Question about Seagate Barracuda 7200.7 ST380011A 80 GB Hard Drive
Seagate HDD external drive
My external drive seagate has detecting when i try to plug in my pc pls. help me to recover/repair my hardisc
    Problem Solver:
  • 8 Answers
Set its jumpher ot the slave position and plug it on ide2/secondary port of the motherboard and dected it from bios setting of the pc which appears when u press delet/f2 buttin when computer starts.
Posted on Oct 08, 2008
My laptop cannot detect my hard drive. It no longer vibrates and the light doesn't blink anymore.
the drive could be potentially corrupt.
plug in your HDD and run recurrva and try to recover files if you cant do that remove the HDD from the caddy and plug into a PC and test if you can access your files if not reformat by right clicking on the drive in my computer (ntfs is recommended) you will loose all data but you may be able to recover your HDD
Jan 04, 2014 | Toshiba 500GB STORE ALU2 PORTABLE USB2.0...
My hard drive freeagent desktop 500gb cannot be detected when connected to the system even when l take it to another computer, l opened the case to test seperately and discover that the HDD cannot be...
try other usb port, or other computer and see whether the hdd is detected. If still not, try to go to device manager ( http://www.computerhope.com/issues/ch000833.htm ), and then assign a drive letter to the hdd. After that, try to access it from Computer, if not able to access it, format it (use quick format) and then use this program to recover your files.
http://www.asoftech.com/adr/
May 23, 2011 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
I have plugged in seagate 250 GB seagate expansion portable drive into windows 7 but the disk is not detected. Can you help me how to resolve this ?
be sure power is supplied to the HDD, if and inter HDD change the cables, if is external check the USB cable and see if you need a complementary power brick or a second USB to power it.
Mar 17, 2011 | Seagate Computers & Internet
Hello, hard drive is not visible in the physical drive list. I was using my External HDD for almost 2months (500GB Western Digital). Suddenly the Drive missing. So followed my friends guide to get...
If you get no joy using the Troubleshooting Guide then try this...
You will need to check You Tube to find a Dismantle on your product and follow the step guide on here, the procedure should be similar.
Check 1st that your External HDD has an P.C. internal HDD inside, from You Tube, before dismantle of your External HDD. Connections for an Internal Laptop HDD may have same connections as P.C. not sure though.
Once your happy that it has continue reading and follow the step guide on the link below.
My neighbour has the Seagate FreeAgent Desk 500GB, and in under 2 weeks it started to beep and was not recognized by any Laptop or P.C. if this is the same for you with any FreeAgent Desk series ( not GO series, different procedure for GO products). You maybe in luck click this link, you may have to register in the forums to view thread.... http://www.yo-lid.co.uk/forum/viewtopic.php?f=32&t=84 Thread can be found in 'Technical' under 'General Technical Issues',
Only attempt this option if you have important information saved in it, you will find that you will be charged by your product makers for retrieval of any information saved on your product.
Thumbs up please if it's any use to you Thank you.
Sep 16, 2010 | Western Digital 320GB MyBook External USB...
Data Recovery from Seagate Desktop Expansion 500GB External Hard
This is a solution I have used in the past and it has worked. It's a Seagate Recover utility for end users.
https://services.seagate.com/diysoftware.aspx
If the data is absolutley critical and very valuable, you can send it to Seagate and they are very good at recovery as well. It gets a little pricey at $800, but I too have had to use that as well for mission critical data I could not afford to lose.
https://services.seagate.com/consumer_standard_services.aspx
Nov 06, 2009 | Seagate Computers & Internet
I have a problem with my seagate agent go 500 gb. when plugged in to my laptop it doesn't detect it and it freezes my laptop until i unplug it. how can i get to my files in the external hard drive?
try to connect it to other computer, if it doesn't help, hdd is probably broken. If you disassemble, you will find internal hard drive, which you can try to connect to desktop PC to save your data, or look up for some data recovery company
Jul 10, 2009 | Seagate Free Agent Go Small 12 GB USB...
Seagate FreeAgent External 500GB HDD - Data Recovery
well firstly if u wana recover ur data u have to make the external hdd power up but thats the major area of issue that its not powering up. the difference in plug doesnt make a difference cuz u can use the same plug,the voltage is same thorugh out in ur place from the substation. so it might be a possibility that when u connected ur hdd,the power ON/OFF switch was awredy ON IF hdd has one. so wat i feel is dat u can try opening the hdd and then connect the hdd to ur desktop with help of the BUS CABLE used to connect the HDDs in desktops. so in dat case i would suggest that u go through the manual of ur external hdd to see how to access the the casing in which the hdd is there.then if u happen to get thorugh n it turns on then u dont have to recover ur data. it would still be there. HOWEVER,its recommended that u dont try these things personaaly if u are'nt too tech savy. u shud consult a tech or a freind who knows abt this.
Oct 06, 2008 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
DATA RECOVERY
Ok,Download software for recover your data from Memory Card, Phone, HDD or any other Storage Device ----
Download from the following link ------
http://www.dasofts.com/software/3675-recover-my-files-3.98-build-6218.html
Note- this software is works only with windows operating system so, connect your Memory Card, Phone, HDD or any other Storage Device to computer to recover data.
For any other help contact me.
Thanks
Jul 12, 2008 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Hard Disk Drive Not Detected
Does your hard drive get detected in the BIOS? If yes then you can recover data by plugging that hard drive as secondary and running a recovery application like Recover My Files.
Dec 23, 2007 | Seagate (ST3160827AS) 160 GB Hard Drive
Seagate Barracuda 7200.7 ST380011A 80 GB Hard Drive Logo
97 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Computer Links
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
