Question about Gateway FPD1975W 19" LCD Monitor
Monitor issues My screen keeps going into like a sleep mode, when I power it on and off it comes back on then it goes back to a black screen
  • 3 more comments
  • Anonymous Aug 26, 2008
    Screen is black and any button you push on the monitor it will say the monitor is going to sleep. The mouse doesn't wake it up.
  • Rosie89 Aug 26, 2008
    The monitor has a black screen and keeps going to sleep with every button you push on the monitor. The mouse will not wake it up either.
  • mdhahn1 Sep 05, 2008
    monitor goes into sleep mode; not acticvated by the n
    mouse
  • jacqueline8 Oct 24, 2008
    my screen turns black after like 5 or 10 mins of being on but i can still faintly see the desktop, and if i have music playing, it continues on playing
  • Anonymous Feb 22, 2009
    turn on comp and monitor goes into sleep mode right away
Thank you, but that will not work because you only have approximately 2 seconds to do anything before the screen goes black. The best solution I found was to dispose of my frustration for $1 at the recycling bin and purchase a new monitor. My Dell was less than half the cost and has been working wonderfully.
Posted on Oct 23, 2008
  • 47 Answers
Well i think ur screen saver setting r responsible for that if u increase the time ur problem will be solved. or ur power setting r responsibe for that u need to change the time setting there to . u can do that by clicking on start then going to control panel then power settings.
Posted on Oct 22, 2008
Mark_Webber
  • 472 Answers
SOURCE: Black screen
Faulty capacitors in the power supply will cause this to happen.
The capacitors will be sending out bad current to the controller board and give you the results you are seeing.
Take it to your local TV repair shop and get them to change the capacitors, it should not cost alot to have it done.
Hope it helps =)
Posted on Apr 09, 2008
pgh_pa_guy
  • 2992 Answers
SOURCE: monitor stuck in sleep mode
It will do this when it's not getting a video signal from the computer. Make sure that the signal cable is firmly plugged in at both ends. Also verify that the computer is actually starting up. The monitor may not be getting a signal because the computer isn't sending any.
Posted on Apr 17, 2009
  • 14 Answers
SOURCE: Screen keeps going black
you may need to change the video output to output 1 in your pcs monitor settings - if you have 2 outputs from pc, swap cable over and select identify monitor. the default for the monitor should be 1( a huge 1 over the display appears)
Posted on Aug 13, 2009
  • 732 Answers
SOURCE: My monitor does not power up when I come out of
mishwilly. If monitor will do same thing with different KNOWN GOOD pc, then monitor will need it's "switch-mode-power-supply" fixed. Could also need CCFL inverter circuit checked! Do you have warranty service? Follow the links to other web sites that you find in my FIXYA profile to read about other options open to you. 12fixlouie Read, read, read.
Posted on Feb 05, 2010
  • 3 Answers
SOURCE: hello
I FIX LOTS OF COMPUTER, AND MY ADVISE IS. IT MIGHT BE YOUR COMPUTERS VIDEO CARD CAUSING THAT PROBLEM . ALSO CHECK FOR VIRUSES THEY CAN DO STRANGE THINGS.
Posted on Mar 17, 2010
Hyundai monitor on for 5 minutes and screen goes black
Have you ever opened up the monitor to clean the dust out,it could be your heating up and then letting it sit will bring it back.If your unsure how to do this ask a tech.
Apr 21, 2017 | Hyundai X224W
When my computer goes into sleep mode and the monitor goes off i have to keep turning the monitor on and off by the power button on the monitor to get it to come on. I hear a static sound and the screen...
Assuming you are using a windows operating system, go to the control panel under the start button. Find power settings and turn off hibernation mode. Sleep mode should be ok. Additionally, on the monitor, find the menu button that pulls up the OSD (on screen display) and see if there is a ECO mode or power saver mode and turn it off as well. Good Luck.
Nov 03, 2017 | ViewSonic VG2021m LCD Monitor
Why does my HP vs17 monitor screen keep going to blank black screen like it turned off but did'nt.....blue power button light is still on? Everything is running but no picture.....keeps happening everytime...
this old monitor has 2 issues.
1: it has CCFL tubes that love to burn out (backlamps)
most this old are long go, yell,dim.,blinking or DEAD.
2: push the menu button on front of mon. turn off power saver.
3: if the PC goes to sleep, or hibernete mode (parked)
then that is 100% normal
if you dont like feature then go to windows control panel
click power, ICON and turn off all monitor sleep /hibernate modes.
that assumes windows, no OS stated.
if the lamps are dead,
use flash light pointed to sceen, see data. ? bingo for bad CCFT tubes.
as seen here
http://www.pcdied.com/monitors.html#flashlighttest
Jan 12, 2018 | HP Vs17 17" LCD Flat Panel Monitor
I have a HP vs17 monitor that keeps going to sleep. It will flash to windows when I first start and immediately goes into sleep mode. When this first happened, I had managed to make sure any sleep modes,...
trixieb1, It's NOT going to sleep mode. Use warranty if possible!! If that not option you will need to read about "cold-cathode-fluorescent-lamps" and the voltage inverters that power them. Learn to do flashlight test when screen goes to black or blank n black!!! Read my fixya profile and those of other ccfl back-lit lcd monitor technicians. We already know what is wrong with your unit. And It is a VERY big problem for all LCD monitor manufacturers. Just do some reading before you do anything else. Good luck with the repair. 12fixlouie
Mar 31, 2010 | HP w2207 Monitor
My monitor goes to sleep and doesn't come back on.
For that when you power up the computer press F8 key then enter in enable vga mode .
Then go to display property and set screen resolution to 1024*768 then apply and ok.
if still not work then try safe mode then uninstall graphic driver and reinstall.
When you power up the computer press F8 key untill you see windows logo.
Let me know if you need further assistance.
Thanks for using Fixya.
Feb 07, 2010 | HP w1907 LCD Monitor
Monitor Goes black, or flickers on and off
The high pitch sound is coming from the inverter. It is faulty and needs to be repaired or replaced. The inverter supplies high voltage to the CCFL lamp, this lamp gives the backlight to the LCD so you can see the LCD images.
Check out LCD parts for parts, service and DIY info. use this link :-
www.lcdparts.net
Aug 29, 2009 | ViewSonic OptiQuest Monitor
Monitor goes to sleep and won't wake up
You can google search for an app called NOSLEEP.EXE
It was written by a Symantec employee to keep your screen active regardless of pic settings.
Install and run it. That will verify the issue is with of or monitor
Software is free
Apr 09, 2017 | Mag Innovision LT776s 17" LCD Monitor
Monitor in sleep mode
I think it maybe time to buy a new monitor
Aug 09, 2017 | X2Gen MG15VT 15" LCD Monitor
Dell Latitude cpx
Symptoms of a Bad Video Driver
Monitor Resolution issues:
screen flickers, screen is cloudy, screen shows horizontal lines, screen goes black, goes blank, goes into sleep mode, goes into power mode, size magnifies or reduces, video is jittery, fonts change, screensaver will not appear, cannot extend display on dual monitors.
Download it from here
VIDEO DRIVER FOR LATITUDE
May 28, 2008 | Dell Latitude CPX Notebook
Gateway FPD1975W 19" LCD Monitor Logo
283 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
