Question about Durabrand Televison & Video
NULOCK REGION Trying to find region unlock code for a LEDVDR0701 DURABRAND DVD RECORDER
  • 376 Answers
All the functions to be carried out with the remote control
With the "Power" button turn the player on
Open the tray
Press the "Clear" button
With the numbers keys press
13690
Close the tray
Turn to standby with the "Power" button
This will work but no indication is given on the screen as you do it.
Posted on Sep 09, 2008
Unlocking multi region code for panasonic dvd/recorder
Panasonic DVD recorder and players will only support the region of which the recorder or player was made in.
Nov 06, 2013 | Televison & Video
Need free region code unlocker - Panasonic DVD Recorder DMR EA-18
you can't unlock the panasonic DVD recorders. I have one and have tried different soloutions on the net but found out they can not be un locked !!!!
Jul 17, 2009 | Televison & Video
I would like to change regions on my portable Durabrand DVD player model PDV-722
Alright, just follow these steps and let me know if you have any problems or questions
  1. Power and switch on the Durabrand DVD player.
  2. Open the DVD disc tray tray or lid.
  3. Press Stop.
  4. Press 3 - 5 - 9 - 7 (3597 in sequence). Can be done on remote control.
  5. Hidden DVD Region menu appears. Select region 0 or 9 using up or down button on remote control
  6. Press OK.
  7. Close the disc tray and press Standby on the DVD player front
Dec 19, 2008 | Televison & Video
Multiregion conversion
go here
http://www.mydigitallife.info/2006/12/24/hack-to-unlock-durabrand-dvd-players-region-code/
Jun 26, 2008 | Durabrand STS92 System
Would like to unlock region codes from dvd/hdd combo recorder
hi
you can try to change the region to play using your dvd by highlighting your dvd drive in the my computer folder then click on properties from there you will get to see the region tab and you can change the region setting for the dvd you will be using. but you will only be allowed to change region 5 times
Jun 12, 2008 | Medion Computers & Internet
Need code for durabrand portable dvd player
  3. Press Stop.
  5. Hidden DVD Region menu appears. Select region 0 or 9 using up or down button on remote control.
  6. Press OK.
The above unlock DVD player region code trick should works on models including Durabrand DVD-1000, Durabrand DVD-1005, Durabrand DVM1418c, Durabrand LCDTV *** DVD player model PVS 21175S1 and others DVD players from Durabrand.
If the above unlock region code hack doesn’t work, or if you’re using Durabrand Car DVD Player model PVS1966, Durabrand PVS1960, Durabrand PVS1680, Durabrand PVS1970, Durabrand PVS223, Durabrand STS75E, Durabrand Dual-7B or Durabrand Dual-7BL, try the following unlock code instead.
  1. Power on the DVD player.
  2. Open the DVD disc tray or lid.
  3. Press 8 - 1 - 3 - 2 - 8 (81328 in sequence) on remote control.
  4. In DVD region code menu, press Enter until come to region 9 (or 0)
  5. Press Play.
  6. Close the DVD tray or lid.
For Durabrand Dual-900, try the following DVD multi-region or region free unblock sequence instead.
  1. Press Open to open disc tray.
  2. Press Clear.
  3. Press 1 - 3 - 6 - 9 - 0 (13690 in sequence).
  4. Press Standby button. After pressing, the DVD disc tray will close and DVD player will switch off).
  5. Press Standby button again to power up the DVD player.
Note: To set back the DVD player to region 1 if you’re using above unlock hack, simply press 13691 in sequence. The 0 or 1, the last digit in the key sequence is actually the digit to determine which region code you’re going to set on the DVD player. You can set to other region code by changing the last digit to 2, 3, 9 or other valid region code number.
For Durabrand DP305, try the following DVD region code unlock hack instead.
  1. Turn on the DVD player.
  2. Press Open/Close button to open the disc tray.
  3. Press Setup.
  4. Press 8 - 8 - 8 - 8 (8888 continuously).
  5. Press Next.
  6. Go to “Version and select a region code. Select 0 for all region or 9 for region free.
  7. Press Play.
The below trick should be able to unlock the region restriction on Durabrand DUR1700 DVD player.
  2. Press Setup.
  3. Go to “Preferences”.
  4. Press Play.
  5. Enter 2 - 5 - 1 - 5 - 3 - 5 (251535 in continuous sequence of keys).
  6. Press Left, Down.
  7. The current region code will be displayed.
  8. Press 0 for region free.
Note that if you select “Region 0′ which allows DVD players to plays all DVD-Video discs from Regions 1-6, some DVDs which are incorporated with “Regional Coding Enhancement” or RCE protection system will refuse to play in such machine.
Jun 05, 2008 | Jensen JR400 Remote Control
TELEFUNKEN TDR-100A DVD RECORDER REGION UNLOCK CODE
You do not need a region unlock code for this recorder as it supports both NTSC & PAL
Dec 09, 2007 | Televison & Video
Cant run original DVD's
open tray hit stop then press3597 chance your code for 9 or 0 then close it ll be multi region
Mar 01, 2007 | Durabrand DUR7 Portable DVD Player
Televison & Video Logo
91 people viewed this question
Top Durabrand Televison & Video Experts
matt martin
matt martin
Are you a Durabrand Televison and Video Expert? Answer questions, earn points and help others
