Question about Dishwashers
Got a Diplomat ADP8322. Starts Cycle then starts bleeping 3 flashes which is a heating error. No hot water at all. Had a look and cleaned watr pressure switch still not working. Any ideas has the heating element gone.
  • Anonymous Mar 21, 2014
    goes to rinse and start button beeps and flashes 3 times
    President:
  • 1,462 Answers
Possibly heating element - only way to find out is to check continuity with a multimeter.
there is also a thermal cutout in series with the heater which could also have gone
Posted on Jun 24, 2008
Diplomat dishwasher ADP 8322 - previously not draining but neither was the sink and I've unblocked that which is now working fine. When I put it on it bleeps continuously after about 5 minutes
Hello Simon,
No water in the tub would indicate the drain is clear (unless it never filled at all...have you confirmed? Do you hear water leaving the unit?).
Those bleeps and flashing lights are of course the machines desperate effort to tell you it's problems and the code may be in the owners manual or a call to the manufacturer.
I'm a big one for checking grunge accumulation and would ensure the discharge hose is clear. This gets back to hearing water leaving the machine. You may need to pull the unit to check the hose, although a common blockage is right at the connection to your disposal.
Also, check for debris under the filter screen in the bottom of the tub, another place detritus accumulates.
All the best.
Nov 22, 2014 | Dishwashers
The CLEAN light is flashing on my Kenmore QuietGuard3 , but it won't clean anything. It starts a cycle for a few minutes, stops and starts flashing clean again. Any suggestions?
You will have to reset the dishwasher. First try and turn off the mains power and back on after a short time. If the clean light flashing starts again then you go through the hard reset procedure.
press NORMAL WASH then HEATED DRY buttons one after the other until all the lights on the board lit up (3X's). The dishwasher will enter into a cycle; Press Cancel. This should stop the flashing.
If you are supplying dishwasher from hot water inlet then make sure the inlet water temperature stays within the recommended range of 145 deg F.
Apr 21, 2013 | Dishwashers
Diplomat Dishwasher ADP8322 false starts - no inflow then beeps
ee the diagram and follow the steps for troubleshooting:
Jun 18, 2012 | Whirlpool Dishwashers
My Diplomat dishwasher ADP8352 keeps stopping
Switch off the machine at your plug end and switch ON.
Check incoming water flow. Check and fill rinse-aid liquid in the dispenser. Check dish washer salt dispenser and fill.
These are the only actions an user can try.
May 27, 2010 | Dishwashers
Diplomat adp8322 dishwasher has start button flashing 7 times and rinsne cycle light on what does this mean
This is stating that no water is entering the dishwasher.
My solution was to turn the power off at the wall and wait for 10 minutes.
Turned it back on. Pressed the Start button and held til it beeped and reset, then started as normal and all was fine.
Jan 02, 2010 | Dishwashers
Diplomat aca9102 wont start all program lights flashing and making bleeping noise
there is a small/large leek in the base of the unit with the filler module probably as i have just removed mine cleaned it emptied all the water from inside the base, tightened the hoses properly and now its running, i was a hour to repair i am a technical minded person so i had no problems but if you are unsure please contact service engineer any local repair man should be able to fix it! there was a switch controlled by a foat in the base as my unit had a leak this is what cause continuious bleeps and 3 flashing lights!!! good luck
Aug 22, 2008 | Dishwashers
Wirlpool dishwasher
I had the same problem on a Diplomat ADP8322 its apparently due to a sensor that thinks the overflow tray (in the very bottom) has water in it..... I checked, and mine didn't....... but I found that putting the machine on a pre-wash, then doing the main wash worked everytime.....
Hope this helps
May 07, 2008 | Dishwashers
Diplomat ADP8322 problem
I had the same problem. its apparently due to a sensor that thinks the overflow tray (in the very bottom) has water in it..... I checked, and mine didn't....... but I found that putting the machine on a pre-wash, then doing the main wash worked everytime.....
Hope this helps
Feb 10, 2008 | Dishwashers
Dishwashers Logo
465 people viewed this question
Top Dishwashers Experts
