Phillips hdd6320 battery replacement - Audio Players & Recorders
  • Anonymous Nov 10, 2008
    i have the same problem, my mp3 will only last about 2 hours and i have been trying to find a replacement battery but i dont know where to find one.
I replace the batteries in the remote control and the train will not go. Is there batteries in the train that might need to be replace, if so, where do I find them?
According to the Instruction Manual it requires 6 AAA batteries, you will need a Phillips screwdriver to access the panel where you must replace it.
The remote controller and the engine need batteries.
Engine
• Locate the battery compartment on the back of the Engine. • Loosen the screws in the battery compartment door with a Phillips screwdriver. Lower the battery compartment door and insert three "AAA" (LR03) alkaline batteries. • Close the battery compartment door and tighten the screws with a Phillips screwdriver. Do not over-tighten. • If this product begins to operate erratically, you may need to reset the electronics. Remove the batteries and replace them in the toy.
Feb 28, 2011 | Fisher Price Geotrax Remote Control...
Phillips HDD6320/05
On the product CD, there are two parts to the Media Player installation. Try re-installing the sotfware on the CD.
May 24, 2008 | Audio Players & Recorders
Actually a HDD6320
The HDD6320 is not compatible with Windows Media Player 11.
You will need to uninstall Media Player 11, to roll back to version 10.
Also, it is not compatible with Windows Vista.
If you haven't already, install the Philips Device Manager from the product CD.
Connect the HDD6320 to the mains and PC.
Select the repair/restore option and follow the on-screen prompts.
If the HDD6320 is still not recognised, let me know if the player shows the connection icon on-screen, and I'll try to help further.
May 06, 2008 | Philips GoGear HDD6330 MP3 Player
I dropped my HDD6320 philips mp3 player and it registered as having no songs on it, but when I synchronized it with my pc they are all on it. I want to clean it completely and reinstall all the music. ...
Sounds like the file list is corrupt on the player. This means that the player ignores the files, because it doesn't scan the drive on start up, it only reads the file list.
Formatting the HDD6320 is straight forward:
Install and run the Philips Device Manager software from the product CD. The software is only compatible with Windows XP.
Connect the player, and wait for Device Manager to recognise it.
Select the Repair / Restore option and follow the on-screen prompts.
This will format the player and re-load the system files.
If you don't have the CD, it can be downloaded here:
http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?scy=GB&slg=ENG&cat=MP3_PLAYERS_CA&sct=HDD_AUDIO_JUKEBOX_SU&session=20080411075449_82.5.155.87&grp=PORTABLE_ENTERTAINMENT_GR&ctn=HDD6320/05&mid=Link_Software&hlt=Link_Software
Apr 11, 2008 | Audio Players & Recorders
Fixed screen, battery went!
There is a single plug with 3 connections for the battery. It can be accessed simply by removeing the back cover. (Don't forget to remove the 2 screws either side of the usb/charging connector first)
If the battery is not connected, then re-connect it.
Unfortunately, the batteries rarely fail on this model. Usually, a charging fault is caused by a faulty charge circuit on the main board.
Apr 09, 2008 | Philips GoGear HDD6330 MP3 Player
How do i launch philips device mamager on my philips digital audio player hdd6320
Call tech support! That's why these people get paid. Sites like this wouldn't need to exist if they did their jobs correctly!
Mar 11, 2008 | Audio Players & Recorders
Philips hdd6320 30gb
Replace or get an extremely expensive repair service.
Jun 27, 2007 | Philips HDD1630 MP3 Player
422 people viewed this question
 Grubhead
Grubhead
