Question about InFocus LP 530 Multimedia Projector
When I put power to my LP530 all I get is a tickin sound
I got this projector from a friend, he said it was working when he last powered it up but when I came to plug a power lead in (standard PC lead with 5amp fuse) all I get is a ticking sound & all the lights on the top flash. I have stripped the unit out & the ticking sound is coming from the power board but not sure where about's? Any ideas solutions or knowledge of how to recify the problem would be greatly recieved
  • clive pearson
    clive pearson May 11, 2010
    I agree with gonzales the ticking sound may be the lamp trying to spark up .. however it could be arcing from a dam or shorted HT ballast . Be careful when you dabble with this sysytem the voltage produced is in excess of 25kv on initial arc and up to 12.5kv whilst running , The untrained should not realy touch but in the event that you have other than the bulb there is not much the untrained person can repair what experience do you have to call on annd as to how much I can tell you ?. regards Vortash
    Problem Solver:
  • 5 Answers
Pull the lamp and see if it hasnt blown. if it has replace. the ticking is the lamp trying to strike.
Posted on Feb 03, 2009
When i hook up my lp530 to my computer all it says is no signal found what do i need to do to make this projector work
there should some function key and Fn button combination on the pc that directs the screen image to the external vga connector. check in the pc manual
Jul 08, 2011 | InFocus LP 530 Multimedia Projector
I have a Infocus Lp530 that as soon as you plug it in, all the lights on the top will continually flash green and an audible clicking sound can be heard. These two things occur before the power button is...
You can try removing the main board & reseating it. Also try plugging into another outlet & make sure the plug has a ground prong on it. Itshould have 2 flat & 1 pin shaped prongs. Otherwise the clicking sound may be the lamp trying to ignite. Normally when you plug in the LP530 the green power light is on steady & then you press it to start the lamp. If its flashing as soon as you plug it in it's likely that the main board is bad, the button board is bad, or the ballast/power board is bad.
You should remove the lamp & inspect it. It should be clear without bulging in the little bulb behind the lamp glass. I service LP530s all the time & something like that is usually the main board.
Good luck,
Apr 15, 2011 | InFocus LP530V Video Projector 2000 ANSI...
InFocus LP530 with burnt original power unit. To use a new bulb, what is required to upgrade the power unit? (Apparently, 5 resistors need to be changed)
unfortunately, infocus no longer makes or even carries parts for that model. you could try getting a bad one on ebay that has a different problem and swap the parts.
Dec 14, 2009 | InFocus LP 530 Multimedia Projector
No sound on my infocus lp530 - laptop thinks its connected, audio cable is good, sound is up on the projector. suggestions?
make sure the settings on the projector are set to internal speakers and (obvoiusly) the sound is on and up on the laptop.
Oct 16, 2009 | InFocus LP 530 Multimedia Projector
I have an LP530. Need main circuit board
Try LumenArc. They stock a range of ballasts. If yours is not listed, then email them.
May 09, 2009 | InFocus LP 530 Multimedia Projector
Infocus LP530 no power
the power supply needs replacing. sometimes the caps are dried up, but show no signs of damage. when the caps doesn't work, the ps doesn't work.
May 07, 2009 | InFocus LP 530 Multimedia Projector
LP530 green Iamge
make sure the resolution on the projector matches the input resolution.
Feb 22, 2009 | InFocus LP70+ Multimedia Projector
InFocus LP530 projector not powering on
the power supply needs to be replaced. it goes after a while in this model.
Feb 09, 2008 | InFocus LP530V Video Projector 2000 ANSI...
Power does not work
ok " always check power first, sounds like internal fuse
has blown , just has to be replaced.
Jan 20, 2008 | Optoma MovieTime DV10 Multimedia Projector
Infocus lp530
I called InFocus and was walked through several steps to determine if it was a bad cable or an internal problem. My InFocus unit would power up and stay powered up with no problem until I connected it to the computer using the analog computer cable (blue connectors). They had me try it with a different computer and then with the S-Video cable. Each time the InFocus unit powered down within seconds of connecting to the computer. The problem is internal. The unit had to be sent to InFocus for repair ($180). If the unit works with the S-Video cable then your problem is a bad cable.
Jan 08, 2008 | InFocus LP70+ Multimedia Projector
InFocus LP 530 Multimedia Projector Logo
174 people viewed this question
Top InFocus Office Equipment & Supplies Experts
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
