Question about KitchenAid KSM90 Ultra Power Series Stand Mixer
Hi, paddle attachment touches the bottom of the mixing bowl - where can I adjust the height ?
  • b_omahony Jun 24, 2008
    hi, paddle attachment touches the bottom of the mixing bowl - where can I adjust the height ?
    Genius:
  • 1,142 Answers
Please provide the make and the model ill provide you the correct info,
Posted on Jun 24, 2008
  • Maanita Chadha
    Maanita Chadha Jun 24, 2008
    This mixer is simple to operate. You choose which attachment that you desire, tilt-up the head of the mixer, and then insert the attachment. The included manual will direct toward which Attachment is best for the job. This process is easy. The 4-1/2-quart stainless steel bowl needs to be positioned onto the base and you might choose to put the shield onto the bowl. Put the tilt-head down and be sure to put the safety lever to the locked position (this prevents the head from moving while blending). You add the ingredients and use the desired speed. With 10-Speeds the options are immense.
    The 4-1/2 quart stainless steel bowl, Flat Beater, Dough Hook, Wire Whip and Shield are dishwasher safe (top rack is recommended for the shield). The KitchenAid Ultra Power KSM90 Stand Mixer is easy to cleanse with a damp cloth
  • Maanita Chadha
    You Can Reach KitchenAid at:
    Customer Satisfaction Center,
    KitchenAid Portable Appliances,
    P.O. Box 218, St. Joseph, MI
    49085-0218
    1-800-541-6390
    Genius:
  • 1,665 Answers
It may not fitted well in socket
How to tighten kitchenaid mixer motor head locking lever?
Adjust the head height first, flat paddle should just clear the bowl. Te head height adjustment can be seen in by the hinge looking from the front when the head is raised. Screw in (clockwise) to lower and out to raise. You cannot get the head lock right when head height is miles out
Jul 10, 2014 | KitchenAid KSM150PS Artisan Series Stand...
Head does not lock but when adjusted whisk touches bowl
The screw is purely for adjusting the head height and that is with the flat paddle. If the head is not locking when the paddle is at the correct height then the locking mechanism needs to be adjusted. If you take it to a Kitchen Aid authorised service person they will sort it for you, they will have done heaps of them. Often the solution is with a file, if you go too far there is no going back so best left to the experts.
Jan 21, 2014 | KitchenAid Artisan Stand Mixer KSM150PS -...
When raised to do whipping my professional 550 hd mixer attachment does not scrap the bowl to mix properly
You can adjust the mixer bowl up and down slightly. If you lower your bowl and look at the back you will see a little screw, it looks like a flat head screw and it is on the "neck" of the mixer.
You can raise and lower the bowl by adjusting this cam screw. You can tell that your bowl is adjust correctly by attaching the flat beater and put a dime in the bottom of the bowl, the beater should just barely touch the dime and move it around the bottom of the bowl.
The beater will not scrape the sides of the bowl, if you are wanting the sides of the bowl scraped I would recommend the Flex Edge Beater made by KitchenAid which is basically a flat beater with a rubberized edge which will scrape the side of the bowl as it rotates.
Here is a link to the flex edge beater on our website: http://www.mendingshed.com/kfe6l.html
Let me know if you have any other questions.
Thank you,
ColleenCustomer ServiceMendingShed.com800-339-9297
Apr 04, 2013 | KitchenAid New Professional 5.5 QT...
Hi, I have a kitchenaid 600 series bowl lift, and I have tried turning the screw both ways to adjust the beater to bowl clearance. The problem is, everyway I tuen the screw, the paddle attachment still...
From the sound of this issue I would have to say the adjustment screws are defective or stripped Normally inside the housing the screw acts like a clamp against the paddle shaft pinching it at the desired height of operation Because Kitchenaid makes alot of their housings from a die cast aluminum tin Mix its easy for the manufacturer to insert the screwed and strip threads causing this issue Replacement of the product at this point is your Only Option for safe Operation of any kitchen appliance.
May 04, 2012 | KitchenAid Food Mixers
I received my mixer as a gift for my birthday in October. The bowl gets stuck and does not release from the base. I have to hit it a number of times with a rubber mallet to get it to release. Also when...
If that is the bowl that came with the machine it is not wrong. What happens from time to time is that the head on the mixer automatically adjusts causing the beater to not operate as it should. To adjust the head on the mixer place a dime at the bottom of the bowl, attatch the beater to the mixer and make as if you are going to start mixing. The beater should JUST touch the dime. If it doesn't touch it at all or is pressing it against the bowl, tilt the head of the mixer up to locate the adjustment screw located inside the shaft. Take a flat head screw driver, turn the screw clockwise (to lower the head) or counter clockwise (to raise the head). Place the beater back on the mixer, turn the machine on and see if it moves the dime moves. Once it is properly adjusted the dime should move ever so slightly.
Nov 19, 2010 | KitchenAid KSM150PS Artisan Series Stand...
Mixer blade is chipping
If it is a tilt head mixer then adjust the screw which can be seen by tipping the head back and looking into the pivot point. Turn the screw CCW to raise the head and prevent the paddle from hitting the bottom of the bowl.
If it is a lift bowl mixer there is an adjusting screw on the frame of the stand behind the bowl holder mechanism. It rurns a cam which adjusts the height of the mixer.
See pg. 13 of the owners manual for bowl height adjustment procedure:
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%209707917.pdf
clockwise to lower the head and counterclockwise to raise the head for more clearance for the beaters.
Apr 17, 2010 | KitchenAid KSM150PS Artisan Series Stand...
How to adjust bowl height on 20 qu hobart mixer.It is an old A200 1/3 hp Paddle is to high in bowl and will not mix dough on bottom and sides of bowl
you need to remove splash shield, tilt mixer back,with a long screwdriver adj. the set screwclockwise to decrease clearance for beater to bowl clearance,always use b beater when making adj. clearance should be .054" to .115".also make sure there are no deformities in btm of bowl which can cause you problems.dont forget to vote
Dec 12, 2009 | Hobart A200 Stand Mixer
Paddle is rubbing the bottom of the mixing bowl
It is going to low down. the adjustment should at the back of the unit.
Mar 13, 2009 | KitchenAid KSM150PS Artisan Series Stand...
Kitchenaid Mixer head wobbles bad
The solution provided by luannej is useful only if your mixing attachment is striking the surface of the bowl. By adjusting the screw located at the junction of the head and base, you are actually controlling how far the head is allowed to tilt forward and, thus, the height of the attachment above the bottom of the bowl. Although the attachment striking the bottom of the bowl will lead to wobble (and noise!), it isn't usually the root cause of the wobble. In fact, the wobble may be causing the bowl strikes and adjusting the head height only hides the problem.
The head of the mixer is secured to the base by a large steel pin. Any play between the head and base comes from this hinge and its resulting tolerances. To "tighten" the sloppy tolerances causing your wobble, follow these steps: 1) Lock the mixer's head down and turn the entire mixer upside down. 2) Looking deep into the hollow base, find the small slotted set screw. This screw actually presses against the pin and takes up the slop between the head and pin. Note that this screw is not the large slotted screw I mentioned earlier visible when you tilt the head back. 3)Tighten the small set screw as much as you can. Your wobble should be greatly reduced or eliminated now. 4) Lastly, you may want to readjust the large screw controlling the head's tilt to optimize the distance between attachment and bowl. Hope this helps.
Oct 24, 2008 | KitchenAid Artisan Series Tilt-Head Stand...
KitchenAid 575 Professional Mixer
Read the instruction manual. There is a screw to adjust the beater height, it is where the mixer joins to the stand.
Feb 28, 2008 | KitchenAid K5SS Heavy Duty Commercial...
KitchenAid KSM90 Ultra Power Series Stand Mixer Logo
110 people viewed this question
Top KitchenAid Food Mixers Experts
Henry  Thomas
Henry Thomas
Custom Exchange
Custom Exchange
Colin Stickland
Colin Stickland
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
