Question about SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive
Replacement of regulator IC chip
The power section of the drive has a small regulator ic chip which needs replacement as per your advice ... How to find the chip & replace it, if possible with a diagram
  • 180 Answers
Send it to me and i can do this hard ware repairing for you ..
anaesarora ata hot mail dota com
Posted on Jul 23, 2008
  • 101 Answers
You cant find this chip this will do the repair in service center only go to service center they will do the replacement
Im trying to repair a Bx4500h. there is not output, the preamp sections works and the transformer works. I tested both. Im thinking its a problem with the 3080 IC underneath the amp board. Theres 2 cables...
Well, first off, if this is an IC output, depending on the rated watts per channel, you will certainly need a rail volt greater than + - 15V. That would be for a regulated voltage somewhere else in the amp.
Mar 07, 2015 | Audio Players & Recorders
Razor v 3 keypad will not light up,everything else is fine
Hi,keypad light issues for Motorola phones are usually caused by the flex of the phone and also the Keypad IC.
The flex of the phone is located inside the phone, it controls the functions of the screen an also the keypads of the phone.
The flex is a thread like object that is located inside the phone. To see the flex, you will need to disassemble the phone to get to the flex of the phone.
After replacing the phone flex, your done.
Also it might be the screen of the phone. But in other to know if it's the screen, you will need to test a new flex.
You can get a replacement flex from any of the phone repair stores around you.
also When buttons on a cell phone does not work , it is usually a problem from the Board of the cell phone. An IC problem...
IC are small chips that has different functions on the cell phone. Each IC chips on the cell phone has it's function. The IC controlling the function of the keypads npt working is damaged and needs to be replaced.with another IC chips.
You can get IC chips from your mobile company mini office or you can simply go to the nearest Expert repair store around you area to replace the damaged IC chip that controls the key pad not working.
Sometimes, it might just be dirt or water spill that is making it not to function. You can open the cell phone and clean the keypad area,
Hope it helps.
Thanks for using fixya...
Jun 15, 2011 | Motorola Mobility RAZR V3
No picture just get a white screen. Can it be reset somehow?
You haven't mentioned, whether there is sound is Ok or not. Anyway, according to your description I understand that there is no sound too. Assuming this I advice you to replace its tuner. If there is only a white screen, that is a raster only with no grains, tuner or chroma Ic may in trouble. In your case it may be chroma Ic itself. If chroma ic fails there will be no grains. In most of the modern TVs One Chip Micom is used. That 90% of tha sections are integrated to one Ic. Video If, Chroma, vertical and Horizontal Oscilator, sync: circuits, System Control etc. If any of these section inside the said ic fails, replacement of that Ic is the only remedy. You just check the chroma Ic first. If it is fauty, it will heat up more, such that we can't touch it. It will be heated upto 50 to 65 degreeC during operation. But not more. To check this, open the back cover of the Tv, locate the said Ic [it will be larger in size normaly have more than 50pins of connections on both sides; say it as DIL type, means Dual In Line], switch on the tv; without touching its any internal parts, wait for two or three minutes, switch off the set and plug out the mains chord from wall socket; and just touch it with your bare fingers and feel the heat effect. If it is too hot that you can't touch it; it is the faulty. Be caucious during this process. Never touch it with power supply is energised. Keep the power plug out from the socket, before doing anything inside the Tv and keep the children away from you.
Oct 17, 2010 | Haier HLT71 7 in. Portable TV
No power to box ic is blown in power psu where can i get replacement as the top has come of chip its the ic1 or 4 chip but cant read anything from chip as no top  need to get it repaired
We can probably look up the part numbers, but we'd need the make and model of the unit. Can you please update this with that info? Also, is the IC marked on the board IC1 or IC4? Hopefully you can also indicate which IC is smoked. When we look this up, we will provide other parts that need to be checked. It is unusual for an IC in the power supply to be the only failed part.
Please update this with the above info.
Oct 23, 2009 | Audio Players & Recorders
Chip 48 is fried and i need to replace it preferably with another kind of chip for which i need technical advice on which one to use
The IC which got burnt was for SMPS regulator. And this is necessary for constant DC supply to all components on your other board. So go on the shop and ask for specified regulator IC and also read all datasheets or documentation before replacing it.
Rate this solution if it was helpful to you.
With Regards,
May 29, 2009 | Computers & Internet
SanDisk 2GB Cruzer Micro USB Flash Drive not working
Jul 23, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Cruzer Micro 2.0GB usb drive not Working
use a soft ware which restores partitions and restores mbr .. this will solve your problem .
other wise i feel the power section of you drive has a small regulator ic chip which needs replacement ..
Jun 18, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Convergence for HD channels only
Hello, please check the IC7102 (24LC64). This is eeprom that contains the convergence data. Please ask the Panasonic dealer if they can supply a replacement IC with the data for your HD. If you need more info please advice. Arpi
Jun 08, 2007 | Panasonic PT-51HX41 51" Rear Projection...
SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive Logo
231 people viewed this question
Top SanDisk Computers & Internet Experts
Arora Singh
Arora Singh
Sandy Moore
Sandy Moore
Are you a SanDisk Computer and Internet Expert? Answer questions, earn points and help others
