Fitting door seal
How do I fit a door seal to a Whirlpool AWM1250 washing machine?
    President:
  • 1,462 Answers
This is general for fittying door boots.
on cabinet, door boot is usuallyn held by a wire ring tensioned by a small spring. prise it out with a screwdriver.
on tub, door boot is held usually by a giant hose clip for want of a better description. unscrew the tensioning screw and remove.
door boot will then pull off - just pull it off in one place then go round the circle.
to refit.
lubricate the groove in the door boot that fits on the tub with washing up liquid. insert groove on tub at any convenient place and force into position by running thumbs round it in opposite directions. this is a knack i have to say.
when on, replace the giant hose clip and tighten.
slip the outer part of the door boot on the cabinet - this is usually easy. replace the holding clip.
put onto rinse cycle to test for leaks
good luck
Posted on Jun 24, 2008
How do you fit a door seal to a AEG LAVAMAT 66600
Thank you for contacting fixya.com.
Please check this video along with the tutorial to install the door seal in your washing machine:-
http://www.apart4u.co.uk/video-tutorials/washing-machine-repair-videos/how-to-fit-door-seals-gaskets/aeg-how-to-change-or-fit-a-washing-machine-door-seal-or-gasket.html
Please get back to us if you have further query else please accept the suggestion.
Jun 01, 2011 | AEG Washing Machines
I need to refit the rubber door seal i managed to take it off but not sure how to fit the retaining metal band
its quite simple if you removed same....Assuming you have refitted the door boot seal the inner ring is normally fed on then tightened up with a securing screw some rings are a spring which needs to be stretched on to the seal, a good video is available at utube .com FIT DOOR BOOT SEAL
Jan 02, 2011 | Whirlpool Washing Machines
Whirlpool Front Loading Duet Washing Machine Plastic at drum front shredding
i think your talking about the rubber door seal????
you can change this yourself,,,under the seal on the case is a wire spring unhook it and the door seal will fold inside the washer,,,on the inner drum you will find the other wire spring undo this as well and pull the old door seal out through the hole in the door,,,the new seal is fitted to the iner drun first so you need to turn the new seal inside out to fit it,,,push the seal into the washer and fit the inner wire first then unfold the seal and fit it over the outer door so you can fit the wire spring,,,
easy after you have fitted a fuw 100?
Aug 21, 2010 | Whirlpool Duet 3.8 cu. ft. Front Load...
Leaking at each wash cycle
this sounds like the door seal has split,,,there not very pricy but a pain to fit,,,so here go's,,,
open the door,,look at the door seal pull it off the back of the door and you should fine a spring wire holding it there,,,undo this wire,,,now fold the seal into the washer over the inner drum,,,,there you will find the inner wire,,undo that wire and pull the seal out the washer door,,,,
to fit the new seal,,,turn the seal inside out and push it through the hole in the door then fit the inner wire on the inner drum first,,,unfold the seal and pull it through the door,,,now fit the outer wire,,,,not put the kettel on,,have a cup of tea take the pain killers for the head ache you just got,,, and think about how much money you just saved ????
now was it realy worth the trouble,,,i wonder? am i good or what?
Jul 15, 2010 | Whirlpool Duet GHW9150P Front Load Washer
What do I do when the big spring that is seemingly behind the rubber bladder of the the door opeing keeps popping out on my Whirlpool washer Duet?
that spring is for the door water seal if it "pops" off when you have a load of washing being washed you will flood your kitchen floor with water,,,fit a new door seal and a new spring fast!
Jun 29, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Trying to fit new door seal with spring keeper to washing machine
Fit the seal first and then fit the spring,it cannot be done with the spring fitted on the seal first.
Plz rate my solution.
Thanks.
Jan 17, 2009 | Zanussi WJS1265W Front Load Washer/Dryer
FITTING NEW DOOR SEAL ON WHIRLPOOL AWM5125
this is a complex repair and the machine complet frount has to be removed
May 10, 2008 | Whirlpool AWZ410 Front Load Washer/Dryer
Usually it will be just be reversing the procedure of removing the old seal. At any rate, the door will need to be disassembled.
Mar 29, 2008 | Whirlpool AWM5125/1 Front Load Washer
Washing Machines Logo
322 people viewed this question
Top Washing Machines Experts
