Question about Nvidia GeForce 6600 Graphic Card
My memory goes down
When i've put the card, my memory performance ges down is it normal??
Here's my PC:
AMD Atlon XP 2200+
1GB Ram
160GB Hard Drive
Just installed vista business ( I was getting that problem when i was using Windos XP)
  • BIOS21 Jun 24, 2008
    Switch to Ubuntu??? what's that???
  • BIOS21 Jun 25, 2008
    My motherboard supports 8X AGP..... according to you how much memory does it take???
  • 137 Answers
Switch to Ubuntu. ;) If that's not an option then maybe aquire some more RAM. The only way your performance would decrease is if the card is using some of your available memory, that is your install 1GB of RAM. If that's not an option, purchase a USB thumb drive 2GB + and use the ready boost feature in Vista.
Posted on Jun 24, 2008
  • 1 more comment
  • nsindian
    nsindian Jun 24, 2008
    Does your motherboard support 8x AGP? If it's locking up or freezing then maybe check your mobo manual for the specs.
  • nsindian
    Ubuntu is an open source operating system based on linux.
  • nsindian
    nsindian Jun 27, 2008
    Not sure what you mean by "how much memory does it take???" The adapter/card uses it's own memory not your available RAM, unless you tell it to in the BIOS settings.
How to instal window XP into Acer aspire T180
The Aspire T180's single-core 2.4GHz AMD Athlon 64 3800+ processor and 1GB of RAM hamper its performance right out of the box, keeping it from being even a passable fit with the Windows Vista Home Premium OS we've seen on other budget machines. (The Aspire ships with Vista Home Basic.) The 160GB hard drive is also on the small side, and the nVidia GeForce 6100/nForce 430 MCP integrated graphics are not exactly top-notch tech, either.
You do, however, get a few bonuses. The software selection includes a 90-day trial of Norton AntiVirus 2006, as well as CyberLink PowerDVD, NTI CD-Maker Gold, and Acer's own performance, recovery, and security tools. And the PC does offer good expandability. Two RAM slots are free, as are an external 5.25-inch drive bay, three internal hard drive bays, two PCI Express (PCIe) slots (one x1 and one x16), and one PCI 2.2 slot. (A modem occupies a second PCI slot.) So it's possible to bump up the Aspire T180's power a bit with some carefully chosen components.
To load Win XP simply select CD-ROM BOOT option from BIOS(hit DEL / F2 key while starting up power), insert a bootable WinXP SP 2/3 CD, depending on it being Genuine Microsoft product or a cracked ver.). When prompted to hit any key, do so & follow instructions on the screen. This is assuming you are doing so for the first time, make 2/3 partitions, else re-install on 'C' Drive after formatting it. Use NTFS partition option. If any probs, pl write back & I'll give more detailed instructions.
Apr 17, 2012 | HP Pavilion zd8000 Notebook
I have a emachines amd athlon 64/ 512mb memory / 160gb hadr drive dessk top. when i turn it on the monitor displays no signal and goes off. ihear the prossessor motor running constantly which normally goes...
Please check the cable that connects the monitor to the video card. Reseat the cable, the issue might be a loose connection. You can also try a known good monitor to isolate if it's the video card or monitor that is causing the problem. Something is preventing the monitor from receiving signals from the video card, hence the "no signal" message.
May 19, 2011 | eMachines Desktop / AMD Athlon Processor /...
Can I Play gta IV/4 on my pc? Specs Ar As Follow: DELL PRECISION 650 With: 2X Seprate Intel Xenon CPU's @ 2.40Ghz Each (4.80Ghz Tot) 1.50GB RAM (Memory) 80GB IDE Primary, 40Gb IDE Seccondary, 40GB...
Minimum System Requirements
  • OS: Windows Vista - Service Pack 1 / XP - Service Pack 3
  • Processor: Intel Core 2 Duo 1.8Ghz, AMD Athlon X2 64 2.4Ghz
  • Memory: 1.5GB, 16GB Free Hard Drive Space
  • Video Card: 256MB NVIDIA 7900 / 256MB ATI X1900
Recommended System Requirements
  • Processor: Intel Core 2 Quad 2.4Ghz, AMD Phenom X3 2.1Ghz
  • Memory: 2 GB (Windows XP) 2.5 GB (Windows Vista)
  • 18 GB Free Hard Drive Space
  • Video Card: 512MB NVIDIA 8600 / 512MB ATI 3870
Source :- IGN PC
this is what it says on the box...so if you dont have these specs..forgett it!!
Jun 15, 2010 | Rockstar Games Grand Theft Auto™ IV for...
My hard drive never stops
Windows is probably constantly trying to create virtual memory using the hard drive's free space. Buy more RAM and/or create a larger virtual memory file. If it's Windows XP, try right-clicking on My Computer, Properties, Advanced, Performance, Advanced again, Change (under Virtual Memory), increase the Initial Size to AT LEAST what is "recommended" lower down on that screen but no more than 1 1/2 times the actual physical RAM, then click Set.
Jan 01, 2010 | AMD Athlon 64 X2 3800+ Dual Core Processor...
Cost of game hardware in india
2GB RAM should be about $100, the same for installation. Your current graphics card meets the specs you provided. An upgraded video card will be about $200 for one that will work, $300 for one that will work well.
Jan 19, 2009 | Computers & Internet
Windows Virtual Memory Minimum is Low
fairly normal occurrence but you should have a look at your performance settings
go to control panel
double click system icon
click the advanced tab at the top
by performance click settings
in pop up window click advanced tab
at the bottom you'll see virtual memory
click change
most common option now is to set the radio button to system managed size
you should then ok each window.....
Dec 30, 2008 | HP Pavilion a620n (PC028A) PC Desktop
FREEZE
this happens if the rams are of different frequencies have a check with the both the ram frequency ...
if they are different then remove 1 ram ....
& try increasing the virtual memory in the OS ...
if you are using the windows xp .. then to increase the virtual memory just go to
control panel >system>advanced>advanced>virtual memory settings>increase the virtual memory for the drive in which the os is installed ....
increase nearly to the double of the ram memory you use ....
this solves your problem ..
any doubts you can reply me
i am always here to assist you
thank you
bye .....
dnt forget to rate the solution ...
Jun 22, 2008 | MSI KM4M-L Motherboard
My PC freezes!!
please add another 1 gb RAM to your system. then the computer does not get freezes
Jun 17, 2008 | MSI KM4M-L Motherboard
Nvidia GeForce 6600 Graphic Card Logo
43 people viewed this question
Top Nvidia Computers & Internet Experts
David
David
Alun Cox
Are you a Nvidia Computer and Internet Expert? Answer questions, earn points and help others
