Question about Autodesk AutoCAD 2004 for PC
INTERNAL ERROR: !dblayoti.cpp@97: ePermanentlyErased
Error message : .\graphics_dx9.cpp(236): dx
Try updating your graphics card's drivers from the manufacturer's website.
Feb 17, 2010 | Office Equipment & Supplies
MadDog MD-16XDVD9 could not perform end of disc-at-once
Have you tried checking your basics ?
Firmware ?
ASPI ?
Disk Defrag ?
IDE location ?
Jumper settings ?
What type of media are you using ?
What programs are you using ?
Exactly where are you and what are you doing when your error occurs.
What are your PC's specs ?
Do you have any Roxio products installed on your PC ?
Please answer ALL of the above - if you don't know, say so, don't make something
Oct 20, 2009 | Computers & Internet
Código de erro: -5009 :
If you are installing from a cd, It may need to be cleaned. Follow the directions below, it should resolve the problem.
1. Go to the directory that holds the file for launching the installation (for example, Setup.exe).
2. Right-click on the installation file and select Run As.
3. Uncheck the box that says Protect My Computer And Data From Unauthorized Activity, and click OK.
Another possibility for resolving this error is to run Windows Update on the system before running the installation routine.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/robert_33deecd2f8e91168
Jul 10, 2009 | Microsoft Windows XP Professional
[..\..\Scr\Video\Videosegment.cpp-55]
Try to uninstall and reinstall the application.
Update your video drivers
Run windows update
Run adobe updater
May 06, 2009 | Adobe Premiere Pro CS3 Full Version for PC...
ActiveSync from my phone
Thinks jbrickman For ask Me !
Here is Another Problemes about This Phone
icon_ea.gif Error occurred accessing attachments. Verify attachment settings - Inbox Tools/Options/Storage. You should also verify that you have sufficient free storage space. icon_error.gif icon_ea.gif COM Error 80070002. icon_error.gif icon_ea.gif ..\CEOutlookTranslator\MapiFields.cpp 2333 icon_error.gif icon_ea.gif ..\CEOutlookTranslator\MapiFields.cpp 2423 icon_error.gif icon_ea.gif ..\CEOutlookTranslator\PFolder.cpp 817 icon_error.gif icon_ea.gif Error occurred while getting email field. icon_error.gif icon_ea.gif Subject of bad email: 080303 WebEx_Overview_.ppt icon_error.gif icon_ea.gif Bad email received: 3/5/08 6:00:27 PM icon_error.gif icon_ea.gif ..\CEOutlookTranslator\PFolder.cpp 679 icon_error.gif icon_ea.gif Error occurred while getting Inbox records, records Processed = 45 icon_error.gif icon_ea.gif COM Error 80070002. icon_error.gif icon_ea.gif ..\CEOutlookTranslator\PFolder.cpp 2957 icon_error.gif icon_ea.gif Error occurred while getting captured Inbox changes, changes Processed = 0 icon_error.gif icon_ea.gif COM Error 80070002.
And The SOlution Here IS :
The way to sync with Exchange Server (as detailed in the documentation that came with the phone and as I have it set up following those instructions) is:
- You go to the verizon wireless website, create your verizon account, enter all the details for your exchange server (address, username, password, etc).
- The VZW server pulls info from your exchange server and then the VZW server sends this info to your handheld.
You may want to call VZW tech support if you are having difficulty setting it up.
And Thanks
Aug 28, 2008 | Apple iPhone 3G
Burn error
You unit is faulty.. replace the unit with a new one. The CD Write Laser has probably "Burnt Out" or perhaps the "Quadrant Detector" has faulted.. either way a new unit is only way solve ya problem ... sry :(
Sep 03, 2007 | HP Media Center m7250n (ED842AA) PC...
YAMAHA CRW8424 gives Track following error..
PROBLEM DEFINITION: Basically, it is a hardware error that occurs when a drive is not capable of following a data track on a CD-R or CDRW or on the other hand, poor power flow may cause the problem SOLUTION: 1. Try use another disc, a disc with a different band. 2. If one doesn't work, you may have to open your system and use a different power connector, making sure no other devices are using the power connector in the same strand. 3. Lastly, if neither the above doesn't work, you may have to send your drive in for servicing as the head may be dirty or misaligned.
Aug 05, 2007 | Yamaha CRW 8424 Burner
Autodesk AutoCAD 2004 for PC Logo
527 people viewed this question
Top Autodesk Computers & Internet Experts
JM Computer Service
JM Computer Service
Jerry
Jerry
Are you an Autodesk Computer and Internet Expert? Answer questions, earn points and help others
