Question about Panasonic Lumix DMC-FZ5 Digital Camera
Camera turns off
In camera mode the camera turns off after 14 secs . a message on screen tells me to switch off then on again if i do this it all works ok but only for 14 secs again.in playback it is not afected,i can leave on as long as i wish.regards
  • emorileau893 Mar 27, 2009
    Turn camera on >message on screen>turn camera off then on again??
  • 95 Answers
I know these cameras very well and if this unit is displaying switch off and then on again only in camera mode then you definetly have a lens fault. if it has been dropped or knocked hard then a qualified technicain is going to have to have a look at it.
Posted on Jun 25, 2008
Panasonic DMC-ZS6 when in camera mode lens comes out and I get the message "Please turn camera off and then on again" when I turn off the lens just stays out.
There is an issue with the camera focus circuit in lens. That is why it is ok when you go into playback mode but negative when the lens is involved.
Aug 25, 2017 | Panasonic Cameras
Ricoh Caplio R7 focusing problem
Go into the menu and find "reset"...follow the on-screen instructions.
Feb 24, 2010 | Ricoh Caplio R7 Digital Camera
I get an error message, E:91:01 blinking constantly on the screen, yet the camera appears to be working fine. What's that about?
here is what your gonna do follow this carefully...ok?
someone had the same problem and they used a combination of their own and a little help from SONY site.
1. Turn OFF cam
2. Remove the battery or the power supply
3. Turn the switch to CAMERA for about 30 sec
4. Turn the switch to OFF
5. Install the battery or power supply
6. Turn the switch to MEMORY
7. Open the LCD cover and press the RESET button ( small inner button )
8. You will be prompt to adjust date/time. Do it
9. Take some pictures
Jul 04, 2009 | Sony Cyber-shot DSC-W50 Digital Camera
I do have the same problem
You can tell Sony and maybe they can fix it.
Jun 07, 2009 | Sony Cyber-shot DSC-W170 Digital Camera
No image in viewfinder or on screen
I found this solution on a different page and it fixed my camera that was having the same problem.
In the case where you get a black image, the following may be of help:
This is a common problem in older Canon S2 IS cameras, especially ones that have not been regularly used. What happens is that the lens iris gets stuck at a small aperture. Most often you can get function back. Here's how:
Turn the camera on in shooting mode.
Turn the mode selector to shutter priority ("Tv").
Use the four-way button on the back to set the shutter speed to 15 seconds. That's right, 15 seconds. (To do this you keep pressing the left direction on the four-way button until it goes from 1/1600 or whatever it might be all the way to 15")
Press the shutter release. Count to seven, then pop open the battery compartment.
Wait several seconds, then close the battery compartment.
You may need to repeat the above sequence several times to unstick the iris. If that does not accomplish it, you will likely have to send the camera in for repair.
Once you have it working again, you should use the camera regularly to keep it from sticking again.
This sounds like a pretty ghetto solution but it worked for me and I know it has worked for others. So before you go wasting your time writing letters, give this a shot.
Oct 17, 2008 | Canon PowerShot S2 IS Digital Camera
My Philips 28PW6006 28" TV will only turn on for about 5 seconds then back off again ?
I think the set is trying to tell you something, perhaps concerning the received signal standard. Philips is a global company but TV standards aren't, so it may be letting you know that it cannot sync with the available signal.
If you have, or can borrow a digital camera, take a screen shot while the message is there. Most cameras have sufficient light sensitivity that you can leave the flash turned off since it will just produce glare and possibly obscure the message. You may have to try more than once but if you would like to know what the problem is, I can't think of any other way to capture it.
If you can trap the message, post it back here to this thread and I'll attempt to translate it; I have a fair amount of foreign language familiarity.
Oct 09, 2008 | Philips 28PW6006 28" TV
Stylus 600. When I turn camera on a blue screen comes up with a message [xD] Write Protect. What does this mean and how do I make it go away?
In order to remove the message of write protect you will need to format the xD memory card. The card has somehow become corrupted. To format the memory card - press Ok - right arrow to Mode Menu - down arrow to Card tab - right arrow to Card Setup - right arrow to Format - Up arrow to Yes and then press Ok. This will permanently delete all images from the memory card and you will be able to start taking images again.
Jul 12, 2008 | Olympus Cameras
Malfunction -turns on and message to return on
the camera has a lens fault and needs to be checked by a panasonic repair technician.
Apr 23, 2008 | Panasonic Lumix DMC-FX9 Digital Camera
Error message 5e02
Turn on your camera, when the lense is opened, hold it till the blue screen appears, extend the lense to his maximum forcing it a little bit then when you turn off your camera, the noise won't be here. Turn on again your camera and hopes it works. I tried it on my camera, works well at the first try then again the error, i did it twice holding the lense when you turn it on, then it worked perfectly.
Hope it works for you.
P.S : my english isn't well but i hope it helps.
Oct 17, 2007 | Olympus Stylus 710 Digital Camera
Turn the power off and on again displayed
The Tapping at the back works perfectly for me !! Just tap it a the back a couple of times while switching the camera on xx And job done !!!!
Nov 18, 2006 | Sony Cyber-Shot DSC-T3 Digital Camera
Panasonic Lumix DMC-FZ5 Digital Camera Logo
74 people viewed this question
Top Panasonic Cameras Experts
Computer Links
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
