Question about TruTech PVS12701 Portable DVD Player
TruTech TV dw19tt video problems with dvd player
My dvd player only works if I plug the video and audio cables into the front of the tv. When I plug them into the same jacks in the back, I only get audio and no video.
  • 6 more comments
  • mtyler48 Jun 24, 2008
    There are only 2 settings..line and cable. I have line selected and can hear audio but see no video
    TV is pretty new and it has never worked in the back. I do have the right channel on.
    I don't understand sweet rascals response..
    I'll try blowing the jack out but since it never worked from purchase it probably is a bad jack. thanks for the contact to customer support however the link for the manual is not my tv it is for a dvd player.
    i have some knowledge of electronics and can attempt the replacement. i didn't want to do that if it was a setup issue.
  • mtyler48 Jun 25, 2008
    TruTech TV dw19tt
    cables are in audio out and video out..colors match
    blowing air did not work..manual link posted not correct manual
    Brigadier General:
  • 6,966 Answers
Based on your postings, it is not a setup/configuration issue, it is a hardware issue. Your TV has only two (2) source settings: line or cable. The "line" has two possible connection points, front and back. the front works but the back does not and you'd rather use the back. Corrective measure would require that you open the back of the unit, chances are 2 ~ 4 screws, the 3 RCA females would be soldered unto a smaller PCB. As VOTIT has posted, check the yellow RCA (video). Most likely problems would be cold or no solder, cracked PCB trace, loose connector, stretched/open wire or even in some cases, wire(s) simply not connected.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Jun 25, 2008
  • 4,234 Answers
Tech48 has it correct. It is a common problem for poor solder connections to exist on the jacks. While rare, the video switching chips have been known to be defective as well which would show up as the audio working without the video. The audio section is switched using a different chip. You have stated that this has never worked. If by chance, the unit is still in warranty, you should be able to get this repaired for no cost. Even if the chip is defective, this is a simple repair and should not take very long.
Keep use posted.
Dan
    President:
  • 624 Answers
Since the audio works on the back jacks on the TV, you have it plugged in right. If you switched the audio and video around you would not get audio from it.
If you have audio from it, you have the right input selection on the TV
Since the audio and video both work on the front jacks of the TV you know that the DVD player is not at fault.
This only leaves one option, the jacks on the back of your TV for the video are not working. It could be a bad solder connection. But it could also be the buffer IC that is on the input board in the back of the TV.
Those are the only really likely problems. Check the solder connection, and if they look good you may just need to take it to a service center. Replacing the buffer IC may not even fix it. You may have some other problem like a shorted transistor or somethiing in that cicuit. The only real way to tell is by doing some real electronic troubleshooting. Anything else is just a guess.
If you have a multimeter and an O-scope and the knowledge of how to use it, you can check the components around that cicuit. It could even be a faulty switching IC. It is going to take a little experience with this type of troubleshooting unless you just have a broken solder joint connection.
Let me know if you want any more help from me.
Posted on Jun 24, 2008
  • Dave DeGain
    Dave DeGain Jun 24, 2008
    One other thing, try connecting a different video device into that jack on the back of your TV. If it does not work, just like the DVD player, that isolates your problem to the TV.
    If you have the option to select different video inputs (like composite, s-video, component) from one source (like video 1 or video 2) just double check that and make sure you have the proper video type selected.
    Master:
  • 788 Answers
What brand and model of TV do you have? I will look up its manual and see the rear input needs activation. Thanks.
  • Dean Joly
    Dean Joly Jun 25, 2008
    If you are plugging your cables to video out and audio out then you will not get a picture or sound. The cables need to be plugged into the video in and audio in of your TV. There is definitely possibility that the only input on this TV is in the front as the TruTech brand seems to be made rather cheaply, there is a lot of dissatisfaction with this Target house brand around the Internet.
  • 2,071 Answers
Your problem is a loose video rca jack at back of your tv ,this common problem of jack connection when the solder there is crack,this the cause no video..this very easy to do just open your TV when open,already locate the your video jack (at edge of cercuit board) when you see video jack renew the solder by soldering iron 30 watts its ok.,,when finish close the TV ..thats it all mtyler..
  • 1 more comment
  • LORETO LACARON
    LORETO LACARON Jun 24, 2008
    the color of the video jack is yellow..
  • LORETO LACARON
    if tv is new and see a video in front connection but when back connection only audio sound maybe you interchange in connection of video one to video 2 this only thing i see this not in setting because you hear audio sound maybe the rca cord near to cut ,some times work , sometimes not checked this .interchange or near to cut intermittent,..
  • LORETO LACARON
    if you do interchange the cord and nothing happen buy a new rca jack cord and if this still you cannot see video ,then my solution above is the best for this.even it new it will factory defect maybe..or use the warranty if covers the warranty....
    Master:
  • 638 Answers
Before doing all this reparing work just clarify your sely that you are inserting the wires of video in the proper jack try interchanging the wires in the jacks then start further some times the silly mismatch creates this problem.also try cleaning the inner side of jack by blowing air through your mouth or air blower if you have it,minute dust can also be the problem.then try the further solutions.
this is the link to help you to get the manual of your product.
http://www.1800customersupport.com/productdocuments/PVS12701_TruTech.pdf
or
the video card must be faulty and is not supporting in the back jack of the tv replace that.
or
the video unit on the back side of your tv unit is faulty for sure get it repaired.
rate the solution as FIXYA if this helps you solving your problem.
    Guru:
  • 1,894 Answers
What is doubt in this?
the video jack in back alone is not working
  • dewan nafees ahmed Jun 24, 2008
    you are telling that the video jack in back side alone is not working right??
    there is nothing to do with settings of TV i think.
    u just need to change the back jack alone.
    that is not a difficult job. if u have a knowledge about electronics u can check it easily and change it.
  • TruTech Master
  • 13,433 Answers
The back video jack must be faulty, have you tryed useing any other device on the jack in the back? Make sure you are watching the right channel when you connect it to the back.
  • Ekse Jun 24, 2008
    Make sure you have connected the right cables to the right connectors you may have placed the 2nd audio cable over video.
  • TruTech Master
  • 19,396 Answers
You need to switch the tv imput to the proper connection when you plug the cable at the back. use tv input selection from remote.
Connect DVD player to TV red white and yellow wires
1. Connect the audio cables to the AUDIO OUT L (left - white) and R (right - red) jacks on the back of
your DVD Player, and to the corresponding Audio Input jacks on your TV.
2. Connect the video cable.
• Basic video connection
- Connect the video cable (yellow) to the VIDEO OUT jack on the back of
your DVD Player, and to the Video Input jack on your TV.
OR
S-Video
(optional) - If your TV has an S-Video Input jack, connect the S-Video cable to the
S-VIDEO OUT jack on the back of your DVD Player and to the S-Video jack on your TV. If your
TV doesn't have S-Video, use the basic video connection listed above.
Mar 18, 2014 | RCA RC5240P DVD Player
Sanyo TV connect to cable box connect DVD player
If your DVD/VCR combo player has three RCA connectors (yellow, red, and white), you can connect them to the corresponding inputs on the front of your TV.
Dec 29, 2012 | Sanyo Televison & Video
How to connect samsung dvd to samsung tv
Follow these steps: Component Video Connection 1. Get a component video cable. This cable has 3 sets of connectors, one each for the red, blue and green color signals.
2 Match the connectors to the appropriate video output jacks on the DVD player. Component video outputs will normally be labeled Cr/Cb/Cy. The Cy output jack is matched to green, Cr to red and Cb to blue.
3 Run the cable from DVD player to the TV. Most TV connections are made from the back panel, but this may vary.
4 Match the connectors to the appropriate video input jacks on the TV.
If using S-Video Connection
1 Get an S-video cable. This cable has a single round connector with 4 pins.
2 Attach one end of the S-video cable to the S-video output jack on the DVD player.
3 Attach the other end to the S-video input jack on the TV.
Composite Video Connection 1 Get a composite video cable. These types of cables are frequently bundled with two-channel audio cables. Composite video cables are tipped with yellow plugs.
2 Plug one end of the composite video cable into the composite video output jack on your DVD player.
3 Plug the other end into the composite video input jack on your TV.
May 14, 2011 | Samsung Televison & Video
How do i connect a DVD player?
Use three RCA cables, yellow, white and red to connect DVD player to TV as shown in the diagram below. Connect yellow to yellow and white to white. Connect red to red. Select on the TV, the A/V input where the DVD is connected using the TV remote control. Power on TV and DVD, place a disc in tray of DVD player and press PLAY.
Mar 28, 2011 | Toshiba 22AV600U 22 in. LCD TV
Whehe do plugs go on back of unit? have direct tv
First off, you need to hook up audio and video by using an A/V cable to connect the DVD player to the TV, yellow, white and red jacks are coded, match the jacks up, put one end of A/V cable to DVD player OUTPUT jacks and the other end to INPUT jacks in back of TV. Also same with Direct TV receiver, hook top set of jacks to TV, with A/V cable, also connect coaxial cable from satelite to matching satelite input jack. Connect power cables, and then you're set. Good luck to you!
Dec 12, 2009 | Televison & Video
Cannot get DVD's to play on our TV.
It depends on what kind of inputs your TV has; here are a few of the most common, all of which your DVD player supports (best quality first):
1) COMPONENT VIDEO (Red, Green, Blue)
If your TV has three inputs for video colored red, green, and blue, this is your best bet for quality video from your DVD player. You may need to buy a component video cable from the store (somewhat pricey, but great quality) which consists of three cables (again, red, green, and blue) stuck together. Just plug the red/green/blue cables into their correspondingly-colored ports on both the DVD player and the TV.
That covers your video. To set up audio, you just need some regular red/white RCA cables. On the DVD player, plug the red/white cables into the correspondingly-colored audio out jacks NEAREST to the red/green/blue cable you used earlier for video, then plug the other end into the audio in red/white jacks on the TV.
2) COMPOSITE VIDEO (Yellow)
If your TV has a yellow input for video, just use a regular yellow RCA cable. Plug it into the yellow video-out jack on the DVD player, then plug the other end into the yellow video-in jack on the TV.
To set up audio, you just need some regular red/white RCA cables. On the DVD player, plug the red/white cables into the correspondingly-colored audio out jacks NEAREST to the yellow cable you used earlier for video, then plug the other end into the audio in red/white jacks on the TV.
3) COAXIAL JACK (Antenna port)
If your TV only has a coaxial jack that you currently plug your antenna or cable line into, you'll need to buy an RF modulater and a short length of coaxial cable (you can find these anwhere: Walmart, Radio Shack, etc).
Plug the RF modulater into an electrical outlet, then plug your antenna/cable line into the "antenna in" jack on the RF modulater. Take the coaxial cable that you just bought and plug it into the "antenna out" jack on the RF modulater, then plug the other end into the antenna/cable jack on the TV. The RF modulater should have a switch on it somewhere that sets either the number 3 or 4; depending on which number you pick, that's the channel that your TV has to be switched to to view the DVD player.
Now you're all set to connect to your DVD player. Just follow the instructions in section (2), only now you're going to plug your cables in the RF modulater instead of the TV.
(I hope this wasn't too confusing; it really is a lot simpler in practice than it is in explanation...)
May 04, 2009 | Televison & Video
Cable connection part broke off in back
Are you talking about the part that connects the cable from the wall to the tv? I do not really understand which part on tv or vcr. It is true you can use the vcr as the tuner. You still have to connect the cable from the wall to the input cable jack on back of vcr. Then you hookup the R/W/Y rca plug- in cable from the back vcr output jacks (which are also color coded) to the tv's jacks. If you only have two jacks on the tv they will probably red and black. It doesn't really matter. Go from your video output on the vcr to the video input of tv, then use one of the audio outputs on vcr and go to the audio input on tv. It should work like that.
Jan 14, 2009 | Philips Magnavox DVD/VCR Dual Player
Sony CD/DVD Player DVP-NS501P
There are several ways to connect the TV to the DVD player but you can only take advantage of the progressive scan option on your player if you use component cable. Component cable has three input jacks on it and they are colored Green, Blue, and Red. Your TV/amplifer must have component input jacks on the back of it to use this cable. If it does, then the input jacks on the back of the TV are usually labled Y, Pa, and Pr. The Y input is for the Green input jack, the Pa input is for the Blue input jack and the Pr is for the Red input jack. Once you have these plugged in you will next need to hookup the audio/vidoe cable that came with your DVD player that has a Yellow, White, and Red input jacks on it. The Yellow input jack is for Video and the White and Red are for audio. Both your TV and DVD player will have inputs for these so just match them up. If you do not have component inputs on your TV then just hook up the audio/video cable and it will work.
Nov 07, 2008 | Sony DVP-NS501P Progressive-Scan DVD/CD...
DVD player hook-up problem
Using the composite video connection method is pretty straightforward. you will be dealing with one video cable (marked in Yellow), and two audio cables (marked in White and Red) Red is right channel and white is left channel if stereo, if mono use the white marked cable. Look at the back of your DVD player you will see the video out RCA jack (marked in yellow) plug one end of the video cable into this jack, the plug the other end of the cable into the TVs Video In jack (marked in yellow) Then plug the audio cables into the Audio Out RCA jacks of the DVD player Red marked cable to red jack White Marked cable to white jack. After this is done plug the ends of the sother side of the cable into the Audio input of the TV white to white, red to red. At this point you should have video and audio once you set the menu of your tv to accept input from the Composite input and the audio jacks. I hope this helps.
Sep 10, 2007 | Televison & Video
TruTech PVS12701 Portable DVD Player Logo
126 people viewed this question
Top TruTech Televison & Video Experts
Jason Morris
Are you a TruTech Televison and Video Expert? Answer questions, earn points and help others
