Disconnect power to range. If you have an ohm meter, you can check the burner coils for continuity from the wires at the switch. If not, open oven door, remove screws holding top. Lift up top and remove screws holding the set of burners in question and visually inspect the inner coil for a break in the burner coil.
I figure out that it's not the switch since I swap the switch with another burner/bridge having the same switch and the burner/bridge one works. Next suspected component would be wires or element radiant. Any suggestions? Thanks.
