Question about Logitech X-240 Computer Speakers
Interference? The speakers are occasionally making a clicking noise. This is when the volume is turned down low and nothing is playing. It seems to also be when there is a change in current (ie, the fridge basically switches between humming and not humming every 20 minutes, this is as it cools and then stops for that time, but during the change every 20 minutes, a clicking noise occurs), the same thing happened when the people in the apartment below us were using an electric drill - everytime it turned on/off! Does anyone have any idea of what I should do?
  • simonj2 Jun 24, 2008
    I do! The power cable though is just plugged into the mains (but obviously the audio cable is plugged into the computer). I've never had this problem with any other speaker... is there a way around it then? Thank you!
    Scholar:
  • 82 Answers
You must use a UPS on your PC set.
Posted on Jun 24, 2008
  • Jimix Eouex
    Jimix Eouex Jun 25, 2008
    Well, maybe you have problem with your speaker, check if your speaker has really had problem by connecting it to other amplifier ( example DVD player). If it performs the same then you have trouble with your speaker but if it function right then you have problem now with your PC.
Subwoofer makes noise like an untuned TV regardless of volume knob
I would suggest your crossover unit has failed in the speaker cabinet. The crossover circuit board separates the low and high frequency content of your stereos audio signal. The low frequencies go to the bass unit (woofer) and the high frequencies go to the tweeter speaker. If the capacitor on the crossover goes open or near open circuit then noise is introduced into the sound system. Replace either the capacitor or crossover unit.
Jan 18, 2014 | Cambridge Audio Minx X300 - Powered...
Bose Companion 3 Speakers make a popping noise.
No solution i'm afraid. But i have the exact same problem. Terrible cracking interference. Unplug everything else in the house and they still crackle. Very annoying. Decided to buy a new woofer on ebay as that seemed to be the problem with possible faulty switch, but the new woofer has a different connection for the volume control. Incredibly frustrating. If you have any luck let me know. Bose want eighty quid to repair...
Jan 31, 2013 | Bose Companion 3 Computer Speakers
I have logitech z2300 speakers and they have not been working for a while. So I am trying to fix them today and have read a few forums of what might work, but as I been trying to fix them it just seems...
if you are trying to fix the sound on your computer
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers or uninstall
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps
Jun 01, 2011 | Logitech Z-2300 Computer Speakers
Speaker level really low
you have to make sure you increased the volume on the computer itself.go to the control panel and click on sound,speech and audio devices.change the volume settings and speaker settings.this should bring about the desired result.
Jul 01, 2010 | Creative Labs Inspire 6600 Computer...
I have Bose Companion 2 Series ones and the left makes odd noises
> I turn the volume to a low it still has the odd noise
If there is any drive to the speaker at all (volume not turned off), the rattle is probably coming from a broken 'surround;' the part that keeps the cone centered around the outer edge.
Another point of failure is a structure called a 'spider' that is located between the voice coil and cone that ensures the voice coil stays centered.
If there is hum with the volume turned completely down, the amplifier driving the speakers (internal or external) has a failing filter in the power supply.
Dec 14, 2009 | Bose Companion 2 Computer Speakers
Speakers making loud pitchy noise
If they are computer speakers try this: (remember i am doing this from a windows vista) on the bottom right hand of the screen there should be a volume key right click on it and click on playback devices then right click on your speakers and click properties and go to levels and turn down the volume from there and see does that work... hope this helps.
May 26, 2009 | Harman Kardon HK595 Computer Speakers
I did what u told. i went to support.dell.com and got it but now what?
I have experience with that model of speakers. When they give up the ghost, the volume is VERY low. But just to be on the safe side, check the volume properties to make sure nothing is set too low. Start>Control Panel>Sounds and Audio Devices. Check the slider bars here, check in the Advanced area as well to make sure nothing is low and check the Speaker Volume as well. If all the bars are set to their maximum, it's time for some new speakers.
Thanks for using fixya.com. If you like my answer, please help me out and rate me accordingly.
Jan 05, 2009 | Dell A215 Computer Speakers
Feedback noise in speakers and Woofer.
hi wfj1310,
that feedback comes from the distance between the mic and the speakers only. Low the record level from the mic and make the distance bigger.
it makes feedback with any speaker, not only with woofer :-/
complements
Oct 25, 2007 | Audio Players & Recorders
Speaker issues
This is a duplicate posting, click on the following link to read the active post: http://www.fixya.com/support/t161863-loud_strange_noises
Jul 28, 2007 | Dell 5650 Computer Speakers
Interference and noise
there is nothing you can do about it, your sub probley has a built in amplifier right? the only thing you can do is live with it, like most things they normally have a little fcc sticker that states "this device must accept any interference received, including interference that cause undesired operation".
Oct 06, 2006 | Logitech S200 Computer Speakers
Logitech X-240 Computer Speakers Logo
143 people viewed this question
Top Logitech Audio Players & Recorders Experts
sonic boom...
sonic boom...
masterwest
Level 1 Expert
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
