo Lanos
Chevy Blazer door wont close....
Not sore if you have the answer or not. Here it is. MANUALLY place interior door lock latch in the UNLOCK position. Now LIFT UP outside door handle as if opening. While holding it up with your finger ( no prying ) lift up closed latch. Now you should be able to close your door normally.
Apr 01, 2009 | 2002 Ford Escape
Bottom hinge on fridge door broken
Yes, there is supposed to be a plastic bushing/washer under there. Usually 1/8 inch thick. If a dealer is not handy you may cut some out of plastic to put there. Then undo the top hinge, and carefully lift the door off (you might want to empty the shelfs). Put your spacer on the hinge pin, and replace the door and the top hinge.
Jan 28, 2008 | Liebherr Premium CTP 3153 Top Freezer...
Kenmore 44103 Side by Side Refrigerator Logo
152 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
