While working with InDesign CS2, we faced a strage problem, we copy some text portion and same paste anywhere in text area or pastboard, font gets changed, into [Times (TT)] font and in stylesheet it comes with "+" sign. But, in actual it was used some other font like "Times LT std". But in font status this font shows as a missing font. Please provide us solution to overcome this problem. It should be as it is as before paste command.
Comments:
Jun 24, 2008
- I use windows xp and PC version InDesign CS2. My problem is, when we simply copy any text portion and pasting it should come in same font, but it gets changed into [Times (TT)] font and in stylesheet also it comes with '+' sign. After that we again select that portion and apply original font, then it comes correct. We never use this font as it looks true type font.I checked preferece setting also but not getting any clue. Please give me clue on that.
I think this sounds similar to a problem my friend had once.. & it was caused by the font missing or not recognised by Windows. I could be way off base here, but anyway, we found a CD with thousands of fonts on it & installed the missing font. After that, it appeared correctly. If you go to control panel (WinXP) and go to the FONT folder, is the font in there? If not, I beleive you might have to add it. If you still have problems, pls post them here. Pls also provide the operating system version and also identify the actual font thats missing.. That is, what does InDesign see the font type as? Rgds,
Comments:
Jun 25, 2008
- Why the Inappropriate solution? That makes me look really bad. It's kinda odd really, when we spend so much time trying to help people like you & you rate before we have had a chance to even get seriously involved in sorting out your problem. Very sad really. Goodbye.
I can no longer open PM65 files since I am using my laptop with Vista. I am trying to open them in...
(More)
I can no longer open PM65 files since I am using my laptop with Vista. I am trying to open them in indesigncs2 I was able to open them when I had Windows XP I am wondering if this is the difference. I get an error that says file can not be repaired. I have used CD back up and usb cards. Almost all my pm files won't open. Appreciate any help.
I can not print a 40 page layout from InDesign CS2. I can print ads that I have created in InDesign...
(More)
I can not print a 40 page layout from InDesign CS2. I can print ads that I have created in InDesign CS2 but not a layout. The printer starts to process and then goes back to ready mode. I can create a pdf and then send to print, but that takes more time. I contacted HP about their HP Color Laserjet 4700n which is a newer printer thinking that was problem. The files will still not print. HELP! My boss wants the problem corrected ASAP. Mary Van Doren
I have indesign cs2 and need to work on a file created in indesign cs3. To open the file requires...
(More)
I have indesign cs2 and need to work on a file created in indesign cs3. To open the file requires cs3 plugins such as lilo.apun and cellstyles.rpun. Is there a patch? Can I download the plugins? Thanks
Converting a Word file to InDesign to make flash cards. Questions on one side answers on the back...
(More)
Converting a Word file to InDesign to make flash cards. Questions on one side answers on the back side. Three questions per card. Can you tell me how to go about it? Art C
I've heard of this before. I don't have any rogue empty boxes floating around. What else causes...
(More)
I've heard of this before. I don't have any rogue empty boxes floating around. What else causes this? I have serious deadlines and can't figure it out. Please help!
