Question about Microsoft Windows XP Professional
Windows xp reboot at the start up again and again
Windows xp reboot
  • nskhanna Apr 17, 2009
    window xp sp2, OS rebooting again and again.let me know yur suggestions pls ......
  • Anonymous Apr 22, 2009
    When I am unable to enter inside the windows operating system, how can i install sp3?
    Is reload the operating system is a best solution in windows?
    No one knows why the windows often corrupts and often need to reinstall the PC.
    Now I did the following steps
    1. Insert the Windows XP CD into your CD drive and restart your
      computer. If you are prompted, select any options required to start
      (boot) from the CD.
    2. When the text-based part of Setup begins, follow the prompts. Select the repair or recover option by pressing R.
    3. If you have a dual-boot or multiboot system, select the installation that you want to access from the Recovery Console.
    4. After you start the Windows Recovery Console, you receive the following message:
      Microsoft Windows(R) Recovery Console
      The Recovery Console provides system repair and recovery functionality.
      Type EXIT to exit the Recovery Console and restart the computer.
      1: C:\WINDOWS
      Which Windows Installation would you like to log on to ?
      (To cancel, press ENTER)Enter the number for the appropriate Windows installation. In this example, you would press 1. Then, Windows prompts you to enter the Administrator account password.
    5. At any time, you can type Help for a list of available commands.
    6. Try chkdsk
    "CHKDSK" is one of the more popular commands
    that you will come across in XP . For boot problems you should
    always try the "CHKDSK /P" (Outside Operating System (Recovery
    Console) or "CHKDSK /F" (Within Operating System) option first
    before you go about reinstalling or repairing Windows.
    You can exit Windows Recovery Console by typing Exit at the command line.
    then reboot.
    Usually windows will recover and start working all the software inside, then I think the problem is solved.
    But it will happen twice in 3 months , then it will corrupt the kernel and so I have to reload the windows.
    try the above steps before you reload windows.
    This is not a solution ............
  1. Insert the Windows XP CD into your CD drive and restart your computer. If you are prompted, select any options required to start (boot) from the CD.
  4. After you start the Windows Recovery Console, you receive the following message: Microsoft Windows(R) Recovery Console
    1: C:\WINDOWS
  6. Try chkdsk
"CHKDSK" is one of the more popular commands that you will come across in XP . For boot problems you should always try the "CHKDSK /P" (Outside Operating System (Recovery Console) or "CHKDSK /F" (Within Operating System) option first before you go about reinstalling or repairing Windows.
then reboot.
Posted on Apr 22, 2009
Hi freinds i have a soluion before u installing windows xp sp3 or pro after u intstall sp3 u have o make a restore point mmeadiately and when ever u r compuer giving rouble go on system resore and select ur system resore poin now it solve thanks by ALEEM.
Posted on Jan 30, 2009
  • 86 Answers
Be more specific you nut case.Maybe your finger is on the reset button :-S
Posted on Aug 16, 2008
    Genius:
  • 2,785 Answers
Plz try to boot in safe mode, if the problem persists than you have to repair or reload the operating sysytem
Posted on Jun 24, 2008
2 Suggested Answers
chuppy
  • 26 Answers
SOURCE: window XP sp2 installation problem
go to the setup menu then "on" the play or plug OS then save it
Posted on May 30, 2009
How to install windows xp sp2 by using dr-dos
1. Check your BIOS to be sure your computer will boot from a CD. Enter the BIOS setup by pressing the "Delete" or F2 or "F12" key, or as directed at the startup screen, immediately after booting. Set the first boot device to "CDROM" or "DVDROM" instead of "hard drive" if it isn't already.
2. MS-DOS command prompt
Insert the Windows XP installation CD into your CD or DVD drive and restart the computer. When prompted, choose to start from the MS-DOS command prompt with CD support. The MS-DOS command prompt will appear in a moment.
3. Start SMARTDRIVE by typing "SMARTDRV" at the DOS prompt and pressing enter. You don't have to run SMARTDRIVE, but copying the files will be much quicker if you do. The computer will display the DOS prompt again.
4. Enter "CD I386" at the DOS prompt to change to the directory where the setup program starts.
5. Enter "WINNT" at the prompt to start Windows XP setup. The installation program will copy files to your computer and then display a message requesting to reboot.
6. Press the "Enter" key to reboot. The setup program will start again and check that your hard drive format is compatible with Windows XP. If not, it will guide you through partitioning and formatting the drive and then ask you to reboot once more.
7. Press "Enter" to reboot. The computer will restart in Windows XP mode and automatically start the Windows Setup Wizard to detect your hardware and finish the installation.
Feb 21, 2011 | Computers & Internet
CAN'T INSTALL WINDOWS XP. The XP disk will reformat system and load window files, but after auto reboot it just stops and then wants to reload windows again from the beginning. ?????
The first time, insert the Windows CD-ROM, and start the reinstall.
Just before the auto-reboot, remove the CD-ROM, so that it will boot from the newly-formatted disk-drive, and continue with the rest of the installation.
Dec 08, 2009 | Compaq Presario 5BW130 (180504-003) PC...
XP Keeps Rebooting at Startup
Most likely it is your hard drive. There is a boot sector on the hard drive and when xp starts it looks for that boot sector. If that boot sector is damaged xp can't find it so xp reboots again...and again...and... Try a different hard drive and see what happens.
Hank
Oct 05, 2009 | Microsoft Windows XP Professional
Window XP sp2 installation problem
May 30, 2009 | Computers & Internet
Window Xp Pro Setup Hangs at Logo Screen after reboot
You can try also to do reformat your hard drive as fresh unallocated one before doing formatting again to install windows. And check your installation disk for scratches.
May 07, 2009 | Microsoft MS Windows XP Professional SP2
I cannot reinstall windows xp in eeepc asus701
check the HDD for erorrs.
In which step you r getting BSOD, in text mode setup or
setup after reboot (GUI MODE)
Apr 13, 2009 | ASUS Eee PC 701 Notebook
XP Reboots by itself on arrival of login screen
have you tried safe mode? if safe mode is still a failure, you have no choice but to reformat 1 of those drives an do a clean installation of windows xp
Mar 17, 2008 | Computers & Internet
Microsoft Windows XP Professional Logo
1,497 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
