Question about Tomtom GO 910 GPS Receiver
Will not charge in car
Replaced the mount kit and the 12v car charger as these items where stolen from my car, these are genuine parts. I was charging the unit in the house in a 240v charger with no problems when I plug into the 12v in the car the green light is on but it will not charge up. If I fully charge the unit on a 240v then plug into the car it only lasts between 6 – 8 hours then is flat and will not turn on. I have tried different cars with the same effects. Could this be a problem with the unit or the new charger? I know you would need the unit to test it properly so where are you based and how do I send it with the charger etc.
  • Ribz Jul 28, 2008
    Pilki i have the same problem, though with the original items.
  • flissporka Sep 04, 2008
    I have EACTLY the same problem with my Tomtom ONE XL GPS.
Posted on Jul 28, 2008
How to charge it
Hi Stacey
How to charge "what model" Cell Phone
iPhone & others usually charge from the USB cable that it comes with.
Plug into any USB port (5v DC)
Some chargers supply more current which can give a faster charge. iPad chargers supply 2A where as iPhone chargers are 1A
Sep 13, 2015 | Cell Phones
Starter relay location
hi... on toyota cars the radio and charger socket are on the same fuse . try that one. god luck
Mar 02, 2014 | Toyota Tundra Cars & Trucks
My battery charger , olympus LI-40C blinks red and does not charge battery
Buy an el-cheepo battery charger kit and charge the batteries.
the olymup charger doesn't like non genuine batteries.
Dec 30, 2011 | Olympus FE-20 Digital Camera
Hi my nokia n97 mini is not charging properly and isnt turning on either. i have two chargers for it. the plug-in wall charger is about 2 months old and i have an in-car charger which is about the same...
Make sure your battery isn't fully drained. Make sure your battery has at least 3.1 V. Anything above that is good. You can check this by using a voltmeter/multimeter
If the battery is OK, make sure both of your chargers are working. Both of them can be bad. You know, there is a posiblity.
If the chargers are fine and the battery is fine, it's probably a hardware fault. Hand it over to a repair shop
Jun 19, 2017 | Nokia N97 mini Smartphone
We have bought a battery charger HB 1206S DC6V - 12V 6AMP, but it does not state what is the state of charge do the lightes go out when it has reached changed state or light up please help
Product Detail Model No.: HB-1206S
The item is used for charging 6V-12V lead-acid batteries
Max Charging Current: 6A
AC Power Input: 64W
Output: 6/12V DC 3. 52A
Batteries Capacities: 15AHR-80AHR
Unit Packing: Colorful box
Dimension: 18cm x 10cm x 20cm
G. W. / N. W.: 1. 85KG/1. 75KG
Certifications: GS, CE, BS, ROHS, SAA
Main functions:
(1) The HB-1206S battery charger has the features of convenient operations, reliable safety and high performance.
(2) During charging, if turn up overload, the battery charger will keep itself at normal current and normal voltage with its self-automatic protecting function.
(3) If being short circuit, the battery charger will switch off itself, and turn normal after one or two minutes.
(4) The output current of the battery charger is very stationary, so it can protect the battery charger very well. It only costs 3 or 4 hours to fully charge the batteries.
(5) Indication of charging: the battery charger has 6 pilot lamps. The more pilot lamps shining, the less electric quantity is. The charging process finishes when all the pilot lamps go out.
(6) The battery charger can be switched between 6V and 12V, so it can charge for 6V and 12V accumulators. You can select 6V or 12V according to your own needs.
(7)The operations are very convenient: Put the red clip to the positive pole of the accumulator which indicated "+", and put the black clip to the negative pole of the accumulator which indicated "-", then plug in power source, the accumulator will be charged.
Aug 02, 2011 | GPS
My garmin nuvi 260 will not take a charge
garmin navs are famous for there chargers burning out. first check the fuse at the end of the 12v car charger by unscrewing the tip of.if its blown replace it. if its not blown then the charger has burned out there are after market chargers but only garmin chargers will work!! as garmin use a sensor to detect the correct type of charger is connected so be sure to buy a genuine garmin 12v charger
best of luck
please take the time to rate this repair.thanks
Aug 03, 2010 | GPS
Batterys dont keep there charge i think the batterys need to be replaced
before you dump those batteries, check the charger. If the battery when charged runs the tool but dies out quickly then you are probably right. If the battery never seems to be charged at all, then it may be the charger.
Dec 10, 2009 | Hitachi DS14DVF3 14.4 Volt Ni Cad 3/8 Inch...
Tomtom GO 910 GPS Receiver Logo
290 people viewed this question
Top Tomtom GPS Experts
LP
k24674
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
