Ndt-40 manual would like to tune video to channel on a new tv
Stick a dvd or video in, press play, then auto/manually tune your new tv. Or simply plug in to AV slot if available.
Posted on Mar 21, 2010
How do I retune my Samsung smart TV 40"with 3D
Country (Area)
Broadcasting > Channel Settings > Country (Area)
Select your country so that the TV can correctly auto-tune the broadcasting channels. This depends
on the country or region.
When the PIN input screen appears,enter your 4 digit PIN number.
Digital Channel
Change the country for digital channels.
Analogue Channel
Change the country for analogue channels.
Manual Tuning
Broadcasting > Channel Settings > Manual Tuning
Scans for a channel manually and stores in the TV.
If a channel is locked using the Channel Lock function, the PIN input window appears.
This function depends on the country and region
Page 147 of this User Manual located on this page will give you more information. (Sorry it wouldn't let me link the PDF manual directly)
UE40H6240AK UE40H6240AKXXU Support SAMSUNG UK
Sep 09, 2014 | Samsung 40" 1080p 3D Slim LED Smart TV...
Have older tv, cable ready only. Hooked dvr to it...cable in dvr then to tv, but cant get setup to come in on any station. Tried both E1 & E2, get nothing
You will need to manually tune a new program channel in to the frequency that the DVD outputs at. It will tell you the frequency it is in the DVD manual. It will be Analogue TV rather than Digital TV option on TV so you need to tune in an analogue channel manually. Also make sure you use an antenna cable at 75 ohms impedance rather than a video cable. They look exactly the same but electronically they are quite different and a video cable will not work from RF out DVD player to RF Antenna In on TV.
Aug 24, 2014 | Televison & Video
I bought a second hand philips tv 29ht2212/79r and have tuned in the channels via the interaction menu using 3 1 9 7 5 3 mute on remote and the sound wont work now. is there something i have to enter to...
open the cover of your tv look for the sound IF using a plastic precesion screw driver adjust the IF counter clock wise slowly untill you reach a good sound or clockwise...if nothong happen solder a 0.2 ceramic capacitor to your sound IF at the coil of the IF under the board the IF has two terminals for the coil.sound if is located near the tuner section..there are two IF the video I.F and sound I.F
May 20, 2010 | Televison & Video
I inherited an old Sony Trinatron TV it's working fine & have just bought and LG VCR to replace a VCR that broke which also works fine. The problem is in tuning the VCR into TV. I automatically tuned...
Depending on where you live you might have to go buy an HD antenna and scan for channels and hope you can get a PBS station or something to get you off of zero and then go into the menu and manually program a channel you can use to tune your VCR maybe that might do the trick
Jun 22, 2017 | Televison & Video
I have a poloriad flat lcd tv now channel 40 is the only channel where their is not sound all other channels have sound. We have cable and our other tv on channel 40 is ok but on the poloriad no sound on...
Could be the tuning of channel . Try doing an automatic channel search again and see if it will tune in more closely and get the full audio level.
Also, you might try a hard reset of the internal soft codes by unplugging it overnight to allow all the internal emproms to reset.
If the cable is passing through a vcr, could be the vcr at fault, too.
Jan 17, 2009 | Polaroid FLM-323B Television
Problems tuning TV and SLV-900
the video recorder has it's own tuner you do not actually record from the tv... think of the vcr as like a tv but without a screen... connect to your tv via a scart lead and while you are on the vcr's 'channel' (so you could see a tape playing on your tv) and access the menu on you vcr (not the tv's menu) choos auto tune if the vcr supports it or manual tune if it has no auto tune and tune in the required channels on your vcr... it is simply then a matter of selecting on your vcr which channel you wish to record
Oct 13, 2008 | Sony SLV-D900 DVD Player / VCR Combo
ITD 58, 59, 60, 61
press info button on the remote then goto tuning on the blue screen menu. say yes to auto tune then save.
Jul 28, 2008 | Sagem PVR 6280 Freeview DTV Receiver /...
Sharp LC-52D62U HDTV won't tune-in channel 21.
Sounds like the signal is probably too strong. The TV is not the problem.
Jan 16, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Televison & Video Logo
163 people viewed this question
Top Televison & Video Experts
Electro Med Services...
