Question about Intel Motherboard
My msi km400 8237 acpi problem
Hey .. well there is a problem tat i am facing tat my msi km400 does not work well if i enable acpi . and my windows just dont work well . sum times its usb dont work and it says that ur usb is not recognized . and sum times windows loads very late ..... and when i start winxp setup sumtimes it does not show my partitions and says tat there is no hard drive connected to this computer ... but when i select standard pc with acpi disabled then it works very fine ... so please let me know of my problem ....
my specifications are
Amd Athlon Xp 1700+
Msi Km400 8237 chipset
768 mb ddr ram
128 mb nvidia gforce card
lite on dvd rw and cdrw superdrive
160gb hard drive seagate ata 7200.7 rpm
300 volts power supply
i hope u will help me in this situation ...
  • Dave May 11, 2010
    please check the board model number. Is it a KM4M board? I require exact model. It may be either on the board or displayed in the POST screen when you first boot up
If you had APM or no power management activated, you will need to reinstall windows after turning on ACPI to load the new ACPI HAL and to detect the hardware again. Otherwise windows will be confused about the type of PC it's installed on.
Posted on Aug 23, 2008
Bios is not ACPI complaint
It's possible that the BIOS setup has been accidentally set to non ACPI mode. Check in the setup to ensure ACPI is enabled.Other possible causes are memory expansion, overclocking and incompatible driver software. Check out what you have recently installed or updated on your computer.This can occur if Windows has detected that the BIOS in the computer is not fully compliant with Advanced Configuration and Power Interface (ACPI). To correct this problem, contact the manufacturer of your computer to obtain a BIOS update that is fully ACPI compliant. (If your PC is an older model, a BIOS update may not be available). There are third party companies that will write a BIOS update for your computer for a fee which may make it more cost effective to replace your computer.You may also find help on this Microsoft Support Site.
Apr 09, 2013 | Computers & Internet
Computer wont reboot can you help me fix it
possible cause is that Windows XP was installed with the wrong power management hardware abstraction layer (HAL). Verify that power management is enabled in the BIOS. Open the Power Options applet from the Control Panel, click the APM tab, and turn on Enable Advanced Power Management support. If you don't see this option, the system is likely configured with the ACPI HAL and your problem lies elsewhere.
You can also reinstall Windows XP and manually select the ACPI HAL during installation to overcome potential power management issues with hardware (such as video cards) that does not support APM.
Oct 23, 2010 | Computers & Internet
ACPI is not a compliant
Enter you bios & disable ACPI. Restart the system. Than update your windows. There should be an update for ACPI through Microsoft update service. Once installed restart your system & enter into your bios. Now enable ACPI. Save & exit the bios.
If this does not help you can try the work around found on Microsoft's web site. See the link provided;
http://support.microsoft.com/kb/314830
Cheers
Mike
Jun 01, 2009 | MSI Computers & Internet
Blue screen ACPI.sys on install (brand new system, first install)
my client office one system working windows , when booting time displaying blue screen error" acpi.sys " . and then continusly system restart., but, i was maked the first and second repair, still now i didn't got solution for this problem. please help me. and also i want need ur help for blue screeen error.
May 15, 2009 | ASUS Computers & Internet
Cannot play sound device
Try downloading the sound drivers from the net it worked for me let me know if it worked please
Mar 13, 2009 | MSI 649 Neo-V Motherboard
Acpi bios
Hi suleman_indi, I'm guessing you have a question about the D845GVSR motherboard. If your question refers to the bios setting for ACPI. Disable it until windows has been updated to SP2. Enter your bios & enable the ACPI. Should be fine once windows has been updated. Click on this link to load Intel's site for the Intel D845GVSR motherboard.
http://downloadcenter.intel.com/Product_Search.aspx?Prod_nm=+D845GVSR&lang=eng&MissingSearchTxt=Please+enter+a+valid+product+name%2C+filename+or+product+ID+%23.&x=21&y=5
If you find you need more information, feel free to update your question.
Mike
Sep 09, 2008 | Intel D845GVSR Motherboard
Unknown device
Hello the homepage is here:
http://www.msi.com/product/mb/P6NGM-FD.html#/?div=Driver&os=XP%2032
if it does not help to upgrade the drivers
Disable it in the device manager
It also depends how new your current windows is
This failure comes often when you upgrade your bios
and running a old windows.
Good luck
Sep 06, 2008 | MSI P6NGM-FD Core 2 Quad Socket 775...
I upgraded my memory fro 256 to 512 in my HP Brio BA200, and now it tells me that the BIOS is not AcPI compliant...what the heck do I do now????
If you perform an upgrade on the BIOS to enable ACPI on a computer that is already running Windows XP , you must reinstall the operating system to enable ACPI support.
low feed backs hurt my ratings and I am tring to help you with your problem,so let me know about the information i provided you is helpfull or not..
dilipbagdi.
Apr 26, 2008 | Computers & Internet
System reboots when acpi turned off
Hi martinkp, what you need is the update from windows. Leave you're acpi enabled withing the bios. Check windows update. Windows will update (windows software for the acpi). Rule of thumb concerning windows update. Check the dates of the updates & install in order, oldest to newest. This should fix you're system from shutting down. There will be no reason to turn off acpi after updating.
Mike
Apr 06, 2008 | MSI K9VGM-V Motherboard
Problem on o/s installation
Look in your bios & see if you can disable the ACPI, (which you should be able too do. Finish installing your OS. Than update the OS. After completing all updates re-enter your bios & enable the ACPI. You should not get that error message after re-start.
Boards that support ACPI will get this error during a fresh install untill they get windows updated. All OS's
Post back if this did not help! It worked for me.
Please vote..
Jan 28, 2008 | Intel D945GNT Motherboard
Intel Motherboard Logo
372 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
