Question about MSI RG54G2 Router (MS-6848-002)
Configuration Utility Unable to connect to 192.168.1.254. All other internet connection attempts are successful. How do I configure this router?
    Novelist:
    Scholar:
  • 134 Answers
Can you ping the router? I mean open a dos shell, type ping -tf 192.168.1.254 - what are the results? Maybe the ping fails, because you need to have your pc set to the same subnet address, to access the router on that IP. Test ping to your own gateway address first.. That will work & show you what to expect from a working ping. You get the gateway address by opening a dos shell & typing ipconfig /all - that shows the current IP address plus the gateway address. Actually, the gatway address might be the same as the router config address, unless you have a NAT function turned on.. Anyway, if you change your IP address to 192.168.1.252 - For example, you will no longer be able to access the internet, but shud be able to enter the configuration web page of the router.. Try the router default settings first. Another thing is that some routers require a direct cable called a 'crossover' cable to connect to the router or you have to go via a hub or a switch, with standard ethernet cables.. This probably looks confusing, but if it does not help, pls post your questions here.. Rgds,
Posted on Jun 24, 2008
Using 1000SW, I get report of:- Connection Status DSL Signal: DSL found on Line 1 PPP Login: Login successful Internet Address: An Internet address was verified ISP Link: Domain Name Server...
When you get a 'cant connect to configuration server', dont worry about it, thats 2wire's configuration server. If you have a 1000sw, then you've been a customer for a long time and have been registered for years and dont need the configuration server. Both you and the 2wire have been configured for years. The 2wire is trying to reach the configuration server because you set it up again, im thinking you moved, changed phone lines, or changed service.
The 2wire configuration server is to set people's 2wire's up for the first time only, and even then it doesnt matter unless you call technical support, and then they can still help you by getting the serial number off the device when that happens years later.
spin
Sep 04, 2009 | 2wire HomePortal 1000 Router
Tip
How to resolve "Limited Or No Connectivity Errors" in Windows
When attempting to set up or make network connections on a Windows computer, you may encounter a Limited Or No Connectivity error message similar to the following:
Limited or no connectivity: The connection has limited or no connectivity. You might be unable to access the Internet or some network resources.
This message can result from any of several different technical glitches or configuration problems. Follow these steps to resolve Limited Or No Connectivity errors in Windows.
1. Determine whether your network access is functioning properly (that you can reach local network resources and the Internet). If you are using a broadband Internet and Windows XP Service Pack 2, this message is often a false error report. See Microsoft Knowledge Base article 892896 for details on how to work around this error appropriately.
2. If your network access is non-functional. continue to the following steps.
3. If your computer connects to the network through a broadband router , resetting (powering off and on) the router may resolve the issue. If not using a broadband router, or if resetting your router only temporarily resolves the issue and the error message re-appears later, continue to the following steps.
If connecting to your network using Wi-Fi and using wireless security, your WEP or other security key may not be set properly. Check the wireless security configuration on your computer's network adapter and update if it necessary.
4. If connecting to your network using an Ethernet cable, your cable may have failed. Temporarily replace your network cable with a new one to determine whether this resolves the issue.
5. If using a broadband router and DHCP on your network, check your computer's IP address to verify it is valid and not a private address that starts with 169.254. An invalid address of the form 169.254.x.x signifies your computer's inability to obtain a usable IP address from your router.
To resolve DHCP configuration problems, proceed to the following steps.
6. Reboot your computer, router (if present) and broadband modem together, then re-test your connection.
7. If your connection remains non-functional, run the Windows Network Repair utility on your computer.
8. If your connection remains non-functional, update your router settings to change from dynamic to static IP address configuration, and set an IP address on the computer appropriately.
9. If your connection remains non-functional, unplug your router and connect the computer directly to your broadband modem. If this configuration is functional, contact the manufacturer of your router for additional support.
10. If your computer is connecting to your network directly through a broadband modem, or if your Internet access remains non-functional after following the instructions above, contact your Internet provider for support.
on Jul 20, 2010 | Computers & Internet
I am unable to get into my Prestige 334 configuration screen
Read this its the manual for your router.
http://www.zyxel.com/DownloadLibary_ShortName/P-334/quick_start_guide/P-334_1.pdf
May 29, 2009 | Zyxel Prestige 334 Router
Unable to connect a WGR614 Wireless Router to a DM111P Modem
Sounds like you need to port forward your router. Go to port forward .com. find your router and follow the instructions. Hope this does the trick for you.
Nov 26, 2008 | NetGear WGR614 Wireless Router
My computer down stairs says im connected to the router upstair,but i can,t connect to the internet down stairs.is it my wireless n usb network adapter.
Try putting the router ip address in your browser address bar, if the router configuration page is displayed this would normally mean there is not a problem with your wifi connection.
Most routers will from these pages indicate wether you are connected to the internet successfully if you are unable to determine this from the indication lights on the router.
Mar 25, 2008 | Computers & Internet
Access web configuration
Note: Not all D-Link routers, print servers and access points have a web-based configuration utility. Please check the manual for your particular product. In particular, the DWL-900AP does not have a web utility while the DWL-900AP+ does have a web utility. You cannot gain web-based configuration utility functionality for the DWL-900AP by installing the DWL900AP+ utility. When entering the IP address of the D-Link device (192.168.0.1 for example), you are not connecting to a website on the Internet or have to be connected to the Internet. The device has the utility built-in to a ROM chip in the device itself. Your computer must be on the same IP subnet to connect to the web-based utility. Make sure you have Java enabled and are using an updated web browser. We recommend the following: Internet Explorer 5.5 or higher Netscape 6 or higher Mozilla 1.2.1 (5.0) or higher Opera 6.0 or higher Safari 1.0 or higher (with Java 1.3.1 or higher) Camino 0.7 or higher Firefox 0.8 or higher -------------------------------------------------------------------------------- Internet Explorer 6 (SP1) users: If you continue to receive Error 500 when trying to connect to the web-based configuration of your D-Link device, make sure you have the latest Windows update for Explorer 6. -------------------------------------------------------------------------------- If you have Windows XP or Server 2003, you must download the latest Java patch from www.java.com. Click here to download patch - http://www.java.com/en/download/index.js... To resolve difficulties accessing a D-Link model that has a web utility, please follow the steps below. Step 1 Verify physical connectivity by checking for solid link lights on the device. If you do not get a solid link light, try using a different cable or connect to a different port on the device if possible. If the computer is turned off, the link light may not be on. What type of cable should I be using? - http://support.dlink.com/faq/view.asp?pr... Step 2 Disable any internet security software running on the computer. Software firewalls such as Zone Alarm, Black Ice, Sygate, Norton Personal Firewall, and Windows XP firewall may block access to the configuration pages. Check the help files included with your firewall software for more information on disabling or configuring it. Step 3 Configure your Internet settings. Go to Start > Settings > Control Panel. Double-click the Internet Options Icon. From the Security tab, click the button to restore the settings to their defaults. Click the Connection tab and set the dial-up option to Never Dial a Connection. Click the LAN Settings button. Nothing should be checked. Click OK. Go to the Advanced tab and click the button to restore these settings to their defaults. Click OK out to the desktop and close any open windows. Step 4 Check your IP address. Your computer must have an IP address in the same range of the device you are attempting to configure. Most D-Link devices use the 192.168.0.X range. Click here to find your IP Address on your computer - http://support.dlink.com/faq/view.asp?pr... If you are attempting to configure a D-Link router, then make sure you take note of your computer´s Default Gateway IP address. The Default Gateway is the IP address of the D-Link router. By default, it should be 192.168.0.1. If you are attempting to configure an Access Point or Print Server, you may need to configure your computer with a Static IP Address in the appropriate range. Click here to set a static IP address on your computer - http://support.dlink.com/faq/view.asp?pr... Step 5 Access the web management. Open your web browser and enter the IP address of your D-Link device in the address bar. This should open the login page for your the web management. Use the instructions provided with your product to login and complete the configuration. There are several more FAQs that cover the configuration of the different D-Link routers, Access Points and Print Servers.
Feb 16, 2006 | D-Link Air Xpert DI-774 Wireless Router
Feb 16, 2006 | D-Link Air Xpert DI-774 (DWL-774) Wireless...
Feb 16, 2006 | D-Link AirPro DI-764 Wireless Router
Access configuration
Feb 16, 2006 | D-Link DI-704P Router
Step 1 Verify physical connectivity by checking for solid link lights on the device. If you do not get a solid link light, try using a different cable or connect to a different port on the device if possible. If the computer is turned off, the link light may not be on. Step 2 Disable any internet security software running on the computer. Software firewalls such as Zone Alarm, Black Ice, Sygate, Norton Personal Firewall, and Windows XP firewall may block access to the configuration pages. Check the help files included with your firewall software for more information on disabling or configuring it. Step 3 Configure your Internet settings. Go to Start > Settings > Control Panel. Double-click the Internet Options Icon. From the Security tab, click the button to restore the settings to their defaults. Click the Connection tab and set the dial-up option to Never Dial a Connection. Click the LAN Settings button. Nothing should be checked. Click OK. Go to the Advanced tab and click the button to restore these settings to their defaults. Click OK out to the desktop and close any open windows. Step 4 Check your IP address. Your computer must have an IP address in the same range of the device you are attempting to configure. Most D-Link devices use the 192.168.0.X range. Click here to find your IP Address on your computer If you are attempting to configure a D-Link router, then make sure you take note of your computer´s Default Gateway IP address. The Default Gateway is the IP address of the D-Link router. By default, it should be 192.168.0.1. If you are attempting to configure an Access Point or Print Server, you may need to configure your computer with a Static IP Address in the appropriate range. Step 5 Access the web management. Open your web browser and enter the IP address of your D-Link device in the address bar. This should open the login page for your the web management. Use the instructions provided with your product to login and complete the configuration.
Feb 16, 2006 | D-Link AirPlus DI-614+ Wireless Router
MSI RG54G2 Router (MS-6848-002) Logo
190 people viewed this question
Top MSI Computers & Internet Experts
vsri9
David
David
Matthew Spark
Matthew Spark
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
