Question about Sony KP-46WT520 46" Rear Projection HDTV-Ready Television
Red light blinks 10 times then 9 but won't turn on.
When I try to turn my Sony on, the red light blinks 10 times and then it blinks 9 but it won't turn on. It appears to be in standby mode. How do I get it out?
  • 2 more comments
  • Manuel Obando Jul 01, 2008
    Mi televisor Sony KP-46WT520 al encenderlo la luz roja parapadea 10 veces luego 9 veces y no me enciende que puedo hacer en este caso
    escribirme al correo mobando@avasa.com.ni o a manueloc46@yahoo.com
    Tengo un televisor Sony KP-46WT520 cuando lo trato de encender se enciende un led en color rojo y parpadea 10 veces luego 9 veces y no me enciende, por favor solicito de su ayuda.
  • shardin22 Jul 02, 2008
    I have a Sony Wega KP-46WT520 and the red light flashes when I hit the power button yet the tv does not turn on. What should I do?
  • Anonymous Mar 12, 2014
    The red light blinks 10 times. Which diode needs to be replaced?
  • Sony Master
  • 8,617 Answers
Can you confirm that the model number of your set is KP46WT520 as I dont want to give you the wrong information.
Posted on Jun 24, 2008
Sony kp-57xbr10w. Red light blinks 10 times . When you turn power on sound comes on . No picture . Then no sound and red light blinks 10 times . Help
Sounds like a highvoltage failure. might be the flyback or focus circuit too. oddly I cant find any useful info about 10 blinks.
Sep 30, 2015 | Sony Televison & Video
Trying to update my sony kdl55ex621 firmware and now I only get 10 red led light blinks
Congratz. You bricked it. Messing with fimware is mortal for electronic equipment. Maybe an authorized Sony repair service can help you, most probably not.
May 27, 2015 | Sony KDL55EX621 55 Class LED Backlit HDTV...
My Sony wega tv won't turn on goes into standby red light blinks 10 times then shuts off?
Look at the owner manual as the 10 blinks is a error code or Google the model number to locate that information--Sony error codes are general and often misleading.
I would if looking at the set inspect the lamp first.
Aug 28, 2012 | Sony Grand WEGA KDF-42WE655 42" Rear...
Sony Trinitron won't turn on red light blinks 9 times
Nine blinks - Replace D 6116 and D 6301 on the "G" board, do not re-solder as this will fix the problem temporary. Or Panel Module Error or Thermal Error. If it is intermittent 9 blinks, meaning sometimes the TV comes on and other times you get flashing, then change the switching regulator on the "G" board or check connections. Make sure the regulator is -12 or -13 (negative).
Apr 29, 2012 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Red standby blinkig light 4 time on a sony 60 in wega
4 Blink 9 out of 10 times is your lamp fan. Check and make sure it clean and free of debrey. Spin it and see if there is any grinding noise. If after you clean and reassemble and the set still shuts down, either replace the lamp fan or check your outher 3 fans as well.
Apr 26, 2012 | Sony KDS-R60XBR1 60" Projection HDTV
Kdfe55a20 won't turn on at all It's a Sony
which LED lights on front are on and or blinking?
If the red or others blink look to see if they are blinking a specific number of times--like red one blinking 3 times, pause and repeating--this is a error code and may indicate what problem in set is.
Apr 24, 2012 | Sony Televison & Video
The tv wont turn on. the red light blinks 9 times.
There is a problem with one or two of the diodes on the G board.
Zero Crossing Detector 9 times 9:0 or 9:1
Probable cause • D6116 or D6301 is open (G Board)
symptom • No picture
I hope this helps and good luck!
Oct 31, 2009 | Sony KP-51WS520 51" Rear Projection...
STANDBY LIGH BLINKING 9 times...
I have a Sony SRS BBE Trinitron (WEGA). The last few days when I tried to turn it on using the remote the Red Light would go on but the TV did not turn on. I would have to press the power button again to turn it on.. I tought the remote battery was just low.
Today when I tried to turn it on nothing is happening and the Red Light is blinking 9 times ??? I tried to unplug it and try it again, still does the same thing ???
We need help...
Lori Nall
Jun 19, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony kde37xs955 green light blinks 9 and red light blinks 6
hi..
It's in standby mode.
Do a reset and see what happens
While holding down the reset button on the remote
Press the power button on the tv
(The tv will turn itself off the back on)
Now release the reset button
It sounds like the lamp needs replaced....
thank u!!
rate me!!!
Apr 10, 2009 | Sony WEGA KDE-42XBR950 42 in. HDTV Plasma...
Sony KP-46WT520 46" Rear Projection HDTV-Ready Television Logo
900 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
