EPSON LX-300+II PRINTER
I have installed this printer and when i try to print SWIFT messages it doesnt print properly,some characters appear to be cut and a bit faint,but when i print a windows xp test page it prints just fine!
    Sergeant:
    Champion:
  • 248 Answers
Check the paper thickness lever located at the left side of the printer, set this lever to the lowest possible setting that your paper can handle. This is the darkest that the printer can print. Other than this, it may be an application issue. Check for contrast settings in your program.
Posted on Jun 24, 2008
I can't Print from my Epson lx-300+II printer it gives communication error what to do now?
ensure that you have the correct driver installed for the printer
do it from online --select the printer make and model and select the right driver to download
Aug 18, 2015 | Epson Office Equipment & Supplies
Epson Status Monitor 3 : Epson LX-300+II ESC/P 'Communication Error' appears after printing successfully ?
Check all connections and make sure all devices are on. If the power was turned off during printing, cancel the print job. If the error does not clear, see your printer documentation.
Jan 28, 2011 | Epson LX-300+ II Matrix Printer
I have ubuntu 10.04 using printer epson lx-300 how to install . Give step by step
http://free-linux-trick.blogspot.com/2009/06/how-to-install-printer-driver-epson-lx.html
Aug 19, 2010 | Epson LX-300+ II Matrix Printer
Driver installed automaticaly in w7 but doesnt print
1st You should download proper Printer Driver. sometime windows don't install proper Driver Here you can download Driver Epson LX Printer Driver After this install the Printer driver in the system.
Installation of Printer Driver Go to the control panel Click on the System Icon Click on the Hardware Tab Click on the Device Manager then Select the Unknown Device or printer device where yellow Question Marks sign on it. Right click on it and uninstall it. After this go to the top of the device manager and click on scan for hardware changes. Driver installation Wizard start. Brows Your Driver from the Hard Disk and click on next. Driver will be install.
May 07, 2010 | Epson LX-300+ II Matrix Printer
Setting custom size (tear off) paper
I have some problem, but now have solved
1. replace your original epson lx-300+II driver by IBM ProPrinter II from windows installation driver.
2. in control panel-->printer and fax-->choose IBM Proprinter II ---> click File-->server properties--> click form tab--> chek create new and fill new paper size and don't forget give a name (ex. 8.5x6)--> save form
3.In printer and faxs right click IBM Proprinter II-->choose properties--> click device setting tab --> change tractor feed, manual paper feed and upper paper tray feed to new name (8.5x6)
4. Good luck
Jun 18, 2009 | Epson LX-300+ II Matrix Printer
Can print correcly
plz check all the settings, language setting must be check , after that if the problem not solved then uninstall the driver and again reinstall the printer driver
May 27, 2009 | Epson LX-300+II Matrix Printer
My epson LX-300 printer got wrong. it's printed strange character seem wingdings character. i used continous form, LX300 pulled the paper over n over. pls tell me how solve it tks
either corrupt drivers, or bad print head. Try reinstalling the drivers for the printer. Otherwise, the problem will be more expensive to fix then to replace the printer.
Apr 30, 2009 | Epson LX-300+ II Matrix Printer
Spooled documents get deleted
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 07, 2009 | Epson LX-300+ II Matrix Printer
Epson LX-300+II, the font problem
have you check the white cable? (from the printer head to the
mainboard) .If the white cable is ok and you confirm that the
printer head is fine, then the problem is at the mainboard.
most problems like this that i had encountered is at the transistor
at the mainboard. Try to check it out using a multitester.
Sep 06, 2008 | Epson LX-300+ II Matrix Printer
Epson lx300+ii with serial port to fujitsu pc
use the com1, and use a baud rate like 9600, with 8 and 1 bit stop. dont. be sure that is in ESC/P or IBM as you requiered. if your software use directly the serial port, be sure that the bios set up is properly. i think that the lx300+ have less buffer than lx300+2
and if you use high speed, could loose info.
Jan 28, 2008 | Epson LX-300+ II Matrix Printer
201 people viewed this question
jasbo
jasbo
