Computers & Internet Logo
Posted on Nov 27, 2010
New pc 2 weeks old compaq laptop, after going online everything on my pc files converted to adobe, I want to know why, and how to change it back.
Anonymous
Level 1:
Problem Solver:
  • Contributor 19 Answers
  • Posted on Nov 27, 2010
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
19
Questions
0
Helped
2130
Points
45
It sounds like when you downloaded or installed Adobe it became the default software to open the file. If this is the case, it's a fairly simple fix.
Go to a file on your computer and right click it.
Then click on Properties.
In the Properties tab, you can select the program you want as the default. Once you do this it should change all the files with the same extensions back to the program that you want to be used.
I hope this helps.
1helpful
Flash player not installing
1) Check the settings of your anti-virus program. A lot of times an anti-virus program will not let a program download.
2) The main thing with Adobe Flash Player, is that it will NOT install a new version of Flash Player; with an old version present.
And it will NOT automatically delete the old version.
Use the Adobe Flash Player Uninstaller tool.
Then go back to Adobe Flash Player Support, and download AND install the newest version of Adobe Flash Player.
Adobe Flash Player Uninstaller tool,
http://www.adobe.com/support/flashplayer/downloads.html
Go down to the bottom of the page, where it states in bold print -
Click on the blue - Tech note - in the paragraph.
Takes you to here,
http://helpx.adobe.com/flash-player/kb/uninstall-flash-player-windows.html
Scroll down to -
1. Download the uninstaller for Flash Player
Click on the blue - uninstaller - underneath the above heading. [Uninstaller (674KB) ]
A small window will come up. Click on Save File.
A small download window will come up.
Allow the file to fully download, then DOUBLE-click right on the file name.
At the bottom of the next 3 small windows, click on Next, Next, and Finish.
If you are not asked to restart your computer, do so.
When Windows loads back up again, go back to Adobe Flash Player Support, download and install the newest version of Adobe Flash Player.
Regards,
joecoolvette
tip
How to Convert PDF to Word for Free?
As a universal file format out there, PDF is considered ideal for uploading, downloading, and publishing documents over the internet. But as it is no easy to edit or change the text in PDF format, sometimes you may need to convert PDF to other format file if you make some changes to your PDF files?<br /><br /> Recently I find many people wonder <a href="http://www.nemopdf.com/knowledge/how-to-convert-pdf-to-word.html">how to convert PDF to word</a>, but not willing to pay for Adobe Acrobat. So, here is the question, how to convert PDF to Word without Adobe Acrobat? With respect to this problem, I believe you can find many free online PDF converters. It's a really good option if your PDF files are not important. However if you want to convert some confidential PDF files to Word, it isn't an ideal choice without doubt.<br /> In that situation, my suggestion is to get an efficient PDF to Word converter. Aside from 100% free online PDF convert websites, there're many programs allowing you to convert PDF to Word for free. Here I will introduce a free PDF to Word convert software and teach you how to covert PDF to Word by using this program.<br /> <br />Nemo PDF To Word is completely free Word to PDF convert software. By using it, you can convert your PDF files to well-formatted and editable Word/RTF in seconds. After conversion, the original text, images, tables, columns, graphics and other formats are well saved in the generated files. It supports batch conversion and partial conversion, greatly saving your time.<br /> <br />As for how to convert PDF to word by using free Nemo PDF to Word, just follow the steps below, you can know how to <a href="http://www.nemopdf.com/knowledge/how-to-convert-pdf-to-word.html">convert PDF to Word for free</a>.<br /> <br />Step 1. Import PDF flies<br /> Click Add Files button to load your target PDF files into the program. The file information like file size and pages will be listed once imported.<br /> <br />Step 2. Make settings<br /> Under Output, you can specify the page range, select Word documents as output file format and output path.<br /> <br />Step 3. Covert PDF files to Word<br /> Click the Convert button to start converting your PDF files to Word.<br /> <br />When the conversion completes, a dialog box will pop up. You can view the generated Word files directly by clicking Open File or Open Folder on it.<br /> <br />Worth Noting:<br /> 1. During conversion, the Convert button will be changed to Stop button. You can stop converting anytime by clicking the Stop button.<br /> <br />2. If your PDF files are encrypted, it will pop up a dialog box for password immediately after importing it. You can load and convert the secured file normally after inputting the correct password.<br /> <br />3. If you want to convert the generated Word documents to PDF, Nemo PDF Converter will do you a favor.
on Aug 18, 2011 • Computers & Internet
I set my computer to open everything with adobe how do i change it back
do a system restore to a date prior to the date of the problem or create a new user profile then copy all your files from the old one then delete it
2answers
Want to copy something off the internet that is in pdf file format to word
You will need to download the PDF the convert it to .doc using one of several free programs you can download online. You can also use this online converter http://convertpdftoword.net/
I go to alot of websites for their information and they say I need adobe flash player to view the info. I have downloaded it but it never works.
You probably need the newest version of Adobe Flash Player for those websites.
Yes, I read where you downloaded it, but there is a flaw.
Adobe Flash Player will NOT uninstall the old version. Therefore it won't use the new version until the old version is removed. Adobe Flash Player does Not remove the old version automatically. (As many other programs do)
YOU have to manually remove the old version, before you can install the new version.
Adobe Flash Player Uninstaller.
Yep. Same place as the Adobe Flash Player new version.
Adobe Flash Player Support Center.
Go to the bottom of the page.
Under the heading Adobe Flash Player Uninstaller, you will see Tech Note in blue.
Click on it.
Or this is the page it takes you to. (I just wanted you to see how to find it)
http://kb2.adobe.com/cps/141/tn_14157.html
To the right of number 1, click on the blue - uninstall_flash_player.exe
I would set it so that it goes to your desktop screen. Much easier to find.
After the file has downloaded, go to your desktop screen.
Double-click right on the file name.
Install it.
Now run the file.
Restart your computer.
Go back to the Adobe Flash Player Support Center, and download the latest version.
Install it.
Let me know how that works in a Comment.
6helpful
3answers
My Compaq Presario CQ60 is overheating
Same issue with one I'm looking at here. A number of people have reported that using the new nvidia display drivers results in the laptop running much cooler. The download link is below, also make sure to uninstall all the other applications that come with the driver package and leave only the following.
Best of luck, Ravi Shanghavi
http://www.nvidia.com/Download/index.aspx?lang=en-uk nVidia Drivers
nVidia Display Control Panel
Same issue: Unable 2 download/view pdf files online.
In Inernet Explorer window, click Tools menu, find Manage Add-Ons.In the window that open look for a drop-down list, select all add-ons and see if Adobe Browser helper Object add-on is enabled. Enable it if it is not. If that does not work reinstall Adobe Reader.
Hope it helps
2answers
I have a problem, in short. I took my Compaq Presario apart to disconnect the internal battery, replace the faulty 3.5'' disk drive, & too check to see if their was a possibility that through out all the...
em first you should have consulted your local pc operator.Atleast you would have him responsible for that but right know you have to see any i am pretty sure they can help.
RCA e-book Reader
There's a Russian site that has software called book designer 4. Not the new version, but version 4. You can convert any text, html or word file. (Depending on your version of Word.) You can also use a LIT converter to convert LIT files to html.
Since I'm a huge fan fiction reader, this works for me. Good Luck!
2answers
PDF Converter Professional error
Your converter preferences may have to be changed to allow this document to be opened.
Grand Canyon Tech
Grand Canyon Tech
