Adobe Photoshop CS2 for PC Logo
Posted on Jun 24, 2008
Animation to a photo
How can i add animation to a phot so...
if i take my mouse pointer over a portion of photo a text displays....
A
Anonymous
How can m a draw a landscape used with smuged tool?
Can someone tell me how to underline from left to right the entire width of the page.
select all the text on the line . place mouse pointer at start of left side of text hold down left mouse button and drag mouse pointer to the right end of line.
click on the u with the underline icon when in the home tab
or press ctrl and u
How to change view size in windows 8
You can change the view size in Windows 8 in the following ways:
1) By changing the size of text and other items on the desktop
You can change the size of text and other items (like icons) on your desktop without disturbing your current screen resolution settings. To do this, follow the steps mentioned ahead:a)Open Screen Resolution by swiping in from the right edge of the screen, tapping "Search" (or if you're using a mouse, pointing to the upper-right corner of the screen, moving the mouse pointer down, and then clicking "Search"), enter "Make text larger" in the search box, and then tapping or clicking "Make text and other items larger or smaller".
b) Drag the slider until the items in the preview image are the size you want them to be.
c) Tap or click "Apply".
You'll see the change the next time you sign in to Windows.
Also, you can change the text size for specific items (such as Window title bars or tooltips) without affecting the size of anything else on your desktop. Follow these steps to do this:
a) Open Screen Resolution by swiping in from the right edge of the screen, tapping "Search" (or if you're using a mouse, pointing to the upper-right corner of the screen, moving the mouse pointer down, and then clicking "Search"), entering "Make text larger" in the search box, and then tapping or clicking "Make text and other items larger or smaller".
b) Under "Change only the text size", choose the item you'd like to change and pick a text size. If you want the text to be bold, select the "Bold" check box.
Note: To view a pictorial description of the above process, refer to the link:
http://nvidia.custhelp.com/app/answers/detail/a_id/3153/~/adjusting-windows-8-display-size%2Fscaling-for-high-dpi%2Fppi-monitors
2) By changing screen resolution
You can change the view size on your desktop by changing screen resolution settings. To do this, follow these steps:
a) Swipe in from the right edge of the screen, tap "Settings", and then tap "Change PC settings" (If you're using a mouse, point to the lower-right corner of the screen, move the mouse pointer up, click "Settings", and then click "Change PC settings").
b) Tap or click "PC and devices", then tap or click "Display".
c)Tap or click the resolution slider and drag it until you find your desired resolution.
d) Tap or click "Apply".
To know more about the best screen resolution settings for your desktop, refer to "Set your monitor to its native resolution" section on the following link:
http://windows.microsoft.com/en-IN/windows-8/get-best-display-monitor
GuruAid.com
Logitech m 705 mouse pointer flickering
Click the Windows "Start" button or press the "Windows" key. The "Start" menu opens.
Type "Cursor blink" in the "Search programs and file" text box.
A list opens.
Click "Change Cursor Blink Rate." The "Keyboard Properties" window opens.
Click the "Speed" tab. A list of options appears.
The "Cursor Blink Rate" section shows a "Cursor Blink Rate" slider displaying a range from "None" to "Fast."
Click and drag the slider button to the "None" area in the far left portion of the "Cursor Blink Rate" scale.
Click "Apply."
Click "OK." The cursor stops flickering on the screen.
hope this helps
Dell mouse uses grab hand rather than text insert or arrow pointer
GO TO YOUR COMPUTER CONTROL PANEL THEN CLICK THE OPTION DEVICES, THEN MOUSE, THEN SELECT THE TYPE OF DISPLAY YOU WOULD PREFER FOR YOUR MOUSE
3answers
How do i delete in wordpad?
Highlight the text you want to delete by holding down the left mouse button and dragging the mouse pointer over the text, then let go of the left mouse button.
Now you can just push the DELETE button or the BACKSPACE button on your keyboard.
Or you can use your mouse to place the mouse pointer on that section of highlighted text and then click the RIGHT mouse button once. Then select CUT from the drop down menu options. This will delete that section of text.
Good luck.
How to play the text animation with out clicking
AVI video file of animation
To create this animtion, follow these steps:
  1. Insert a text box from the Drawing toolbar (in PowerPoint 2007, go to Insert tab> Text Box), and type your text. Center justify itthe text by clicking Center on the Formatting toolbar. (In PowerPoint 2007, right-click the text box and choose Center from the mini toolbar.)
  2. Click the text box's outline and copy it to the Clipboard. Paste it two times onto the slide.
  3. Drag the three text boxes apart from each other. Eventually, you'll place them on top of each other, but it's much easier to select them when they're separated. Notice that I have a plain white slide and one word.
  4. Change the properties of the text to create variations. I used 96, 72, and 48 point text, with light gray, dark gray, and black colors. Of course, if you want a different effect, you can do something different.
  1. Choose Slide Show > Custom Animation (in PowerPoint 2007, Animations tab> Custom Animation) to display the Custom Animation task pane.
  2. Select the first text box and choose Add Effect> Entrance> Fade. (If you don't see the Fade animation, click More Effects to find it.) Set the Speed to fast. Leave the Start as On Click (the default).
  3. Select the second text box and choose Add Effect> Entrance> Fade. Again set the Speed to fast, but this time set the Start to After Previous.
  4. As soon as the second text box comes in, you want the first one to fade out. So select the first text box again, and choose Add Effect> Exit> Fade. (You may need to choose More Effects to find it.) Set the Speed to Very Fast and the Start to After Previous. (I discovered by trial and error that I wanted the Speed set to Very Fast; otherwise, you wait too long for the third text box to come in.)
  5. Next, you want the third text box to fade in so select it and choose Add Effect> Entrance> Fade. Set the Start to After Previous and the Speed to Very Fast.
  6. Finally, you want the second text box to fade out, leaving just the third text box. Select it, and choose Add Effect> Exit> Fade. Set the Start to After Previous and the Speed to Fast.
Note: You can always change the order of your animations by selecting an item in the Custom Animation task pane and dragging it to a new location or using the Re-order buttons at the bottom.
  1. Save your work and test the animation to see what it looks like. Either go into slide show view or click the Play button in the task pane.
  2. To center the three text boxes on top of each other, select all three text boxes. From the Draw toolbar, choose Draw> Align or Distribute> Relative to Slide. (In PowerPoint 2007, choose Format tab> Arrange group> Align drop-down list> Align to Slide.)
  3. Now choose Draw> Align or Distribute> Align Center. (In PowerPoint 2007, choose Format tab> Arrange group> Align drop-down list> Align Center.)
  4. Choose Draw> Align or Distribute> Align Middle. (In PowerPoint 2007, choose Format tab> Arrange group> Align drop-down list> Align Middle.)
Save and try out your animation!
Fade in variations of text, one on top of the other plus magnify
You can add another animation to your objects to increase the intensity of the animation. For example, try adding a Magnify entrance effect to all three text boxes. Set the speed the same as the Fade In animation and place the animation in the task pane right after the Fade In. Set the Start to With Previous. You can see how it looks.
AVI video of both animations
Typewriter text
You can make text appear letter by letter; to add to the effect, you can add a typewriter sound. You can see the animation here. Sorry, I couldn't include the sound.
AVI video of typewriter text.
Follow these steps:
  1. Add a text box from the Drawing toolbar (in PowerPoint 2007, go to Insert tab> Text Box), and type the text.
  2. Select the text box.
  3. On the Custom Animation task pane, choose Add Effect > Entrance > Appear.
  4. Click the animation item in the task pane. Click the down arrow and choose Effect Options.
  5. On the Effect tab, choose By Letter from the Animate Text drop-down list.
  6. Set the delay between letters. I chose 0.3 seconds.
  7. From the Sound drop-down list, choose Typewriter and click OK.
Try the animation. I had the following problem -- there was no clicking sound for the last letter. That might not bother you, but it bothered me. I solved the problem by adding another letter at the end of the word and making it the same color as the background (so that it was invisible). This worked!
0010101 GIG hacker 1010101
www.gighacker.blogspot.com
Mouse portion on pointer does not work
replace the batteries, check the ir with a digital camera or camera phone (it will look like a blinking white light), then open up the remote and check the contacts. worse comes to worse, replace it.
2answers
Flash animation & actionscript
You need flash to create the animations,once done you need to save it and then insert it in dreamweaver and from there create the links...Please note the use of time frames to implement motions..
Top Adobe Computers & Internet Experts
k24674
ZJ Limited
ZJ Limited
ExpressFiX
ExpressFiX
Are you an Adobe Computer and Internet Expert? Answer questions, earn points and help others
