I have checked the lever and adjusted accordingly,but theres no change,and i believe its an application problem,i also went through the amnual to try and troubleshoot,but to no avail.Is there a way that i can change the font and the pitch perhaps on the printer,i tried following the intructions about changing printer default settings,and im struggling with making changes from the printer control panel.On the printer properties on the PC,i tried everything that i know,and still nothing.Pls help!
Changing the default settings in the printer using the printers panel may be a bit difficult but it should be manageable. As soon as you enter the default setting mode it will print a guide, the guide will include the current setting. The guide will also give you the corresponding value of a certain setting according to the status of the light. The first two boxes will correspond to the font lights and the last box on the guide refers to the pause light. pressing the lf/ff button cycles through the options and pressing the tear off button will select the current option and cycle through the options as well.... However, in any printing environment, the setting in the APPLICATION OVERRIDES the setting in the PRINTER. So, whatever setting you select in the printers' default will be overridden by the applications' settings....
