Question about Samsung PS-42C7HD 42 in. HD-Ready Plasma Television
Will not power up
Hi, I have the above model, the power was cut for a moment ( less then 10 seconds ) and when the power was turned back on at the outlet the TV On/Off button on the front of the unit will not power up and only flashers blue
  • 44 Answers
Unplug the set for 30 minutes, plug it back in and see if it works.
Posted on Jul 03, 2008
Why wont my htc at&t phone turn back on?
Hi, charge the battery back up for about 30 minutes and see if turns back on. If not, pull the battery if you can. Hold the power button down for 5 to 10 seconds. Reinstall the battery and try to power back on.
Hope this helps.
Jul 16, 2014 | HTC Cell Phones
All lights flash display reads "power out self reset in 10 seconds".
Display reads power cut restart in 10 seconds
The motor controller board has a switch mode power supply problem.
Best to get a new motor controller board Or a technician to look at it.
Look at the 6 digit part number under the bar code to get the right part for your machine.
Nov 22, 2013 | Fisher Paykel Eco IWL16
Hi, i have a v12 1400watt amp in may car and when i turn my car on it blinks in between red and green.. i dont have anything connected to the amp as i dont wanna blow anything. Its got Ground, Remote &...
connect a digital voltmeter in the speaker terminals, turn on the amp, the reading should be 0.01Volt to a maximum of 1volt but rarely it will go this high, higher than this will surely fry your loudspeaker voice coils to a crisp in less than 10 seconds, have it checked by a qualified technician.
Feb 03, 2011 | Car Audio & Video
We had a power out for a few seconds and the bl 2170w only comes on for less that a second. If I hold the Go button when it is turned on the 3 indicator lights stay on. If I let go and repress the Go...
Unplug the power to the printer before the power comes back on to avoid any damage due to surges when the power is back. After the router is back on and working. Plug your printer back. Then press the blue button for 10 seconds so that the setup page is printed. Your printer is now back on.
Sep 30, 2010 | Brother HL-2170W Laser Printer
How do you fix a ps3 when it cuts off and flashes red? my brother kept turning the system off from the back instead of from the controller or the power button in the front. Now it comes on for maybe a...
This is the YLOD. Your system needs to be professionally reflowed. Check out or call 1-888-389-3038. We are a professional repair company that can fix this for you. All of our repairs include a 90 day warranty on the whole console and not just what was repaired.
Jul 09, 2010 | Sony Playstation 3 (PS3) Console
Car stars, will run for 10 seconds then cuts out.
check your mafs it may be dirty clean it with mafs cleaner
Jan 08, 2010 | 2006 Nissan Xterra
I have a 2600 peavey amplifier and when i turn the volum up it cuts off for about 2-3 seconds what i need to do
check that the cooling fans are working. if they are not then you are probably triggering the thermal overload protection.
Nov 08, 2009 | Peavey Pv 2600 Power Amplifier
Blackjack 2 won't turn on
Hi svstskier,
This is actually a bug in the BlackJack II's firmware. If you power the BlackJack II off, but you're unable to power back on, try removing the battery for about 10 seconds, then reinsert the battery and power back on. The power button should work now.
(At the moment there's no permanent fix for this.)
Does that adequately resolve the issue?
Are you turning the BlackJack II off to conserve battery? While flying? Something else?
Sep 28, 2008 | Samsung BlackJack II Smartphone
DFI Infinity NF4 SLI won't start
Hi steve, PC repair is trial & error. I suggest you replace the power supply or test the power supply in another PC that also uses 4 SATA drives & two PCI-E slots for starters. Two boards with the same problem is odd. You must have the CPU & fan connected, memory installed, ATA 24_pin main power plugg connected (Page 17 in manual). 4-pin_12v power connected which is located (Just to the left of DDR1 memory slot). Looking at you're board the power supply should be no less than 500w.
CPU must have thermal grease between CPU & heat sink.
Even though you have fans running & LED's on & flashing, the power supply seems to be the first item to check. Make sure the bottom of the motherboard is not touching the PC case.
Try the above & post you're finding here.
Good Luck!
Jun 28, 2008 | DFI Computers & Internet
Clock doesn't update
Ensure you have the latest software....7.10
Also, hold down the menu and map button when you power it up for 15 seconds or so.
Make sure you have a clear view of the sky....let it sit for 20 min.
Answer the questions on the screen and try again.
Note: doing the above will cause the unit to lose all your favorites, recent finds etc., so do a back up.
Dec 07, 2007 | Garmin StreetPilot 2720 GPS Receiver
Open Questions:
See all Samsung PS-42C7HD 42 in. HD-Ready Plasma Questions
Samsung PS-42C7HD 42 in. HD-Ready Plasma Television Logo
127 people viewed this question
Jerry Greenberg
Jerry Greenberg
